Old 09-14-2005, 01:08 AM   #1
WorkWagon
WorkWagon is on a distinguished road
WorkWagon's Avatar
1993 SW2
Default does disconnecting battery 'reboot' PCM.
There is freguent mention of pulling fuses to reset the memory on the PCM. Will disconnecting the battery accomplish the same thing?
I have had my battery disconnected a few times all ready; radiator replacement, and then when dealing with SIR at all.
I have replaced my ECTS and I am supposed to reset the PCM for that, right?
Add to WorkWagon's Reputation
Rate the quality of this post and help WorkWagon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WorkWagon is offline   Reply With Quote
Old 09-14-2005, 07:42 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: does disconnecting battery 'reboot' PCM.
Well there's resetting and there's RESETTING. Taking loose the battery cable will clear the current codes. It won't clear the code history. However, it's enough for an ECTS replacement.
Add to BarnOwl's Reputation
Old 09-14-2005, 08:16 AM   #3
Luke
Luke's Avatar
Default After replacing ECTS
Barn Owl
When replacing ECTS, I take it, that it is strongly recommended that the PCM be reset.
I've not done that. Comments ??
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 09-14-2005, 08:27 AM   #4
BarnOwl
BarnOwl's Avatar
Not really. It'll be fine reset or no.
Old 09-14-2005, 08:29 AM   #5
Luke
Luke's Avatar
Thank You......
Old 09-14-2005, 08:46 AM   #6
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
I think it's a good idea. As the pcm is used to adding more fuel than needed, resetting it will have it relearn a bit faster. Certainly not necessary though.
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline   Reply With Quote
Disconnecting a electrical harness SL2turnman S-Series General 1 11-27-2005 07:09 PM
disconnecting A/C vintagegz Vue General 31 03-09-2005 07:57 PM
disconnecting factory speakers Blondie21 S-Series General 15 03-19-2004 05:01 PM
Disconnecting Wiring from PCM... Rob1998SL2 Miscellaneous Tech 8 02-07-2004 11:51 AM
Disconnecting Rev Govener Mtuk_Neo Miscellaneous Tech 14 09-02-2003 09:55 PM
