Old 07-04-2005, 03:43 AM   #1
tgferg67global
tgferg67global will become famous soon enoughtgferg67global will become famous soon enough
tgferg67global's Avatar
Default 97 SC1 partial throttle surging/power loss
I have some acceleration problems I can't pinpoint. No SES light.
Under partial throttle, the car slightly misses when cold and and gets much worse when warmed up. When warmed up, under partial throttle, the car loses power and surges/bucks like horsepower is cutting in and out.
Idle, cruising and full throttle are normal.
New items
*Plugs(NGK)
*Wires(Double-Silicone-Autozone)
*Coil Packs(Wells)
*O2 sensor front(Bosch Universal)
*Fuel Filter
*Fuel pump replaced 35,000 miles ago at dealer.
Things I have tried
*Fuel injector cleaner
*Blocked off EGR and problem persisted.
*ECTS is brass already but not sure how old it is.
*Cleaned/Removed throttle body and IAC
*Cleaned sludge from MAP sensor orfice.
*Inspected/Cleaned all connectors and grounds.
*Seafoam combustion chamber cleaner.
Where should I go from here?
Throttle position sensor?
DIS module?
Map sensor?
ECTS (even though mine is brass already)?
Fuel pressure regulator?
Alternator(doesn't seem likely since problem gets worse when warmed up)?
Add to tgferg67global's Reputation
Rate the quality of this post and help tgferg67global reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgferg67global is offline   Reply With Quote
Old 07-04-2005, 04:36 AM   #2
tgferg67global
Default Re: 97 SC1 partial throttle surging/power loss
I forgot to mention the car is an automatic.
After the car is warmed up the loss of power under partial throttle is so bad that I have to press the gas pedal 1/3 to 1/2 of the way down to accelerate normally compare to just barely touching the gas pedal to get the same power when the car is cold. The whole time this is happening the car surges with more and less power.
Could it be a weird transmission problem such as the torque convertor cutting in and out and/or wrong gear selection masking itself as an engine problem?
Old 07-04-2005, 08:37 AM   #3
Luke
Luke's Avatar
Default Throttle Position Sensor
I'd take off and replace the TPS, for years ago, when I replaced my unit, I actually opened up the old unit and found that there was an area on the arch swing, where there was a loss of contact. This may be the case with your unit.
It does wear down.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 07-04-2005, 02:50 PM   #4
tgferg67global
Default Re: Throttle Position Sensor
It does wear down.
Wouldn't a bad contact show up when revving up the engine out of gear?
When I do this no bad spot shows up. The drivability problem seems to occur under load. Do you know if all the TPS is just a potentiometer(like a volume knob on a radio) or is there more to it than that and it could fail another way under load that wouldn't show up when revving the engine up out of gear?
Old 07-05-2005, 08:54 AM   #5
Luke
Luke's Avatar
> Global <
Very good point; The "load" issue has me stomped.
Old 07-05-2005, 09:14 AM   #6
tgferg67global
> Global <
Looking through some posts didn't you have a crank position sensor that was causing drivability problems for you?
I just bought a multimeter and will be testing my sensors. Funny feeling that everything will be within range
Old 07-05-2005, 09:28 AM   #7
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Did you clean up your coilpack bolts? My car used to hesitate and kind of jerk a little while driving at partial throttle. It was unnoticeable while revving in neutral. After cleaning the bolts off w/ my bench grinder brush it was VERY smooth.
That may be your problem...
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline   Reply With Quote
Old 07-05-2005, 09:45 AM   #8
Luke
Luke's Avatar
> Global <
> didn't you have a crank position sensor that was causing drivability problems for you? <
Yes, and now I have a back-up unit, hoever, when that fails, the engine will not run at all. It will simply shut down. The engine will turn over when you attempt to start it, but will not start. That would not be your issue.
> SOHC <
> Did you clean up your coilpack bolts? <
Nice alert -- didn't even think of that. We do continue to learn...
Old 07-05-2005, 12:34 PM   #9
tgferg67global
Yes I dipped them in muriatic acid along with other rusty ground fastners.
They are completely silver.
Old 07-05-2005, 01:40 PM   #10
sps SOHC
sps SOHC's Avatar
Tps ??
Old 07-06-2005, 01:27 AM   #11
sierrap615
sierrap615's Avatar
a bad TPS can be tested with a ohmmeter/multimeter.
i can see a bad TPS only showing up under load, remember it is consided the "driver demand" sensor. in park/neutral you aren't "demanding" any power, you have no load, the PCM is only injecting enought fuel to match the airflow and RPM, it is not enriching the A/F for added power, as it would if you were actually accerating.
sierrap615 is offline   Reply With Quote
Old 07-07-2005, 06:38 PM   #12
tgferg67global
Well I swapped out the TPS sensor with one from a junk yard and the problem still exists. The TPS sensor was fine
Old 07-07-2005, 08:27 PM   #13
sps SOHC
sps SOHC's Avatar
reset your computer by unplugging the negative battery cable for a few minutes. (get your radio security codes before you do this)
You usually need to do this whenever you change a sensor out (like ECTS) if you didn't it could just be the problem. Also try cleaning the ports that lead to your EGR as well as the EGR just to be sure. Cuz I really can't think of much else.
Old 03-28-2010, 01:48 PM   #14
tgferg67global
I never posted the resolution to this problem.
It had something to do with the map sensor. I replaced it and also noticed the area behind the sensor in the intake was packed full of oil with a "grease like" consistancy. I took off the vacuum hose underneath the sensor and sprayed carburator cleaner in the map sensor hole in the intake. Gobs of partially solidified oil came out the vaccum hose outlet on the bottom of the intake. So between the new map sensor and cleaning out the "cavity" caked with oil behind the sensor, the problem was resolved.
04 3.5L surging under constant throttle mmckown Vue Tech 15 08-18-2008 12:34 PM
Surging and power loss on a SL1 Mera S-Series General 1 05-18-2008 10:24 PM
Power Loss @ mid throttle richpor S-Series Tech 13 08-02-2006 05:50 AM
weakness/loss power at upper end (higher throttle) MacExperts S-Series General 6 12-17-2005 03:18 AM
persistant surging at specific throttle position jacobarber S-Series General 7 04-20-2005 10:58 AM
