Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 11-19-2001, 11:37 AM   #1
NEWLW300OWNR
NEWLW300OWNR is on a distinguished road
Thumbs Down If this is common Saturn has a HUGE problem
While at the nearest Saturn dealer for some warranty work on my LW300, I noticed a V6 L sedan on a lift in the service area with the engine and subframe completely removed from the car. Service department said car has a problem with oil and water mixing in car's oil cooler. Is this problem common? What is cause of this? Defective part or poor engineering? Wouldn't the engine sustain permanent damage from water in the oil? The impression I got was they were going to just flush the engine out (oil passages and cooling passages?) after fixing/replacing the oil cooler.
Add to NEWLW300OWNR's Reputation
Rate the quality of this post and help NEWLW300OWNR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NEWLW300OWNR is offline
Old 11-19-2001, 02:09 PM   #2
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default
I havent seen anything like this yet ... im almost to 20k and havent had any real problems yet.
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 11-19-2001, 03:41 PM   #3
hugh
hugh will become famous soon enough
Default
This sounds like major internal defect in oil cooler allowing oil and coolant to mix. Leaking of coolant onto engine block due to poor external sealant is not unheard of but is minor problem as there is no way oil and coolant can mix. It happened on my LS2. It was fixed in a couple of hours.
In view removal of engine,there is probably more than just flushing block and replacing oil cooler involved. If coolant has been getting into oil for any length of time it could mean serious damage to engine........good reason for checking oil dipstick frequently for brownish foam deposit.
It would be interesting if you could let us know what problem actually was.
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline
Old 11-19-2001, 03:47 PM   #4
Tony
Tony is on a distinguished road
Tony's Avatar
Default
I have better than 18,500 on my V6 and have not had a problem like this. I have not heard of one till now either.
Add to Tony's Reputation
Rate the quality of this post and help Tony reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tony is offline
Old 11-19-2001, 06:49 PM   #5
NEWLW300OWNR
Default give them an email
I do know the car in question is a silver L300. The dealer can be reached at their website, www.saturnofpleasanton.com. Maybe if you email their service department they will divulge exactly what they found to be the problem with this particular car. Other than checking our dipsticks, I don't know any other way of watching out for this!
Old 11-19-2001, 07:52 PM   #6
SATURNFAN13185-2
SATURNFAN13185-2 is on a distinguished road
SATURNFAN13185-2's Avatar
Default About checking oil......
Someone mentioned that you need to check your oil for foamy substance---while an excellent idea, and I do it with my car (a '97 Dodge), on a new car I don't think that's something you should have to do. You shouldn't have to worry about problems like that on a new car...
SATURNFAN13185
Add to SATURNFAN13185-2's Reputation
Rate the quality of this post and help SATURNFAN13185-2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SATURNFAN13185-2 is offline
Old 11-19-2001, 11:21 PM   #7
hugh
Default
Saturnfan;
I agree,but sad to say, things like that can happen at any time.
hugh is offline
Old 11-20-2001, 06:36 AM   #8
BillS
BillS is on a distinguished road
Default
I've never seen it or heard of it in the L series. If it was a common problem, it would be all over this site.
It happed to my 84 BroncoII once. Don't get me started on THAT one. My first and last SUV if you can call it that.
Bill
Add to BillS's Reputation
Rate the quality of this post and help BillS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BillS is offline
Old 12-13-2004, 01:44 PM   #9
tazunemono
tazunemono is on a distinguished road
Default Re: If this is common Saturn has a HUGE problem
Please see my post at
http://www.saturnfans.com/forums/sho...369#post518369
let me know if it's related
Add to tazunemono's Reputation
Rate the quality of this post and help tazunemono reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tazunemono is offline
Old 12-13-2004, 05:30 PM   #10
94sc293sl1
94sc293sl1 is on a distinguished road
94sc293sl1's Avatar
1994 SC2
Wow, talk about bringing up threads from the dead. This thread is more than three years old!
Craig
Saturn owner no longer as of 12/21/05, sold my SC2.
www.insidetrackmagazine.com
Add to 94sc293sl1's Reputation
Rate the quality of this post and help 94sc293sl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94sc293sl1 is offline
Old 12-13-2004, 06:00 PM   #11
walt
walt has a spectacular aura aboutwalt has a spectacular aura aboutwalt has a spectacular aura about
This is an Isolated incident for sure. There are to many Ls out there for the general public to not have heard about this happening to others.This was most likely a faulty part which happened in assembling.
Add to walt's Reputation
Rate the quality of this post and help walt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
walt is offline
Saturn SL head cracked (apparently a common problem) king_tim S-Series General 45 05-06-2017 09:36 AM
I have a huge problem. Tjjuine S-Series General 15 10-26-2008 08:24 PM
vue transmission huge problem Sincere2883 Vue Tech 4 08-08-2008 07:40 PM
huge problem after rebuild??? 99saturnsl2 L-Series General 1 08-01-2006 09:06 PM
Common Problem I Assume? ECTS maybe? Elementkng20 S-Series Tech 7 03-25-2006 07:26 PM
