#1 | ||||
![]() Join Date: Jul 2005
Hey guys my non abs brakes are TERRIBLE... the pedal is low, mushy, and hits the floor. i can make a fairly hard stop, but cant skid as i think i should be able to when slamming the pedal. My brake fluid is very black... could it be bad fluid, and is there an easy way i can check? If it is bad then ill have them bled, but i dont want to have a mechanic do that for nothing. My fluid level is and has been perfect for years, so theres no way its a leak.
... - 1993 SL1 Auto 100,000+ miles
#2 | ||||
![]() ![]() Join Date: Feb 2000
Location: Closed course. professional driver. do not attempt.
have you ever had the brake fluid bleed or flushed and refilled in those 100,000 miles? brake fluid should be a honey golden color (or blue if it's ate super blue) not black. get two or three 12 oz bottles of fresh brake fluid and pump out all the black stuff.
... eRic 02sc2 fka eRic 96sc2 Detroit SCCA Solo 2001,2002 1st DSP Waterford Hills 2007 Fun Run 1st 6a Detroit SCCA 2008 Triathalon 1st PF Detroit SCCA Solo 2009 2nd ST Crutchfield: pkeqe-6j8e3-d2qqe
#3 | ||||
id do it myself, but i havent heard good things about bleeding brakes on these forums! Is there any wolfman proceedure for that? or could you outline one for me? do i have to take the wheels off to get to the bleeders? thanks!
- and no they have NEVER been bled as far as i know ... - 1993 SL1 Auto 100,000+ miles
#4 | ||||
by the way my front pads and rotors are new, and the brakes were mushy before and after
#5 | ||||
here's an article on bleeding the brakes from SPS and teamscR
http://www.teamscr.com/brakes.html ... eRic 02sc2 fka eRic 96sc2 Detroit SCCA Solo 2001,2002 1st DSP Waterford Hills 2007 Fun Run 1st 6a Detroit SCCA 2008 Triathalon 1st PF Detroit SCCA Solo 2009 2nd ST Crutchfield: pkeqe-6j8e3-d2qqe
#6 | |||||
![]() Join Date: Jan 2005
#7 | ||||
It doesent slowly sink to the floor. However, sometimes, it helps to pump the brakes, but not really. theyre usually very regular.
#8 | ||||
I know this is a real long shot, but is there any possibility of bleeding the brakes on an sl1 without removing the wheels / jacking up the vehicle? Otherwise i think im going to take it to a mechanic to have it done. thanks.
- just a better discription: my pedal is low to begin with, and once you begin to brake you have to keep going lower and lower, because the brakes engage slowwly as you go down, not sharply. (what i call mushy!) theyll go far enough down that they hit the floor. at that point you're braking pretty hard, but still hitting the floor! ... - 1993 SL1 Auto 100,000+ miles
#9 | |||||
#10 | |||||
can you "see" the bleed screws on yours? if not, the wheels must be removed. ... eRic 02sc2 fka eRic 96sc2 Detroit SCCA Solo 2001,2002 1st DSP Waterford Hills 2007 Fun Run 1st 6a Detroit SCCA 2008 Triathalon 1st PF Detroit SCCA Solo 2009 2nd ST Crutchfield: pkeqe-6j8e3-d2qqe
#11 | ||||
Sounds like you have a bad master cylinder. Or a leak in the line. But if there is still fluid and it's black, then I would suspect a bad master cylinder.
--Tom ... 2004 VUE 2003 Mazda Protégé ES 1992 SC - former autox/track car (sold)
#12 | ||||
nah i cant see anything through my wheels. to the mechanic she goes! ill let you guys know how it turns out. thanks!
#13 | |||||
#14 | ||||
![]() Join Date: May 2004
I would start with the bleeding, since to me that is what it sounds like. Also though couldn't a weak flex hose cause the same problem?
#15 | |||||
i recently found out that i had a bad master cylinder, but the symptoms weren't what i would call 'normal' for that type of problem. the pedal just had a REALLY long throw to it, no sinking, no fading. once you were into the brakes, it braked normally. this went on for about 2 years (i don't drive the car all the time). finally, after an autox on a road-course (waterford hills), i had them checked by a professional. $204.00 fixed my problem (i don't do master cylinders). s3aturnr ... "reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
#16 | ||||
I guess this means the issue could be my master cylinder, could be my fluid... how to find out? I guess i should change the fluid anyway, itll probably help. Does anyone else have any insight into this? How to check fluid or master cylinder to determine exactly what is wrong?
#17 | ||||
My 2 cent. Have the rear brakes manually adjusted up tight. Then bleed the brakes until you get clean fluid at all 4 wheels.
Brake fluid absorbs water (dot 3). Moisture from the air and condensation. Under hard use brake temps can get high enough to boil the water out of the fluid. Now there is air in the system even tho there are no leaks. On old style mastercylinders with the large metal covers you could pump up the brakes. hold pressure on the pedal, remove the cover, slide your foot off the pedal and let it fly up. If there is air in the system you would actually see a stream of brake fluid shoot up from the mastercylinder. Careful of the paint! I imagine you could use this same check on the satty. Good luck and let us know. ![]()
#18 | ||||
...remove large metal cover? huh? it sounds like a good idea, if i new what you were talking about (yea im a noob) please elaborate for me! Thanks!
#19 | ||||
peppermj brings up yet another point, my mechanic has some kind of issue with the saturn rear drums. he says he cant get to the adjuster because its in a hard to reach area and the hole doesent line up well. what should i tell him? (i know, get a new mechanic. hes been doing work for us for a long time and we trust him so i dont think im going to do that)
#20 | ||||
The adjuster doesn't line up with the hole and is adjusted by using the emergency brake I was told. I know when we took the drums off the boys 97 SC1 the adjusters weren't even close to the access hole.
| Thread Tools | |
| Display Modes | |
| brake pedal goes almost to floor before brakes engage? | sfitts | S-Series Tech | 29 | 01-03-2008 06:35 AM |
| SL2 brakes (pedal goes to floor, etc) | PlasticCarsRock | S-Series General | 45 | 01-12-2006 08:35 PM |
| brake pedal hits the floor | murdock | S-Series Tech | 2 | 09-22-2005 06:06 AM |
| brake pedal hits floor | dwp | S-Series Tech | 9 | 01-06-2004 10:57 PM |
| Mushy brake pedal... | Scyan | Miscellaneous Tech | 22 | 08-23-2003 09:31 PM |
