Old 07-01-2005, 06:16 AM   #1
horndog
horndog is on a distinguished road
Default Timing chain installation 1.9 SOHC (1995)
Which way are the camshaft and the crankshaft timing marks suppose to lined up? I have found nothing on this. All I know is the crankshaft pointed straight up and is the camshaft sprocket the same?
Add to horndog's Reputation
Rate the quality of this post and help horndog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
horndog is offline   Reply With Quote
Old 07-01-2005, 08:55 AM   #2
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
Default Re: Timing chain installation 1.9 SOHC (1995)
camshaft has a dowel hole for alignment. i forget what size drill bit but u like the sprocket up with that hold on the head
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 07-01-2005, 10:05 AM   #3
Low Saturn
Low Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to all
Low Saturn's Avatar
2008 AURA XE
Are you doing this without a manual? Because one would be handy. Even the crappy Haynes and/or Chiltons should give this information.
Old 07-03-2005, 07:59 AM   #4
horndog
if the dowel goes into the camshaft where the key is, then I have no clue.
I had both crank and cam at TDC and fired it up and ran like crap, dunno what is wrong.
I did get a chilton's and will redo it by their instructions. I can do the timing chain in about 2 hours now..
Old 07-03-2005, 10:46 AM   #5
twosaturns
twosaturns's Avatar
on a DOHC, it's real easy- line up the dowel marks, and there are sliver links in the chain that line up at the bottom of the crank and top of each cam sprocket. of course, make sure you had real TDC, not 180 out.
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline   Reply With Quote
Old 07-06-2005, 07:10 AM   #6
horndog
well here is the scoop..
I bought this car from a customer for $50. Took the head off and had it sent in to be inspected. The machine shop said, "all the intake valves are bent." Ok, fix it. They fixed it. I put it all together and the timing chain, and fired it up. It ran for a minute then clunk, clunk, BAM! I said, ooh that doesn't sound good. took the valve cover off, and found the camshaft sprocket not on all the way(did I forget to tighten it?) and the timing was out 180 degrees.
Ok, fixed that..
got the timing right according to saturn and chilton's. fired it up and ran like crap again, but ok. check the compression, cyl1= 0 psi, cyl2= 190psi, cyl3=200psi, cyl4=0 psi...
hmm... could the bottom end took a digger? dunno. pistons bad? dunno
sprayed some oil in the 1 and 4 cylinders and rechecked the compression... hmm still 0. must be the valves. now I probably need to send the head in again to replace more valves. what do you all think?
becoming an expensive experiement, but I can do a timing chain in this car in less than 2 hours
Old 07-06-2005, 07:23 AM   #7
twosaturns
twosaturns's Avatar
you bent the valves in 1 and 4 sounds like. at least you're getting fast...
Old 07-06-2005, 07:30 AM   #8
horndog
i figured bent valves... there goes another $250
do you know if you can cut the valve seats more than once?
Old 07-06-2005, 10:29 AM   #9
bigc791
bigc791's Avatar
1994 SL1
Just get a used head. You will be better off in the end cleaning up a used head than dumping more valves into beat up guides. SOHC heads go for like $75 here you pick the car they pull it you take it home. i clean up the valves and put guides seals in them and never have any problems. Make sure when you pick the car you know why its there though. Look for something that is obviously there for reasons other than engine failure
Carmen
Old 07-07-2005, 11:16 AM   #10
justin_zink
justin_zink is on a distinguished road
1995 SL
The engine that you are working on is an interference engine. this means there is no releifs cut into the pistons for the valves. When you had the timing off it caused the pistons to hit the valves. I would check the pistons for damage as well and always doublecheck the timing after you do it and try to get a friend to check it as well before you start it. Good luck
Add to justin_zink's Reputation
Rate the quality of this post and help justin_zink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justin_zink is offline   Reply With Quote
Old 07-07-2005, 02:14 PM   #11
bigc791
bigc791's Avatar
1994 SL1
what is there to check? either your colored links are where tehy are supposed to be or they arent.
Carmen
Old 07-11-2005, 07:40 AM   #12
horndog
Carmen
i'm glad you are not doing my chain... you need to set the crank to TDC and the cam to TDC
Old 07-11-2005, 06:57 PM   #13
slaka8
slaka8 is on a distinguished road
I will buy the car!
Shoot me a price
Add to slaka8's Reputation
Rate the quality of this post and help slaka8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slaka8 is offline   Reply With Quote
Old 07-12-2005, 07:01 AM   #14
horndog
you going to pick it up in florida?
02 SOHC Timing Chain Success Report manualman S-Series Tech 11 11-30-2009 06:52 PM
Timing chain cover, sohc duganator9 S-Series Tech 2 11-12-2007 09:33 PM
Timing chain installation question jamman S-Series Tech 4 02-26-2007 10:43 AM
94 SL1 SOHC Sounded like a bad timing chain..but not? columbiawifi S-Series Tech 3 02-23-2007 06:56 PM
MP3 File of My 1995 SL2 That Dealer Say Needs Timing Chain 95StillRunning S-Series Tech 3 10-23-2006 09:19 PM
