Old 08-04-2005, 07:57 PM   #1
lentinman
lentinman is on a distinguished road
Default 95 Saturn SL1 Cylinder Compression
Can anyone tell me what the compression setting should be? I guess I'm wondering what they would have been new and what they would expect to be after 10 years and what is horrible. Thanks.
Len
Add to lentinman's Reputation
Rate the quality of this post and help lentinman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lentinman is offline   Reply With Quote
Old 08-04-2005, 08:52 PM   #2
stanleyr
stanleyr is on a distinguished road
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
Default Re: 95 Saturn SL1 Cylinder Compression
185 - 205 PSI is normal spec for a warm engine . It should build up quickly and evenly. Below 180 PSI is getting a bit tired .
Add to stanleyr's Reputation
Rate the quality of this post and help stanleyr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stanleyr is offline   Reply With Quote
Old 08-05-2005, 04:55 PM   #3
lentinman
Stanley:
Thanks for the reply. You are saying 185-205. I called the local Saturn service department. The guy I talked to put me on hold to find out. I don't know whether he looked up the specs or asked someone else. But, he stated 160-170. I asked him what they would have been new and he said 170 or so.
That is a huge difference. I wonder if it could be the SL1 issue. He asked me what model I had and I said SL1 and he said "Ok, so it is a single" - clearly implying that it mattered. Did you consider that?
Len
Old 08-06-2005, 02:36 AM   #4
stanleyr
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
Two things that could be different:
  1. The 95 may have had some changes made that differ from the 92 SOHC spec
  2. The service manual I own for the 91-92 may be wrong
I've included some of the literature from the service manual.
Doing further research and if we can trust the rest of the information from the manual, the compression ratio for the a SOHC is 9.3:1 and a DOHC 9.5:1. The bore and stroke for both engines is the same, 3.2" x 3.5". The SOHC cam lobe lift rise is 0.2531"-0.2556". The DOHC cam lobe lift rise is much higher at 0.35" (and some change) for intake and 0.34" (and some change) for exhaust.
So...Yes, I would have to conclude the compression would be lower on a SOHC considering the lower compression ratio with the same bore and stroke, fewer valves and the less aggressive cam. Perhaps some others may have a '95 SOHC spec sheet that will clear it up?
Go with what Saturn's mechanic says.
Old 08-06-2005, 04:23 AM   #5
Jeremy97sc
Jeremy97sc is on a distinguished road
Jeremy97sc's Avatar
Even a cold test should reveal above 180psi.
Cold compression on my engine WAS 210 all across.
But its 210 210 170 0 now Lol.
Add to Jeremy97sc's Reputation
Rate the quality of this post and help Jeremy97sc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeremy97sc is offline   Reply With Quote
Old 08-06-2005, 03:50 PM   #6
lentinman
Jeremy & Stanley: Thanks.
He also said that the differential between the cylinders should vary no more than 10. Your 210, 210, 170, 0 looks to have a higher differential than that. I suspect you have a problem.... just kidding.
Len
'95 SG4 1.9L - No Compression in a Cylinder LanmanTheFirst S-Series Tech 12 05-25-2014 11:54 AM
Low Compression on Cylinder # 3 acworthpatrick S-Series Tech 5 01-22-2009 03:50 PM
No compression in 1 cylinder bruce633 S-Series General 4 03-19-2007 02:13 PM
Dead #1 Cylinder, no Compression??? cabech984 S-Series Tech 15 12-05-2006 03:47 AM
1 cylinder 20 lbs. low on compression..? topCONsurveyor S-Series General 5 04-15-2006 11:53 PM
