Old 09-18-2005, 04:11 PM   #1
WingsOfSaturn
WingsOfSaturn's Avatar
Default ECTS and Temp Gauge Sensor Wiring
I am installing a 96 DOHC head into a 95 SL2. I do not want to tap a hole into the head for the temp gauge sensor. Has anyone ever spliced the single wire for the temp gauge sensor into the the non-ground wire that goes to the ECTS? Will doing this possibly mess with the PCM? My other possibility would be to tap a hole into the elbow water connection that goes to the intake manifold and install the temp gauge sensor there. If I mess this up it can easily be replaced, but not a head.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 09-18-2005, 04:15 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: ECTS and Temp Gauge Sensor Wiring
I've heard of at least one person putting a tee in a heater hose and putting one there. It was in a post a while back. Sounded like it would work.
Add to BarnOwl's Reputation
Old 09-18-2005, 05:31 PM   #3
GRIFF
GRIFF is on a distinguished road
Romzek, This is a crude way to do it, But I just put it here, Screwed it a bit and put a bunch of high temp RTV around it,
I'm sure it's not as accurate as it should be, But it's worked for the last two years.
I didn't want to do the drill & tap method either
[IMG]
Add to GRIFF's Reputation
Rate the quality of this post and help GRIFF reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GRIFF is offline   Reply With Quote
Old 09-18-2005, 05:36 PM   #4
eljefino
eljefino's Avatar
1995 SW1
The gauge will change the impedance and mess with the computer if spliced into the CTS wiring.
Griff's idea has some merit though mechanics everywhere will assume the worst when they see it. The gauge only has to please you so if it's slightly off, so what? You even have the unique opportunity to get some more of these single-wire sensors epoxied to oil pans, transmission cooler lines, etc, and a rotating switch to flip between them.
Add to eljefino's Reputation
Old 09-18-2005, 07:29 PM   #5
WingsOfSaturn
Great idea Griff. I'm going to try that. Looks like you used a brass sensor. I have a few left over ceramic ones that I am going to try it with. Dealer here charges $25 for the brass sensors so have to order them at Saturnparts.com/net.
And eljefino, good idea on multiple sensors. I may experiment with an oil temp sensor. Who cares what mechanics think, they are not touching my satties anyways.
95 SL2 MT 220K+
Old 10-22-2005, 05:25 PM   #6
WingsOfSaturn
Update on my temp gauge sensor issue. I went ahead and installed a sensor in the elbow that goes into the intake manifold. So far works great and seems to give accurate temp readings.
95 SL2 MT 220K+
Old 10-22-2005, 05:36 PM   #7
GRIFF
Romzek,
Nice job on the sensor. I wouldn't have thought about doing that. How tough was it. What size tap did you use?
Again nice job
Greg
Old 10-22-2005, 09:45 PM   #8
WingsOfSaturn
I do believe that it was a M10x1.0 tap. Was not too hard. I extended the wire with some solderless crip connectors and used some plumbers tape on the threads of the sensor. Feels a lot better knowing what the water temp is at.
95 SL2 MT 220K+
ECTS Temp Gauge Issue Questions Katmack7 S-Series Tech 17 08-22-2008 10:09 PM
New ECTS...still have Hot Temp Gauge 2NDSOUT S-Series Tech 6 05-22-2008 09:20 AM
ECTS and gauge sensor reversed? spare_change S-Series Tech 6 02-19-2008 03:56 PM
Temp Gauge Dead, ECTS Replacement? DecayingOmega S-Series Tech 5 05-19-2007 10:24 AM
Replaced ECTS... Still runs under 1/4 on temp gauge??? jessicabreck S-Series Tech 13 01-10-2005 11:19 AM
