Old 05-18-2005, 08:52 PM   #1
superjasn
superjasn is on a distinguished road
Default turns and turns but no start
i have a 95 sl2 and i was turning a corner and as i was pulling out it died as if i didnt know how to drive standard... automatically i tried poping the clutch while the momentum was still good... well no good.. so i pulled over tried to start it.. and now just grr rr rrr rrr rrr ....turns and turns with not start...now mind you it died while in motion.. if that means anything.. full is getting to the fuel rail.. has a nice strong battery... switched out the damn cps now wondering if it is the fuel pump... or that pcm thingy... i already did thing i saw in the forum to check the fuel pump ... i turned the key to on... for 3-4 sec. while it was priming and did it 3 times and then tried starting it... no start so your guess is as good as mine what the hell is it??? and i need my car so i appreciate any and all input
Add to superjasn's Reputation
Rate the quality of this post and help superjasn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
superjasn is offline   Reply With Quote
Old 05-18-2005, 09:22 PM   #2
dave.sl
dave.sl has a spectacular aura aboutdave.sl has a spectacular aura about
Default Re: turns and turns but no start
It would be a big help to let the forum know if the plugs are getting a strong spark when the engine is cranking. You could check it either at the coil pack or even pull one of the boots off one of the plugs and put a spare plug on the boot and ground the plug while cranking. I am not a Tech , but I think this would help others give you some other things to check out.
Add to dave.sl's Reputation
Rate the quality of this post and help dave.sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dave.sl is offline   Reply With Quote
Old 05-18-2005, 10:08 PM   #3
Lee3333
Lee3333 is on a distinguished road
Lee3333's Avatar
1999 SW2
I had a similar problem with my 93 SL2. My car would occassionally crank with out starting. After a while, it would start. Next, it began stalling out as I was driving. I changed the CPS and the ECTS, with no success. I took the car to my mechanic, and he discovered that when the car was running, if he tapped the ignition module the car would stall out. He changed the module and it solved the problem.
Also, my wifes 99 SW2 would crank with out starting once in a while. Then, the car would present this problem more and more frequently until it finally would not start. This turned out to be the PCM. Once it was replaced, the car was fine.
Add to Lee3333's Reputation
Rate the quality of this post and help Lee3333 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lee3333 is offline   Reply With Quote
Old 05-19-2005, 11:51 AM   #4
superjasn
forgot to say that it will start while spraying gas in the intake.... so spark is good
Old 05-19-2005, 01:26 PM   #5
edbama2
edbama2 is on a distinguished road
edbama2's Avatar
1993 SC2
1994 SC2
It sounds like your fuel filter or fuel pump if it will start with fuel.
When is Saturn going to make an SC2 Truck?
New 05 Dodge Ram Quad Hemi Thunder Road Package
Add to edbama2's Reputation
Rate the quality of this post and help edbama2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edbama2 is offline   Reply With Quote
Old 05-19-2005, 01:33 PM   #6
ud503j
ud503j is on a distinguished road
ud503j's Avatar
1997 SW2
Turn off the radio and a/c. Turn the key to run but not to start. Listen to see if you can hear the hum of the fuel pump. That's the easiest way to see if it's the pump. You might also have a bad/clogged injector but I don't think that would just cause it to run rough, not a complete shutdown and no restart.
1997 SW2 --> 'Vi'
g/f's 2002 SL2 --> 'Raven'
R4V3n SP33D's boytoy!
Add to ud503j's Reputation
Rate the quality of this post and help ud503j reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ud503j is offline   Reply With Quote
Old 05-19-2005, 01:39 PM   #7
superjasn
i can hear the pump prime itself when turned on... so i am thinking maybe its the pcm.. what do the rest of you think.. that would cause the fuel injectors not to shoot fuel right?? because thats the only thing thats not happening
Old 05-19-2005, 02:04 PM   #8
emailer33
emailer33 is on a distinguished road
1993 SL2
assume the pcm last, double check sensor connections, connections to pcm, etc...
Add to emailer33's Reputation
Rate the quality of this post and help emailer33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emailer33 is offline   Reply With Quote
Old 05-19-2005, 02:06 PM   #9
ud503j
ud503j's Avatar
1997 SW2
Pull the ECM 'B' fuse (in the underhood junction box if I'm correct,) for five minutes. It should clear out any 'programming' that's in the computer. Put it back in and see if it starts then. It should go back to defaults then. If not I think anybody with a test tool should be able to tell if it's toast or not.
1997 SW2 --> 'Vi'
Old 05-19-2005, 08:10 PM   #10
superjasn
i have checked and checked the sensor connections and connections of everything else nothing that i can see .. i have disconnected and reconnected to be sure of good connection 6x over nothing lose or burnt or anything else
Old 05-20-2005, 01:06 AM   #11
Magicman
Magicman has a spectacular aura aboutMagicman has a spectacular aura aboutMagicman has a spectacular aura about
I am currently experiencing this very same problem with a '94 SC2. It even happened the exact same way...........while accelerating it just died..........and hasnt started since.
I had a mechanic look at it.........he said it has spark......and I can hear the fuel pump. He said it was most likely the pcm. I replaced that and still nothing. Of course, it was a salvage part......so who knows if it works.
I'm very curious to see what fixes your car........maybe the same thing is wrong with mine. Whoever figures it out first, post it here!
Thanks,
Mike
Add to Magicman's Reputation
Rate the quality of this post and help Magicman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Magicman is offline   Reply With Quote
SC2 turns over but Won't Start; please help SaturnGirl02 S-Series Tech 12 05-31-2009 08:24 PM
Turns over but will not start unhappysaturn S-Series Tech 9 04-07-2009 03:52 PM
1999 SL turns over but won't start ryan123 S-Series General 16 11-25-2008 11:43 PM
Please Help! Car turns over, but won't start Red's 99 S-Series Tech 3 10-08-2007 10:00 AM
Turns over but takes a while to start StephenMartinez S-Series Tech 3 05-14-2007 03:16 PM
