Old 05-16-2005, 03:56 PM   #1
Gold93SL1
Gold93SL1 is on a distinguished road
1993 SL1
Default Doing front brake pads/rotors: torque plate bolt size and new anti-rattle clips??
I'm in the midst of replacing the front pads and discs (have caliper/pads off on driver's side so far) and am in a bit of a pickle.
A.) What size are the two TORQUE PLATE TO STEERING KNUCKLE BOLTS? Are they 18mm or 23/32? Conveniently enough, I have neither
B.) Are new anti-rattle clips required when installing new pads? My set of NAPA TruStop pads didn't come with new ones.
Thanks a ton! It would be nice to be able to get the torque plate off!! The discs are uber-rusty...who knows how old they are
Add to Gold93SL1's Reputation
Rate the quality of this post and help Gold93SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gold93SL1 is offline   Reply With Quote
Old 05-16-2005, 05:19 PM   #2
geartooth94
geartooth94's Avatar
Default Re: Doing front brake pads/rotors: torque plate bolt size and new anti-rattle clips??
you're right, the torque plate bolts (or caliper bracket as some like to call it) are large, I think either 18 or 19 mm.
I did not use new anti-rattle clips when doing either the front axle OR rear axle disc brake jobs on my SL2. Actually I found it hard to remove them, so i just cleaned them up with a little brake cleen, sandpaper and slapped in the new pads.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 05-16-2005, 07:54 PM   #3
The caliper mount to steering knuckle bolts are 18mm heads. Reinstall them with blue locktite to prevent them from backing out.
The anti rattle clips can be reused with no problem. If you want you can bend/tweak the curved up part of the clip to give a bit more hold pressure against the pads.
Add to ssicarman's Reputation
which caliper bolt for front brake pads loosens ? copakeman S-Series Tech 4 11-22-2009 08:56 AM
Disc Brake Anti-Rattle Clips The Critic S-Series Tech 4 07-23-2007 11:07 PM
Soft Brake Pedal after replacing front pads and rotors chinch33 L-Series Tech 7 05-08-2006 12:34 AM
Brake pads down to 3% on front Rotors. Time for change? L300GATTLINGGUN L-Series General 18 07-21-2005 07:48 AM
SW2 bolt size for front rotors to hub BahnBurnr S-Series General 3 03-27-2005 03:35 PM
