Old 05-19-2005, 09:39 AM   #1
BlackBirdRacing
BlackBirdRacing is on a distinguished road
BlackBirdRacing's Avatar
Default clutch slave again?
history of car...
1993 sl2 fresh rebuild engine, lots of goodies.
Rebuilt tranny, welded diff pin.
brand new spec stage 2 clutch
sms flywheel
everything goes fine....
fast forward 2500 miles
clutch starts acting up, won't disengage fully.
I thinks must be old hydralics....
I replace hydralics, problem goes away for three days now problem back.
WTF??!!
clutch doesn't disengage fully, and clutch engaes right off floor.
Could I have put something together wrong?
Add to BlackBirdRacing's Reputation
Rate the quality of this post and help BlackBirdRacing reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlackBirdRacing is offline   Reply With Quote
Old 05-20-2005, 04:50 PM   #2
BlackBirdRacing
Default Re: clutch slave again?
Well good thing nobody else knows now I don't feel so much like a jackass.
Old 05-20-2005, 11:07 PM   #3
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
Normally the clutch pedal engaging low to the floor is a hydralic problem. Just like you figured. That fact that it fixed for three days when you replaced the hydralics means that you were right. Doing it again means that you could have gotten a bad master/slave unit. Inspect/remove it and see if there is there any fluid leakage from it. I would imagine that there will be some kind of warrenty on it after only three days.
Add to ssicarman's Reputation
Old 05-26-2005, 09:44 AM   #4
BarnOwl
BarnOwl's Avatar
This is a long shot, but my clutch with 160K on it quit disengaging. I replaced the hydraulics. Seemed to help some, but not much. It wound up being worn/broken fingers on the pressure plate. It wasn't slipping at all. Unless you got a bad pressure plate, I wouldn't expect that to happen in 2500 miles though.
Add to BarnOwl's Reputation
Clutch Slave chris2121 S-Series Tech 0 02-20-2009 12:03 AM
Clutch slave cylinder jrd_67 L-Series General 10 08-29-2004 10:16 PM
clutch slave cylinder jrd_67 L-Series Tech 0 08-15-2004 03:50 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 11:36 AM
Clutch slave Froussemaitre S-Series Tech 8 06-14-2002 09:00 AM
