Old 07-25-2005, 06:06 AM   #1
SL1_Owner
SL1_Owner is on a distinguished road
1998 SL1
Default Manual Transmission Oil
What kind of transmission oil do I need to use in my 1998 Saturn SL with 5 speed Manual. Went to AutoZone and they said AF3 oil, but could not find any in the store ???
A second question, how do I know if the car I have is an SL or SL1 os SL2, what differentiates the three ?
Add to SL1_Owner's Reputation
Rate the quality of this post and help SL1_Owner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL1_Owner is offline   Reply With Quote
Old 07-25-2005, 07:00 AM   #2
S3aturnR
S3aturnR's Avatar
1999 SL1
Default Re: Manual Transmission Oil
i would get that 'oil' right from the dealership. they have plenty. saturn recommends that you use ONLY their fluid for the tranny anyway. not exactly sure of the differences between an sl and sl1, but the main differences between an sl1 and sl2 is the sl2 has a twin cam engine (sl1 has sohc), the sl2 has a rear sway bar, painted bumpers (in most cases), 15" wheels (as opposed to 14"), higher gearing in the tranny (sl1 is lower for better fuel economy) and seats with an adjustable headrest. this is not a complete list, tho.
now that i think of it, maybe the difference between the sl and sl1 is power steering? not for sure, tho...
s3aturnr
Add to S3aturnR's Reputation
Old 07-25-2005, 08:29 AM   #3
98SL
98SL is on a distinguished road
1998 SL
It says in the manual that you can also use Dexron III in the Saturn manual trans--most all auto parts stores should have that.
Add to 98SL's Reputation
Rate the quality of this post and help 98SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98SL is offline   Reply With Quote
Old 07-25-2005, 08:35 AM   #4
irish56
irish56 is just really niceirish56 is just really niceirish56 is just really niceirish56 is just really niceirish56 is just really nice
irish56's Avatar
1999 SC1
Any Dexron-III automatic transmission fluid should be fine. I use Mobil 1 synthetic ATF in my SL2 5-speed. You'll pay top dollar if you buy ATF at the dealership, but since you only need 2.5 quarts (IIRC), it won't break you.
As for telling which model you have, gently release the clutch and get the car rolling at 5 mph or so, then floor the accelerator in first gear. If the front tires chirp and the motor zings to 6500 rpm while throwing you back in the seat, you've got an SL2. If the tires don't chirp and the car gently gathers speed until the rev limiter cuts in at 5500, you've got an SL/SL1.
Add to irish56's Reputation
Rate the quality of this post and help irish56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
irish56 is offline   Reply With Quote
Old 07-25-2005, 08:37 AM   #5
Monroe44
Monroe44 is on a distinguished road
The transmission fluid is ATF (Automatic Transmission Fluid), and yes, you are using it in your manual transmission. The grade is as said above, Dextron III.
Add to Monroe44's Reputation
Rate the quality of this post and help Monroe44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Monroe44 is offline   Reply With Quote
Old 07-25-2005, 08:45 AM   #6
Unique Concepts
Unique Concepts is on a distinguished road
Unique Concepts's Avatar
2001 SL2
If you really want to know the difference between SL/SL1/SL2, besides the obvious SOHC, DOHC, simply look at the decklid reflector. If the decklid has a reflector it is a SL2, if it does not, then it is either an SL or SL1.
For ATF i would highly recommend the Saturn fluid part # 21005856, but if you are to go aftermarket use Redline D4 ATF.
Add to Unique Concepts's Reputation
Rate the quality of this post and help Unique Concepts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Unique Concepts is offline   Reply With Quote
Old 07-25-2005, 12:43 PM   #7
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1991 SL2
Can highly recommend the Mobil 1 ATF for a refill. Works great in cold
weather (goes into gear much easier), assume it does the same when
hot.
Get yourself a funnel with a loooong flexible neck on it. The one I have is about 12-16" long, really makes adding new fluid much easier.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 07-25-2005, 01:22 PM   #8
Longsnowsm
Longsnowsm is on a distinguished road
Is it just ATF for all the S series manual transmissions? I tried to lookup the tranny fluid on one of the sites and it told me that the tranny fluid should be bought from the dealer... Pretty strange. Thoughts?
How hard is it to drain that fluid and replace it? Is it just a drain plug, or is is a pan sorta thing like an auto tranny has?
Longsnowsm
Add to Longsnowsm's Reputation
Rate the quality of this post and help Longsnowsm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Longsnowsm is offline   Reply With Quote
Old 07-25-2005, 01:33 PM   #9
98SL
1998 SL
Longsnowsm
There's a drain plug--it's kinda to hard to get at without putting the front on jackstands but you can do it. Just drain the oil into your normal oil collector and take it to your local auto parts store just like for engine case oil. Dexron III is all you need--don't buy it at the dealer; get it at you local Kragen or NAPA or whatever. Don't buy ANYTHING at the dealer that you don't have to. The dealer would prefer that your car breaks so you'll buy a new one from them. *******s.
Old 07-25-2005, 05:03 PM   #10
ringed1
ringed1 is on a distinguished road
1994 SC2
hot.
I add a strong second to this. I use Mobil 1, and it leads to noticably smoother shifting in the manual trans.
Add to ringed1's Reputation
Rate the quality of this post and help ringed1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ringed1 is offline   Reply With Quote
Old 07-25-2005, 05:21 PM   #11
Unique Concepts
2001 SL2
There is nothing special about the Saturn Fluid, use what you would like. Saturn does not prefer your car to break down, they prefer that you buy Saturn parts. Mobil 1 is also an excellent choice
Manual Transmission Oil Change shogun Ion Tech 4 01-04-2009 11:35 AM
Will a 1997 saturn sc1 manual transmission work in my 1998 manual sl2? CARLiTO_ S-Series Tech 1 08-19-2008 07:52 PM
manual transmission oil check and change ghost9804 S-Series Tech 6 06-02-2006 07:18 PM
Will putting gear oil in Manual Transmission destroy it? Donggie S-Series Tech 8 10-07-2002 10:01 AM
Manual Transmission Oil change intervals L100 Miscellaneous Tech 4 04-18-2001 11:56 PM
