Old 05-25-2005, 07:12 PM   #1
BigDaddyDrex1
BigDaddyDrex1 is on a distinguished road
BigDaddyDrex1's Avatar
Default Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor
Im in the process of changing all my sensors as my car is 10 years old. My qustion is there is a sensor on the transaxle by the tranny filter. its not listed in the service manual nor any of my local autoparts stores. Im assuming that its the temp sensor for the transaxle in case in gets to hot. If that is the case does anyone know if its the same part# as the one located on the engine?
thank you
Big Daddy Drex1
Add to BigDaddyDrex1's Reputation
Rate the quality of this post and help BigDaddyDrex1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BigDaddyDrex1 is offline   Reply With Quote
Old 05-26-2005, 01:47 AM   #2
sierrap615
sierrap615's Avatar
Default Re: Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor
it is the same part
sierrap615 is offline   Reply With Quote
Old 05-26-2005, 08:30 PM   #3
wolfman
wolfman's Avatar
The ECT, IAT and TFT are all the same part.
(Engine Coolant Temperature)
(Intake Air Temperature)
(Transaxle Fluid Temperature)
Note: the TFT is also sometimes called the TTS or ATT sensor.
Add to wolfman's Reputation
Old 05-27-2005, 12:06 AM   #4
sierrap615
sierrap615's Avatar
i have also heard TOT(trans oil temp)
Old 05-27-2005, 03:29 PM   #5
BigDaddyDrex1
thanx for the help
Coolant Temp Sensor? gr8gonzo0 S-Series Tech 2 05-12-2009 09:21 AM
Coolant temp sensor? 3500srw S-Series Tech 8 06-26-2008 11:45 PM
3.5 l coolant temp sensor DMVue Vue General 6 12-15-2007 09:17 AM
Coolant Temp Sensor MDSaturnSL2 S-Series General 19 12-23-2003 08:23 PM
where is the coolant temp sensor buddyc S-Series Tech 2 08-06-2003 06:18 PM
