Old 08-23-2005, 09:47 PM   #1
johns811
johns811 is on a distinguished road
Default What size socket for oil filter cap?
Hi, I have to purchase a socket for the oil filter cap. What size works best?
Thanks
Add to johns811's Reputation
Rate the quality of this post and help johns811 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johns811 is offline   Reply With Quote
Old 08-24-2005, 05:49 AM   #2
jmettee
jmettee is on a distinguished road
jmettee's Avatar
2003 ION-3 Quad Coupe
Default Re: What size socket for oil filter cap?
I believe the owner's manual says a 32mm is the correct size. I use a 1-1/4" combination wrench, which is slightly loose, but works well enough.
J
2003 SATURN Ion QC3m
"Giggity Giggity Goo" -Quagmire
Add to jmettee's Reputation
Rate the quality of this post and help jmettee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jmettee is offline   Reply With Quote
Old 08-24-2005, 06:57 AM   #3
J3ION3
J3ION3 is on a distinguished road
2004 ION-3 Sedan
2007 VUE 2.2L
A 1-1/4" 6-point socket works very well for me. Using a open end wrench or a 12-point socket has a good possibility of stripping the nut portion of the plastic cover.
Add to J3ION3's Reputation
Rate the quality of this post and help J3ION3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
J3ION3 is offline   Reply With Quote
Old 08-25-2005, 12:12 PM   #4
Powerben5000
Powerben5000 is on a distinguished road
Powerben5000's Avatar
2003 ION-2 Sedan
Saturns are supposed to be metric so if you have a shallow 32mm that would be preferable to using american sockets.. I didn't have a socket shallow enough to get at it so I just used an adjustable strap wrench to do it.
"It was never easy for me...I was born a poor black child..." - Steve Martin from _The Jerk_
Add to Powerben5000's Reputation
Rate the quality of this post and help Powerben5000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Powerben5000 is offline   Reply With Quote
Old 08-25-2005, 04:07 PM   #5
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
You'll never find a 1 1/4" socket shallow enough unless you machine one. Try a search for filter caps in the L-Series forums. Somebody there mentioned some company that carried one specifically for an Ecotec. (all ecotecs are a bit different in that area)
In the meantime, do what I do.
Use an adjustable wrench to get it off. Put the cap back on hand tight. Tighten only a 1/8 turn at most. That's more than enough to keep it from leaking. It has a decent o-ring that compresses fairly easy. Mine hasn't leaked in over 15 changes.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 08-25-2005, 05:41 PM   #6
midlifecrisis
midlifecrisis is on a distinguished road
midlifecrisis's Avatar
I've changed the oil every time on my '03 QC, buy the filters at Saturn Riverside, CA for $4.95 buy the dozen and purchased an AutoZone brand breaker bar 1/2" drive and a 1 1/4" socket for about $21.00. works well, you losen the cap till just before the soket hits the manifold then remove and losen the rest of the way by hand.
Add to midlifecrisis's Reputation
Rate the quality of this post and help midlifecrisis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
midlifecrisis is offline   Reply With Quote
Old 08-25-2005, 10:05 PM   #7
DSLaBuda
DSLaBuda is on a distinguished road
DSLaBuda's Avatar
2005 ION-1 Sedan
1997 SL1
actually i bought one at pep boys for about $4 before discount. 'performance tool' brand (generic), there is also a stanley brand in that size.
i use that socket, a flex joint, and a six inch extension with my rachet and never had a problem.
[edit]
if they're really hard to find elsewhere, this could be a money maker for me.
[/edit]
-DS
"I'm a product, of my environment
So don't blame me, I just work here"
But I want to **** it all up!!"
Offspring - Americana
Add to DSLaBuda's Reputation
Rate the quality of this post and help DSLaBuda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DSLaBuda is offline   Reply With Quote
No Parts stores carry the oil filter socket YourMainParadox Vue General 20 10-05-2008 10:59 AM
Socket for Ecotec oil filter cap David 93 SL2m General Saturn Discussion 3 09-14-2007 12:15 PM
Second Oil filter Cap playboyroy L-Series General 1 04-29-2004 02:59 PM
L-200 2.2 oil filter socket drohlf1 Miscellaneous Tech 8 01-24-2003 09:23 PM
Oil cap size and periodic maintenance abkaiser S-Series Tech 3 03-09-2000 01:41 PM
