Old 06-19-2005, 11:55 AM   #1
les1234
les1234 is on a distinguished road
Default Help with Ion Lube Job
I have a 2005 Ion.
For a lube & Oil change, the Saturn brochure describes lube as lube chassis, lube suspension and lube steering components.
My Saturn dealer is ~1 hour drive away.
I would like to lube the car myself as I used to lube my old car only at the wheel grease fittings.
Could someone instruct me where the chassis, suspension and steering lube parts are and how to lube them?
Also are other lube places (eg Canadian Tire, Jiffy Lube, Walmart, etc) competent to do a good lube job?
Add to les1234's Reputation
Rate the quality of this post and help les1234 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
les1234 is offline   Reply With Quote
Old 06-19-2005, 01:02 PM   #2
Default Re: Help with Ion Lube Job
There are no suspension or chassis lube points on the IONs or nay other Saturn for that matter. It is a hold over from the "OLD" days when cars did have the need for lube. So for the oil change all you really need to do is to change the oil and reset the oil change light. Of course a good iinspection of the underneath of the car is more than a good idea along with setting the tire pressure.
Add to ssicarman's Reputation
Old 06-24-2005, 08:03 AM   #3
les1234
Appreciate your expert advice.
I will be questioning my Saturn dealer regarding their 2005 ION maintenance brochure performing lubrication for chassis, suspension and steering components.
Old 06-25-2005, 01:06 PM   #4
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
The reason that is said is if for some reason say you do get an aftermarket joint that does require greasing it will be taken care of. Also at our dealership all door hinges are greased.
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 09-06-2005, 11:54 PM   #5
DSLaBuda
DSLaBuda is on a distinguished road
DSLaBuda's Avatar
2005 ION-1 Sedan
1997 SL1
some shops (even big name one) you have to remind them to grease yours. almost everywhere you can get a oil changer that assumes they don't need it.
my response; "you see those little nubs sticking out of the ball joints? those are zerks, grease 'em."
-DS
"I'm a product, of my environment
So don't blame me, I just work here"
But I want to **** it all up!!"
Offspring - Americana
Add to DSLaBuda's Reputation
Rate the quality of this post and help DSLaBuda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DSLaBuda is offline   Reply With Quote
Old 09-13-2005, 04:20 AM   #6
freyguy8
freyguy8 is on a distinguished road
2004 ION-2 Quad Coupe
Originally Posted by les1234
I have a 2005 Ion.
Just as a little sidenote, Ive had a bad experience with Walmarts Tire and Lube people. The people that work there are not very smart(at least it seems to me). I would recommend going to another place other than Walmart.
After a dark night, there's always a brighter day.
Add to freyguy8's Reputation
Rate the quality of this post and help freyguy8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freyguy8 is offline   Reply With Quote
Ion = easiest front brake job ever! golftango Ion Tech 7 09-24-2016 06:03 AM
Clutch job on an Ion DukeCitySC2 Ion Tech 8 07-29-2009 08:46 AM
Grease job on an Ion? Blueshark Ion Tech 2 02-11-2007 09:31 AM
What to Lube Jim'sVue04FWDV6 Vue General 1 02-22-2006 08:56 AM
Lube Job 95_SC2_Guy Miscellaneous Tech 0 12-10-2002 04:32 AM
