Old 09-05-2005, 04:54 PM   #1
sunshn1972
sunshn1972 is on a distinguished road
sunshn1972's Avatar
Wrench Cleaning EGR Valve (with Pictures)
I cleaned my EGR valve today. I wasn't having any problems, it was just preventive maintenance. My 98 SL2 is at almost 121,000 miles, and as far as I know the EGR valve has never been cleaned. I was surprised that there was almost no build up on it. A few sprays of carb cleaner and a toothbrush got it shining in just a few minutes.
So here's what I did, with pictures.
This space intentionally left blank.
Add to sunshn1972's Reputation
Rate the quality of this post and help sunshn1972 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sunshn1972 is offline   Reply With Quote
Old 09-05-2005, 06:53 PM   #2
sunshn1972
sunshn1972's Avatar
Default Re: Cleaning EGR Valve (with Pictures)
1. Find the EGR valve. Since I had never heard of such a thing until about a month ago, this was an interesting task.
Old 09-05-2005, 06:56 PM   #3
sunshn1972
sunshn1972's Avatar
2. I removed the air intake tube to make it easier to get to the EGR valve. Remove the electrical connector from the top.
Old 09-05-2005, 06:57 PM   #4
sunshn1972
sunshn1972's Avatar
3. There is a bracket that has to e removed (see photo). Then remove the two bolts holding the EGR in place. One of them is under the lower end of the bracket.
Old 09-05-2005, 06:59 PM   #5
sunshn1972
sunshn1972's Avatar
4. Once the EGR valve is off, spray some carb cleaner in the two holes under the spot the valve came off. You can see the gasket in this picture, it didn't come off with the valve. Don't get any carb cleaner on the gasket.
Old 09-05-2005, 07:02 PM   #6
sunshn1972
sunshn1972's Avatar
5. Hold the EGR valvehorizontally and spray carb cleaner on the pinktle (see picture). I used a regular toothbrush to clean the pintle, but I had hardly any buildup.
Old 09-05-2005, 07:05 PM   #7
sunshn1972
sunshn1972's Avatar
Wrench Re: Cleaning EGR Valve (with Pictures)
6. Put it all back together inteh reverse order.
It was easier that I expected. Except for dropping the 10mm socket under the air filter and taking it off to get the socket back. Also, it would have been nice to have a deep well 10mm socket to get the bolt off that was under the bracket. I was able to do it with a standard socket, but not easily.
Let me know if I missed anything!
Old 02-23-2007, 12:51 AM   #8
phile
phile is on a distinguished road
1992 SL2
Thanks! My 1992 SL2 was running like goat manure. I took the EGR valve off and cleaned it. Runs perfect!
Add to phile's Reputation
Rate the quality of this post and help phile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phile is offline   Reply With Quote
Old 02-24-2007, 12:01 PM   #9
m.dolan
m.dolan is on a distinguished road
1994 SW2
Thumbs Up Re: Cleaning EGR Valve (with Pictures)
sunshn1972 your timing on this topic for me was perfect, being a new member to this wonderful forum, I needed to ask about this same topic. your pics were just right. Am I right to assume that the soleniod and the valve are as one unit?
Add to m.dolan's Reputation
Rate the quality of this post and help m.dolan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m.dolan is offline   Reply With Quote
Old 02-25-2007, 01:42 AM   #10
Phredawgy
Phredawgy's Avatar
If yours is identical to the pictures then that is your EGR valve...electronic instead of vacuumed I spent alot of time looking for the mushroomish EGR that the Haynes manual was showing(and that I have in a different vehicle)
Add to Phredawgy's Reputation
Old 03-03-2007, 11:37 PM   #11
JaeMarie
JaeMarie is on a distinguished road
Thanks a million, fixed a P1404 by searching for it here. took me no time to find a FAQ. removed the intake on the 2000 sl2 to make it easier, probably not necessary though.
thank you autozone for pulling the code and saturnfans for posting a how-to; saved our family $150+. Much luv.
Add to JaeMarie's Reputation
Rate the quality of this post and help JaeMarie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JaeMarie is offline   Reply With Quote
Old 09-06-2007, 01:10 PM   #12
GlennCoco
GlennCoco is on a distinguished road
1994 SL1
Besides a 10mm socket, do I need anything else for this?
Add to GlennCoco's Reputation
Rate the quality of this post and help GlennCoco reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GlennCoco is offline   Reply With Quote
Old 09-06-2007, 07:14 PM   #13
Phredawgy
Phredawgy's Avatar
Couple rags, used toothbrush, carb cleaner and a new gasket.
If you start the vehicle with the EGR off without beginning the cleaning process it will be loud as hell but you'll get alot of gunk out of there before hand
Old 09-07-2007, 01:06 PM   #14
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Re: Cleaning EGR Valve (with Pictures)
Originally Posted by Phredawgy View Post
...and a new gasket.
Gaskets are not expensive and I recommend replacing them rather than reusing them.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
Old 09-07-2007, 01:20 PM   #15
GlennCoco
1994 SL1
OK, I have the thing off. It's bigger than I thought. Am I supposed to have taken the whole thing off? It's got a big round black thing on the top of it.
Also, I think I read somewhere else that you're supposed to make sure the pintle moves freely. How do I test that exactly?
Old 09-07-2007, 02:45 PM   #16
rlhdghhmh
rlhdghhmh is on a distinguished road
rlhdghhmh's Avatar
2002 SL1
are the instructions for the DOHC the same as the SOHC is it in the same place?
2002 SL1 GO BIG OR GO HOME
Add to rlhdghhmh's Reputation
Rate the quality of this post and help rlhdghhmh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rlhdghhmh is offline   Reply With Quote
Old 09-07-2007, 04:45 PM   #17
Glen, yes, the electronic EGR valve is pretty big. You can test the movement of the pintle by pushing on it GENTLY with a screwdriver tip or the like.
Rlhdg... (why didn't you buy a vowel?), the EGR valve is a little further back on the SOHC, on the intake manifold. But the directions are pretty-much the same. When you remove the air intake tube, you'll see it.
Add to madpogue's Reputation
Old 09-09-2007, 07:18 PM   #18
L100andSW2
L100andSW2 is on a distinguished road
L100andSW2's Avatar
2002 L-Series 2.2L Sedan
1995 SW2
Just got in from following this procedure and smooth sailing. Mine had plenty of carbon crud to clean off. Maybe the first time it's been done in the SW2's 13 yrs, 139,000 miles.
Side note - the ECTS is below the EGR. With EGR set to the side, did the ECTS change procedure and its was easier since could see and reach around better. The old ECTS was plastic type and cracked, replaced with brass unit. Used this thread for instructions:
http://www.saturnfans.com/forums/showthread.php?t=24003
Add to L100andSW2's Reputation
Rate the quality of this post and help L100andSW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L100andSW2 is offline   Reply With Quote
Old 09-11-2007, 09:41 PM   #19
duganator
duganator is on a distinguished road
I hate to be that guy, but how do you know if you need to clean the egr?
Add to duganator's Reputation
Rate the quality of this post and help duganator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
duganator is offline   Reply With Quote
Old 09-23-2007, 12:40 PM   #20
saturnchap
saturnchap is on a distinguished road
I guess mine is due!I've had it 5 years and never cleaned it.I guess that's why she's getting lazy in hills.
Add to saturnchap's Reputation
Rate the quality of this post and help saturnchap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnchap is offline   Reply With Quote
cleaning egr valve bdobraj S-Series General 14 11-09-2019 09:06 AM
EGR Valve Cleaning clickclickw00t S-Series Tech 1 05-30-2007 03:14 PM
EGR Valve Cleaning - HELP! LaraKimbo S-Series Tech 5 05-12-2007 12:13 PM
EGR Valve cleaning diablo2070 S-Series Tech 5 04-02-2007 09:11 PM
Cleaning EGR valve wolfehunter S-Series General 9 07-18-2006 11:03 PM
