#1 | ||||
![]() Join Date: Feb 2005
2007 AURA XR
2007 Outlook XR
So I open up the hood of my Ion to put in my new NGK's and I can't for the life of me figure out what I have to do to get the spark plugs out - anybody help me out here? I realize we have a coil-on-plug setup, and have never worked w/ one. Thanks!
... +rep always appreciated! The Procharged Ion - http://kickassion.bc3tech.net 16.317s @ 85.30mph (Nearly stock) 188.28whp / 175.03wtq - SMP Stage 2 - 10psi
#2 | ||||
![]() ![]() ![]() Join Date: Apr 2002
2002 VUE 2.2L
The black piece that says "Ecotec" on it has a few bolts around the edge. Those need to be undone, and the cassette pulls up with the plug boots under it. The plugs are deep in the head of the engine from there.
~D.J.~ ... 2012 Mercedes Benz C250 Sport Sedan 2008 smart fortwo Passion Coupe 8/28/2008 - 3/12/2012 2002 VUE FWD4m - Gone but not forgotten. 5/14/2002 - 10/31/2011
#3 | ||||
Keep in mind that you don't need to change the plugs until 100,000 miles.
Only change the plugs on a COLD engine and torque them in--don't guess. ... A lousy day in paradise is still a day in paradise.
#4 | ||||||
2007 AURA XR
2007 Outlook XR
![]() ... +rep always appreciated! The Procharged Ion - http://kickassion.bc3tech.net 16.317s @ 85.30mph (Nearly stock) 188.28whp / 175.03wtq - SMP Stage 2 - 10psi
#5 | ||||
![]() Join Date: Jan 2005
2006 VUE Red Line
2007 ION-3 Sedan
put a little bit of anti seize compound on the threads of the plugs, noy too much or you may over torque when installing, that way they do not seize in the head. When taking them out cold do so slowly so as not to damage the threads. But really stock plugs are great for their service life, no need to change early.
#6 | |||||
The stock plugs are platinum tipped....good for ~100k miles. I just checked mine @ 32k miles & they were only worn .001" J ... 2003 SATURN Ion QC3m "Giggity Giggity Goo" -Quagmire
#7 | |||||
No anti sieze on the 2.2 Lt spark plugs. There is a chance that the cylinder head can be damaged. ... A lousy day in paradise is still a day in paradise.
#8 | |||||
How so???? (This doesn't make any sense to me as anti-seize prevents the aluminum head threads from sticking to the spark plug threads.) J ... 2003 SATURN Ion QC3m "Giggity Giggity Goo" -Quagmire
#9 | ||||
2006 VUE Red Line
2007 ION-3 Sedan
I would also like to know how anti seize would damage the threads.Take a look at a plug that has been in an aluminum head for 4 or 5 years and try to take it out.
#10 | ||||
I am basing my info from the L-series 2.2 Lt campaign for replacing the spark plugs for misfire. Below is the appropiate info from the campaign.
Notice: This engine has an aluminum cylinder head. Do not remove the spark plugs from a hot engine. Removing spark plugs from a hot engine may cause cylinder head damage. Before spark plugs are removed, allow the engine to cool to below 49° C (120° F). Replace spark plugs. Important: Ensure water and debris are blown out of spark plug holes before removing spark plugs. Remove old spark plugs using a 5/8 in. spark plug socket. Spark Plug Gap 1.1 mm (0.45 in.) Notice: Do NOT coat spark plug threads with anti-seize compound. If anti-seize compound is used and spark plugs are over-torqued, damage to the cylinder head threads may result. ... A lousy day in paradise is still a day in paradise.
#11 | ||||
2006 VUE Red Line
2007 ION-3 Sedan
The important thing to note is that it refers to over torquing the plugs which can damage the aluminum head. This can be done with or without anti seize, you must be careful. Anti seize just allows you to remove the plugs at a higher mileage without taking the aluminum threads out with the plug!
#12 | ||||
![]() Join Date: Aug 2002
2003 ION-2 Sedan
Jog my memory, Saturn always used NGK's as stock plugs, is this not the case with the ECOTEC?
... Save the Earth, Ban Slushboxes!!!!!
#13 | ||||
2005 ION-1 Sedan
1997 SL1
the 1.9 motors were a saturn design. the ecotec is a gm global division design. while i'm not sure (Can someone verify?), i'd bet there are ac delco plugs in there.
... -DS "I'm a product, of my environment So don't blame me, I just work here" Offspring - Americana
#14 | ||||
most of the GMs come with Denso's now
#15 | |||||
2005 ION-1 Sedan
1997 SL1
are they no longer producing their ac/delco brand of plugs for factory use then? this has me really interested, it would blow ppl's mind about gm. other gm ppl @ my work have a 04 colorado, 05 cobalt, and a 04 deville. should have then check theirs to see how far this spreads. i really thought the denso usage in gm built gm's was limited to s-series saturn modes. on a sidenote, what does that honda 3.5 in your vue use? for that matter, what does the opel (?) sourced 3.0L engine have? ... -DS "I'm a product, of my environment So don't blame me, I just work here" Offspring - Americana
#16 | ||||
2007 AURA XR
2007 Outlook XR
what's the torque spec on the plugs or where can i find it? I'm putting the new NGK iridium's in today.
FYI for anybody else that plans on doing this, you need a "deep socket" set to get the plugs in... I have to go buy myself a socket today.... +rep always appreciated! The Procharged Ion - http://kickassion.bc3tech.net 16.317s @ 85.30mph (Nearly stock) 188.28whp / 175.03wtq - SMP Stage 2 - 10psi
#17 | |||||
BC3TECH: have you noticed any diffrence in the performance of your car since you changed your plugs? im loking to do the same and what to know if any real diffrence was made?
#18 | ||||
2007 AURA XR
2007 Outlook XR
haven't had a go at the track yet this year. i'll let you know when I do.
#19 | ||||
2003 ION-2 Quad Coupe
the saturn repair manual state that the gap for the plug should be 1.0mm. the plugs should be torqued to 20Nm or 15 lb ft.
... You say you just passed 100,000 miles.....well I guess it is time to take off the training wheels!
#20 | |||||
| Thread Tools | |
| Display Modes | |
| Want to change my spark plugs | lilbigredhead | L-Series Tech | 4 | 02-20-2007 03:19 PM |
| How often should I change my Spark Plugs? | XenonGT | S-Series General | 15 | 02-06-2006 09:44 AM |
| Anyone change spark plugs yet? | jmettee | Ion General | 3 | 08-23-2005 07:07 AM |
| How to change spark plugs | K-1 | S-Series Tech | 51 | 05-07-2004 10:27 AM |
| When to change spark plugs? | JstHkyCin | Ion Tech | 6 | 03-25-2004 01:21 PM |
