Old 09-14-2005, 08:23 PM   #1
RDKamikaze
RDKamikaze is on a distinguished road
RDKamikaze's Avatar
2002 SC1
Default Short Ram Intake or Cold Air Intake?
What's the difference between the two and which would you suggest? Please explain why you feel that way, thanks!
Add to RDKamikaze's Reputation
Rate the quality of this post and help RDKamikaze reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RDKamikaze is offline   Reply With Quote
Old 09-14-2005, 08:45 PM   #2
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: Short Ram Intake or Cold Air Intake?
one draws air from inside the engine bay
the other draws air from the outside.
Which one is better is dependent on you.
Drive in rain, you'll have to worry about the CAI
Drive in dust alot, you'll have to clean the CAI alot.
Drive in normal california weather, the CAI is better, drive in floodgate florida alot and you'll worry about sucking in water...
really it doesn't matter which you get. The CAI gives a little better performance, but that should help you weigh the decidison on what to get. I personally have the AEM CAI, and love it. But rarely do i drive through 2 feet of water.
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline   Reply With Quote
Old 09-14-2005, 08:49 PM   #3
RDKamikaze
RDKamikaze's Avatar
2002 SC1
Down here in Mesa, it's dry all year long, we get like 1" rain a year lol. With this in mind, should I just get a short ram intake? I don't really want to spend $230 on a CAI, I'd rather spend $100 and get the same thing, but I was just wanting to clerify the quality before I run out and buy it lol.
Old 09-14-2005, 09:23 PM   #4
Token
Token is on a distinguished road
Token's Avatar
1994 SW2
My advice stay away from the Ebay products. Most of them are crap.
Go to www.checkpointautoaccessories.com
"Some days your the dog, some days your the hydrant."
Add to Token's Reputation
Rate the quality of this post and help Token reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Token is offline   Reply With Quote
Old 09-14-2005, 09:32 PM   #5
kb9wgx
kb9wgx is on a distinguished road
kb9wgx's Avatar
1996 SL1
I would definately go with the cold air intake. It will give you about 10hp. The short air ram will do a little, but the difference will be negligable. Get a KN filter, remove your resonator, and punch some extra holes in the bottom of the air box. For $50, you'll have about the same performance as a short air ram.
I made a CAI out of dryer tubing, only cause I'm poor and don't show off under the hood. While it's not the optimal set up, I did notice a big increase in power, and it really helps my gas milage if I drive conservatively with it.
Add to kb9wgx's Reputation
Rate the quality of this post and help kb9wgx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kb9wgx is offline   Reply With Quote
Old 09-14-2005, 09:52 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
goto www.aempower.com and look at the dyno results of the Short Ram vs. Cold Air. on a Saturn
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-15-2005, 05:11 AM   #7
IonNinja
IonNinja is on a distinguished road
IonNinja's Avatar
2005 ION-2 Sedan
CAI's give slightly better performance than a short ram. the difference in performance isn't huge (not huge enough to justify the price differences) but if you're looking to suck all you can out of your engine then pick up a CAI.
Technically a short ram isn't the best way to go performance wise. An air box with a drop in filter and aluminum piping would outperform a short ram.
But if you're too cheap and you just want a cool sound, buy a short ram.
2005 Saturn Ion 2 Sedan
Add to IonNinja's Reputation
Rate the quality of this post and help IonNinja reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IonNinja is offline   Reply With Quote
Old 09-15-2005, 06:08 AM   #8
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
In Mesa, it will be so hot under the hood of your car that you could even lose some performance with a WAI. I'd go with the CAI assuming you have a 5spd.
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline   Reply With Quote
Old 09-15-2005, 07:24 AM   #9
Viperoni
Viperoni is on a distinguished road
1995 SW2
Exactly what I was going to say. The CAI will keep your engine running cooler, as it will suck in cooler air.
1995 SW2 (DOHC, MP3) at 15.545 @ 87.81mph:
http://www.sounddomain.com/ride/2346787/
Add to Viperoni's Reputation
Rate the quality of this post and help Viperoni reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Viperoni is offline   Reply With Quote
Old 09-15-2005, 08:30 AM   #10
RDKamikaze
RDKamikaze's Avatar
2002 SC1
gotcha thanks everyone. Now where can I find an AEM CAI for >$200? Will I have to save up for a little longer or will I be able to get one for $200 from anywhere/one?
Old 09-15-2005, 08:33 AM   #11
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
So how come the car runs at the same temp in the summer and the winter? Oh, that's because intake air does little to effect engine running temp.
--Tom
Not a Saturn.
Add to Tom92SCm's Reputation
Old 09-15-2005, 04:52 PM   #12
sickcallawayc12
sickcallawayc12 is on a distinguished road
sickcallawayc12's Avatar
aem's cai for a saturn are around $260 almost at any place that sells them. the only exception is ebay where i've seen them around $210 at the cheapest.
1998 Chevrolet Blazer LT
all stock for now (nothin' wrong with that either)
I'll miss my Saturn, from the AEM CAI to the rear main oil seal leaks to the giant APC stickers on the side (sarcasm)
Add to sickcallawayc12's Reputation
Rate the quality of this post and help sickcallawayc12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sickcallawayc12 is offline   Reply With Quote
Old 09-15-2005, 08:15 PM   #13
Viperoni
1995 SW2
--Tom
While the coolant temperature should stay at roughly the same level, I imagine the intake manifold and TB will run cooler with a CAI vs. WAI, and in general, the air charge coming into the cylinder should be a bit cooler. Whether or not there's a measurable difference, I have no idea... but I'd figure there would be.
Old 09-15-2005, 08:55 PM   #14
sl1budgettuner
sl1budgettuner is on a distinguished road
sl1budgettuner's Avatar
1998 SL1
SRA Pros: Cheaper, no need for bypass, filter stays cleaner longer
Cons: Sucks up hot, less dense air. less Horsepower gains, not in airflow
CAI: Pros: Sucks up cold denser air, more horsepower, and filter is in the airflow.
Cons: More expensive, need a bypass to avoid hydrolock, and filter gets dirty, fast.
Add to sl1budgettuner's Reputation
Rate the quality of this post and help sl1budgettuner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl1budgettuner is offline   Reply With Quote
Old 09-15-2005, 10:49 PM   #15
Dimundave911
Dimundave911 is on a distinguished road
Dimundave911's Avatar
1998 SC1
There is no difference in engine/coolant temp if you have a CAI, WAI or stock airbox.
Dave
"Did you ever Dance with the devil in the pale moonlight?"
Add to Dimundave911's Reputation
Rate the quality of this post and help Dimundave911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dimundave911 is offline   Reply With Quote
Old 09-16-2005, 05:55 AM   #16
Token
Token's Avatar
1994 SW2
I think this site www.autoanything.com will best explain this question. Plus many more performance questions, in full detail.
Once your at the website, scroll down to where it says Research Guides and click on Air Intake Systems.
Old 09-20-2005, 10:51 PM   #17
kb9wgx
kb9wgx's Avatar
1996 SL1
As SL1budgettuner said, Cold air is denser, therefore bringing more oxygen into the engine. And the high-flow filter helps alot too.
Old 09-21-2005, 11:13 AM   #18
Sprint
Sprint is on a distinguished road
Sprint's Avatar
2004 VUE 2.2L
Most people have forgot the obvious question. You have a SC1, so its a SOHC. Do you also have a automatic?
-Allan.
My Website: http://www.allanssaturn.com/
Add to Sprint's Reputation
Rate the quality of this post and help Sprint reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sprint is offline   Reply With Quote
Old 09-22-2005, 01:50 PM   #19
sickcallawayc12
Hey, he's right. Isn't that something? Applefool mentioned that too, "assuming you have a 5spd." Assuming you are looking for an intake to purchase for your car (2001 SC1) if it is an automatic you are out of luck, no room for a CAI in those suckers. Even if you have a manual (they have them at SPS if i read it correctly) most people think it isn't worth putting performance parts on a SOHC if you planned on doing that, but I don't know if this is true for a CAI on a SOHC (I would do it if mine was a SOHC).
Old 09-27-2005, 07:23 AM   #20
Viperoni
1995 SW2
Is there any difference in air charge temperature as it near the intake ports in the cylinder head?
Short Ram Intake vs Cold Air Intake Saturn Tuner S-Series Mods 29 01-30-2010 08:54 AM
Short Ram Air Intake mjdub S-Series Mods 21 09-13-2007 10:58 PM
Cold air intake or Short Ram intake 04RedlineMike Ion Red Line 17 08-07-2007 04:35 PM
FS: 91-02 S Series Short Throw Shifter & AEM Short Ram Air Intake dacuda Classifieds 0 06-10-2006 06:39 PM
AEM Cold Air or Short Ram Intake Shortie Mods and Performance 15 11-19-2003 10:06 AM
