Old 10-01-2005, 01:00 PM   #1
The_Lizard
The_Lizard is on a distinguished road
Default dead temp gauge, hesitation
New member here, my step-daughter was given an S-series sedan to use. No owner's manual, I think it is a 1996.
The temp gauge stays at dead cold, thermostat opens OK, engine starts and idles but hesitates very badly when you first hit the gas. If it quits, you need WOT to make it fire up again. No SES light.
Also, I found the #1 spark plug well was flooded in about 3/4 inch of oil, so I pulled the valve cover this morning. Nothing apparently wrong, no gasket failure (what's up with that gasket anyway, could not remove from cover) no apparent head cracks.
Does any of this sound familiar? Thanks In Advance!
Add to The_Lizard's Reputation
Rate the quality of this post and help The_Lizard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The_Lizard is offline   Reply With Quote
Old 10-01-2005, 02:45 PM   #2
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Post Re: dead temp gauge, hesitation
Boy does it. MY daughter has a 96 SC2. It has the dohc engine where the sparg plugs sit down in the holes. The small circular gasket (O-ring almost) leaked to the point of the plugs being drowned in oil (@ about 100,000 miles).
Also the The temp gauge, starting, and idling problems were caused by a cracked ECTS (coolant temperature sensor). Checking on this forum let me find that they are a known problem and have been redisgned. Use the OEM brass tip for replacement and your problem should be solved. There are two excdellent "How to's" in the library on replacement procedure. Good luck and welcome aboard.
Add to peppermrj's Reputation
Rate the quality of this post and help peppermrj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peppermrj is offline   Reply With Quote
Old 10-02-2005, 03:05 PM   #3
The_Lizard
Default Re: dead temp gauge, hesitation
Well, thanks for the tips, the fix worked! I read through the entire thread in the library and followed the directions. This time the car ran right, at least around a few blocks in the neighborhood.
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
Temp Gauge Dead, ECTS Replacement? DecayingOmega S-Series Tech 5 05-19-2007 10:24 AM
93 SC2 hesitation... stalling... dead!!! heavner S-Series Tech 10 08-27-2005 08:28 AM
Fuel Gauge dead schultp S-Series Tech 1 02-19-2005 06:57 PM
Temp Gauge Dead w/ SES Light YELO_SC2 Miscellaneous Tech 9 02-12-2004 10:58 PM
