Old 04-17-2005, 05:19 PM   #1
badtzbuzz
badtzbuzz is on a distinguished road
Default cooling fan and Engine coolant temperature sensor problems
Having some troubles with my in-laws 2001 SW2. The Cooling Fan does not turn on and the temperature gauge does not read past 1/4.
We've tried replacing the ECTS, twice already, same problem. The fan does come on, when the AC is turned on. It also comes on when the ECTS plug is disconnected from the ECTS itself.
Even after the coolant is boiling the gauge reads 1/4 and the fan is not on.
Could it be the thermostat?
Any advice is appreciated.
Add to badtzbuzz's Reputation
Rate the quality of this post and help badtzbuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
badtzbuzz is offline
Old 04-17-2005, 05:24 PM   #2
Red97sc2
Red97sc2 is on a distinguished road
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
Default Re: cooling fan and Engine coolant temperature sensor problems
http://www.saturnfans.com/forums/showthread.php?t=41736
Looks to be a GREAT guide.
Add to Red97sc2's Reputation
Rate the quality of this post and help Red97sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Red97sc2 is offline
Old 04-17-2005, 06:02 PM   #3
badtzbuzz
Thanks for the thread. However, the fan does work and I've already reaplced the ects twice. It hasn't solved the problem.
Old 04-18-2005, 01:47 PM   #4
eljefino
eljefino's Avatar
1995 SW1
check the wiring to the ects, probably got corroded.
Add to eljefino's Reputation
eljefino is offline
Old 04-18-2005, 01:53 PM   #5
badtzbuzz
That's what I'm thinking...it might be the increased resistance. I've checked the exposed part of the wiring, but haven't checked the wire loom leading to the ECU.
Thanks.
Old 04-18-2005, 02:10 PM   #6
bgates2b
bgates2b is on a distinguished road
bgates2b's Avatar
2007 AURA XR
I thought Saturn fans come on when the needle goes into the red?
When I bought the HomeComing, the dealer I test drove it with parked the car and revved the engine up. He wanted to show me that you cannot overheat a Saturn and sure enough, the fan turned on when it hit the red zone.
I had two saturns, and neither one of them had the fan go on before reaching the red zone, unless the air is on. Funny, but 12 years later, I still get nervous as to when the fan will go on.
Add to bgates2b's Reputation
Rate the quality of this post and help bgates2b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bgates2b is offline
Regarding the Engine coolant temperature sensor BrianD1 S-Series General 4 01-06-2010 04:54 PM
Engine Coolant Temperature Sensor 2ndSCowner S-Series General 13 03-24-2009 12:43 AM
Engine Coolant Temperature Sensor Tom64 S-Series Tech 3 11-22-2007 07:36 PM
Coolant temp sensor controls the cooling fan? Toadfish S-Series Tech 2 11-17-2007 12:48 PM
Engine Coolant Temperature Sensor lhwilliams S-Series Tech 7 04-17-2007 03:58 AM
