Old 08-28-2005, 02:15 AM   #1
wolfman
wolfman's Avatar
Default P301 codes made easy?
I still can't get anything to post in the "How To" section (Oh Charrrrrlieeee!) So I'll drop this in here. I have seen a recent upswing in the number of folks getting SES lights that reveal the P301 code when scanned. (Misfire) I will toss this out as a quick "general" troubleshooting guide with TWO senarios:
Senario #1.
Upon initial start up, cars runs/idles very rough, though usually sometimes only briefly, and SES light comes on. (Code P301 generated)
In this senario, odds are that a problem exists in the IGNITION system somewhere. Things to check:
1. Spark plugs (non platinum, correct gap)
2. Spark plug wires (cross firing due to age and moisture or oil flooded plug wells in the DOHC engines only)
3. Coil pack towers (corroded)
4. Coil pack to engine bolts corroded at loop connectors
Senario #2.
Car starts and idles ok, cruises ok, but stumbles, jerks and or "misses" during moderate acceleration or hill climbing, and SES light comes on. (Code P301 generated)
In this senario, odds are that a problem lies in the FUEL or EGR system despite what the code suggests. A fault in one of those other two systems may be leaning out the air fuel mixture briefly and causing the misfire. Things to check:
1. Fuel injectors clogged
2. EGR valve sticking
3. MAP sensor vacuum ports clogged/leaking or poor electrical connection
4. Faulty TPS or TPS wiring/connector
5. Items 1-4 in senario 1 (just to be sure)
Add to wolfman's Reputation
Old 08-28-2005, 10:00 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: P301 codes made easy?
you mean p0301? (four digit number) and don't forget p0300, p0302, p0303, p0304.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 08-29-2005, 09:08 AM   #3
Luke
Luke's Avatar
> Fm e Ric <
> you mean p0301? (four digit number) and don't forget p0300, p0302, p0303, p0304. <
Simply another example why we should not listen to Wolf's advice, guidance, & assistance. Can't get anything right.
Should we talk about my manual radiator fan swith ????? Wolf: Do you like your morning toast with the crust cut off Regular butter or salted butter
Of course, I would be the first person to omit a zero in front of a number, but then that's me, and perceiving that a zero in front doesn't mean anything.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 08-29-2005, 08:39 PM   #4
eRic 02sc2
eRic 02sc2's Avatar
You're obviously not a computer nerd or a Dukes of Hazzard fan... "01" is not the same as "1"
eRic 02sc2
Old 08-29-2005, 08:44 PM   #5
wolfman
wolfman's Avatar
Not to worry, if I can ever get stuff to post in the "How To" section again, I'll fix this tragic and horrible error then.
Old 08-30-2005, 08:48 AM   #6
Luke
Luke's Avatar
Default Tragic and horrible error
> Fm Wolf <
> I'll fix this tragic and horrible error <
Ok, then I'm withdrawing my "toast" offer... ..........and see that this does not happen again.
For I simply cannot work with "flawed" people.
Water Pump Replacement made Easy Chad S-Series Tech 5 12-28-2006 10:49 AM
Got my codes read.. the autozone rep was surprised to see soo many codes... oh no bskicrash1 S-Series General 2 11-12-2006 01:10 PM
Mexican-made VUE and Europian-made Evoke/Astra - would you buy them? robertburns3 Astra General 73 06-04-2006 09:07 PM
Is it easy to clear fault codes? 91SL2/96SL2 S-Series Tech 13 05-13-2003 08:03 PM
Avatars Made Easy Charlie Community Center 0 11-19-2002 06:39 AM
