Old 09-03-2005, 11:35 PM   #1
Token
Token is on a distinguished road
Token's Avatar
1994 SW2
Default Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door????
I have noticed a rust problem on my 1994 SW2, that is in the same spot on both sides of the car.
It's rusting under that plastic thingy which is the trim that sits on top of the rocker panel. It's under the door when the doors are shut.
My other question is how do I fix this. I was going to just scrape it down with a wire brush and get all the loose flakes off. Then pop rivet a piece of steel on it and try to match it with some paint of the same color.
Does anyone else have this problem?
What can I do to prevent this from happening after I fix it?
What did you do to fix it?
Add to Token's Reputation
Rate the quality of this post and help Token reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Token is offline   Reply With Quote
Old 09-04-2005, 04:10 AM   #2
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door????
you really can't do anything about it...and it'll only get worse.
The door sill plate is notorious for rust in snow felt areas.
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline   Reply With Quote
Old 09-04-2005, 06:46 AM   #3
Token
Token's Avatar
1994 SW2
"DOOR SILL PLATE"
Aha, I knew it was called something.
Well, That just freeking sucks. I'm going to get started on this project today.
Hopefully, I can fix it.
I had a similar problem on a 1992 Cavalier. I rebuilt the rocker panels on both sides, using 16 - 18 guage steel (I forget). Supplies didn't cost that much. A 4X3 piece of stainless steel cost about $20.00. Alot cheaper than your local hardware store, mostly because I went to a supplier. I bent the steel by borrowing my buddies aluminum siding bender. Then I put a pop rivet in just about every inch around the perimeter of the new rocker panel. Afterwards I went with some bondo, and put it where the rivets were placed, sanded it smooth, primed it-(one-coat), Painted it-(3-coats), Clear coat-(3-coats). I thought it would very difficult to match and blend the paint, so I ended up painting them black.
I'm not a expert when it comes to body work. Plus I never attempted anything like this before. But I bought that car with 71000 on it off the state of Ohio for $1100 dollars. I put 35000 miles on it and only put about $400 into it. Most of it went into making the car look nice. But, I ended up selling it for $1700.
I knew I wouldn't get what wanted for it if I didn't fix the rocker panels. So for about $75 and 8 hours of labor which stretched in 2 weekends, I did it. I gave myself a that-a-boy.
I'm still in search of anybody who has encountered this problem and how did they solve it for their Saturn on the "Door Sill Plate".
Old 09-04-2005, 09:45 AM   #4
dcp
dcp is on a distinguished road
dcp's Avatar
All you can do is slow rust down.sounds like you are going about it the right way.GOOD LUCK!
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 09-04-2005, 11:36 AM   #5
lilcraigford
lilcraigford is on a distinguished road
Find a body shop that'll do it. My Dad had his passenger side replaced, and I know I need to have both of my rocker panels replaced. Unfortunatly it is kind of expensive, it's like $300 per side where we take them. The work is premium though, they do a beautiful job and it usually looks factory fresh... IMO have it done right.
Add to lilcraigford's Reputation
Rate the quality of this post and help lilcraigford reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lilcraigford is offline   Reply With Quote
Old 09-04-2005, 12:15 PM   #6
cazzylee
cazzylee is on a distinguished road
cazzylee's Avatar
I had those replaced for about 150$ per side, but the rust wasn't TOO bad so I got off easy.
In short, yes they all rust there.
Madness takes it's toll: Please have exact change.
SES light + unplugged sensor = testicle ownage.
Add to cazzylee's Reputation
Rate the quality of this post and help cazzylee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cazzylee is offline   Reply With Quote
Old 09-04-2005, 12:26 PM   #7
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Is the door sill plate the same thing as the inner rocker panel? The inner rocker is available from saturn for under $50.00.
Add to peppermrj's Reputation
Rate the quality of this post and help peppermrj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peppermrj is offline   Reply With Quote
Old 09-04-2005, 07:32 PM   #8
93 saturn sl2
93 saturn sl2 is on a distinguished road
1993 SL2
my car is rusted on both of the back sides too. Me and my grandpa are going to grind the rusted are and replace it with some aluminum.
93 sl2
mp3 swapped
bolt on's
black interior
Add to 93 saturn sl2's Reputation
Rate the quality of this post and help 93 saturn sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93 saturn sl2 is offline   Reply With Quote
Old 09-04-2005, 09:12 PM   #9
eRic 02sc2
eRic 02sc2's Avatar
is this something that only happens on the sedans and wagons? since they have four doors with the b-pillar in the middle.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-04-2005, 10:34 PM   #10
UH2L
UH2L is on a distinguished road
It might be the seals. A crystal type material leaches through and abraids metal leading to rust where the seal rubs. Check with your retailer for a service bulletin. It might be a different issue though.
UH2L
Have a visit to my blog, "Things I've Noticed" at...
www.UH2L.com
Add to UH2L's Reputation
Rate the quality of this post and help UH2L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
UH2L is offline   Reply With Quote
Old 09-05-2005, 10:54 AM   #11
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Mine also has rust, I used some POR 15 to cover up the rust.
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 09-05-2005, 12:43 PM   #12
jimpennjr
jimpennjr will become famous soon enough
2008 VUE 3.6L
My door sill plates on both sides at the rear doors both were rusted and flaking like crazy. I wire brushed the area and then bondo'd it then primed and painted the area black. It did the job for now.
jimpennjr
'96 SL1 5-speed--Traded in for an '09 HHR
2008 Vue XR V6 Trade in the '04 Vue for it.
Add to jimpennjr's Reputation
Rate the quality of this post and help jimpennjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimpennjr is offline   Reply With Quote
Old 09-05-2005, 02:37 PM   #13
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Mine were both really bad. I spent about a day just grinding rust away. Once it was all pretty much clean (leaving a fairly large hole) I sprayed over it with some rust converter and then primer and several coats of paint. It seems to have subsided for the most part, though I expect I may need to have them cut out and replaced if I intend to keep this car.
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline   Reply With Quote
Old 09-05-2005, 07:01 PM   #14
peppermrj
peppermrj's Avatar
Question Re: Do all older Saturns "RUST" under that plastic "THINGY" that sits under the door????
Apple,
Somewhat off topic but what brand rust converter and your opinion of its effectiveness?
Old 09-05-2005, 08:41 PM   #15
twosaturns
twosaturns's Avatar
don't our cars have a 10 year rust through warranty?
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline   Reply With Quote
Old 09-06-2005, 06:02 AM   #16
Leadsled Coupe
Leadsled Coupe is on a distinguished road
1993 SL2
Mine has rust there too. POR15 on the way!
'93 Automatic SL2 with 150k+ miles-
'93 AOD Mustang LX- 5.4L fuel hog-Gas mileage? "Don't ask- Don't tell!" This one is tuned for power.
Add to Leadsled Coupe's Reputation
Rate the quality of this post and help Leadsled Coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leadsled Coupe is offline   Reply With Quote
Old 09-06-2005, 06:49 AM   #17
Applefool
Applefool's Avatar
2006 ION Red Line
Originally Posted by peppermrj
Apple,
Not sure what it was called but the slogan was "convert rust to black primer". If sprayed onto a non rusted surface it goes on and looks clear. If sprayed onto rust it does in fact turn it to black.
Old 09-06-2005, 07:45 AM   #18
S3aturnR
S3aturnR's Avatar
1999 SL1
mine are rusted, too...
s3aturnr
Add to S3aturnR's Reputation
Old 09-06-2005, 08:57 AM   #19
billb300
billb300 is on a distinguished road
My 2001 spent it's first 2(?) years in West Virginia and has been living in South Carolina since but im starting to notice some rust right where the seals for the suicide door touch the door sill plate....been meaning to fix that b/c it bothers me.
Add to billb300's Reputation
Rate the quality of this post and help billb300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
billb300 is offline   Reply With Quote
Old 09-06-2005, 10:55 AM   #20
M.Nguyen
M.Nguyen's Avatar
1993 SL2
I've never owned a car that's had any rust on it...
Hahahaha...I love California.
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota Charlie General Saturn Discussion 20 02-25-2011 04:11 PM
"chrome" plastic door molding? 20VUE06 Vue General 1 05-01-2009 04:09 PM
"New" SL1 2002 "Potential" owner with Questions MBman S-Series General 19 03-01-2006 12:43 AM
Im starting to think "Saturn" will be switched to "OPEL" by 2010! johnsocal General Saturn Discussion 12 10-28-2003 02:05 AM
"L" series owners: Seeking the "LOW" life? Abe95SC2 Mods and Performance 8 02-04-2002 10:19 AM
