Old 04-05-2005, 02:10 PM   #1
94stoner
94stoner is on a distinguished road
Default Bad Fuel Injector?
94 SL2 98,000 miles. Automatic
My #1 fuel injector is intermittent? When the engine is cold it works fine, I check this by pulling out the ignition wire to that cylinder expecting the motor to stumble or not. When I start my car when the engine is hot I get no fuel to that cylinder. The only way for me to get that injector going again is to tap that injector plug on top with the end of a screwdriver. Then it works. I already tried 2 bottles/tanks of the injector cleaner but still the same problem. My question is: Is the injector just clogged? Or the coil winding is bad?
Thanks
Add to 94stoner's Reputation
Rate the quality of this post and help 94stoner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94stoner is offline
Old 04-05-2005, 10:10 PM   #2
Default Re: Bad Fuel Injector?
If you are tapping the injector connector to get it working there is a chancve that the connector has a problem with a loose connection. If you believe it to be the injector for sure try swapping the injector with another cylinder to see if the problem follows the injector. If it does replace it.
Add to ssicarman's Reputation
ssicarman is offline
Old 04-06-2005, 10:39 AM   #3
Luke
Luke's Avatar
> ssicarman <
> If you are tapping the injector connector to get it working there is a chance that the connector has a problem with a loose connection <
Very Good piece of analysis -- that slipped my mind. I would have simply assumed that it was the injector
Add to Luke's Reputation
Luke is offline
Old 06-05-2005, 01:16 PM   #4
94stoner
Just an update.
I haven't did anything to my problem yet, but I found something out about gasoline. Everytime I fill up with ARCO gas 87 because it's the cheapest around here in LA I get my intermittent injector problem. But when I fill up with Mobil (87) my injector problem goes away and I do notice a little more power. Of course I shouldn't have any problems with any type of gas I use but it's strange. I still have to take care of my problem though.
94stoner is offline
Old 06-06-2005, 08:34 AM   #5
Luke
Luke's Avatar
Aaaaaaaaaaaahhhhhhhh, I've been using Arco (Los Angeles & Orange Counties) for decades with no problems. You may, though, be getting bad gas from one particular "old" (thus underground tank) station.
Luke is offline
Old 06-23-2005, 07:45 PM   #6
94stoner
Luke I think you are correct. Since my last post here I have been using other brands of gasoline (even a different ARCO) and I don't have that injector problem anymore. BUT I did go back to that ARCO about two days ago and guess what! My injector problem came back. I won't go there anymore and now I have to put up with my problem until I use up all of that gas.
Thanks.
94stoner is offline
Old 06-23-2005, 09:04 PM   #7
BarnOwl
BarnOwl's Avatar
To make sure that it's not the injector, you could try swapping number one with 2 or 3.
Add to BarnOwl's Reputation
BarnOwl is offline
Old 06-23-2005, 09:32 PM   #8
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
I woud be a little suspicious of the fuel as problem idea. If it was fuel, would you have problems with other injectors as well? Also tapping on injector wouldn't solve the problem. Still sounds like a short in the injector connection. Could be mistaken, but I would try swapping injectors just to see what happens.
Add to dansl2's Reputation
Rate the quality of this post and help dansl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dansl2 is offline
Old 06-23-2005, 11:30 PM   #9
sierrap615
sierrap615's Avatar
not nessicirally, if the injectior is partilly clogged the better gas(Mobil) may work but the lower quality fuel(ARCO) won't. its possible but i don't think that is the cause in this case. i think i'm going with ssicarman on this one.
first measure resistance of the injectior both cold and hot and compare. if you have a NOID light handy, you may want to see it you are getting a injectior signal when warm, then with the NOID light still installed wiggle the wire and connectior see if the signal changes. also you can use a mechanic's sheitiscope or a long flathead screwdriver to listen for the injectior ticking. if the injectior is ticking and you have no fuel, the injectior sounds clogged to me. also visually inspect the connectior.
one way or the other, odds are the injectior will need replaced, or there is a small chance the connectior/wiring is damaged.
sierrap615 is offline
Old 06-24-2005, 09:21 AM   #10
Luke
Luke's Avatar
Default Arco Customer Relations Complaint
Arco Customer Relations Complaint telephone number is 1800 - 322 - 2726
You'll need the station location and "number"; you'll find that on your receipt.
Luke is offline
Old 06-24-2005, 03:38 PM   #11
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
a wise old Standard Oil of Ohio (now BP) engineer once told me:
switch brands of gas often
everybody cheats on the additives but everybody cheats on different ones at different times
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill Murray is offline
bad signal to fuel injector PurdueGuy S-Series Tech 10 03-13-2008 10:14 AM
Fuel Injector / Fuel System cleaners AJT_Leo S-Series Tech 2 07-09-2007 03:30 PM
Bad Fuel Injector lhwilliams Community Center 1 04-14-2007 08:24 PM
Bad Injector replace or run fuel additive nmsaty S-Series General 3 04-20-2006 11:25 AM
Bad injector? Av8r S-Series Tech 4 02-24-2005 12:10 AM
