Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 03-23-2005, 09:23 AM   #1
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Post "Top 10 Tips for Improving Your Fuel Economy"
The following information is from http://www.edmunds.com/reviews/list/...4/article.html:
By Tara Baukus Mello
Date Posted 10-05-2004
Filling up is a fact of every driver's life, but for some drivers it is a necessary evil. If you are one of those people who gulps every time you have to fill up your vehicle, there's good news: there are some simple things you can do to improve your fuel economy no matter what type of vehicle you drive.
Monitoring your average fuel economy regularly is a good idea, too. (Some vehicles have a handy computer that computes this for you.) If you notice a significant change, then something has changed with your vehicle.
Here are 10 things you can do today to get better gas mileage right away.
1. Follow the Recommended Maintenance
A vehicle that is well maintained means it will operate with greater efficiency. This not only improves your overall vehicle performance, but it will improve your fuel economy as well. Fouled spark plugs, a dirty air filter or clogged fuel filter will all affect your fuel economy. According to the U.S. Department of Energy (DOE), replacing a clogged air filter can increase your mileage by 10 percent, while replacing an oxygen sensor could result in an improvement as high as 40 percent. Proper maintenance also means using the right octane gas and the recommended grade of motor oil. Using the recommended types for your vehicle will give you optimum fuel economy and can save you money as well. Check your owner's manual for your vehicle's recommendations and have maintenance performed regularly by a dealer or reputable mechanic.
2. Keep Your Tires Properly Inflated
Underinflated tires require more energy to roll, which translates into more frequent fill-ups. You can improve your fuel economy by about 3.3 percent if you keep your tires inflated properly, according to the DOE. The psi number noted on the sidewall of your tires is the maximum pressure of the tire and is not the proper inflation level for your car. Your vehicle manufacturer will list the recommended tire pressure in your owner's manual or a sticker on the doorjamb of the driver-side door. Buy a tire-pressure gauge and check your tires monthly, adding air as necessary.
3. Take a Load Off
Heavier vehicles require more energy to move, so carrying around excess weight will also affect your mileage. Empty out your trunk (or even your backseat) of unnecessary items. An extra 100 pounds in the trunk will reduce your fuel economy by 1 to 2 percent in the typical vehicle. If you have a roof rack or roof carrier, install it on your vehicle only when absolutely necessary. Not only does the carrier add extra weight, but it also increases the aerodynamic drag on the vehicle, which further contributes to a loss of fuel economy.
4. Don't Drive Aggressively
We're not talking road rage here, but the type of driving many people do when they are in a rush. Mashing the accelerator pedal from a stoplight, braking hard and speeding all contribute to a decrease in fuel economy. Give yourself extra time to get to your destination and think "steady and smooth" as you drive. On surface streets, driving at the speed limit will give you mostly green lights, which improves your gas mileage as well as reduces the wear on your brakes. On the highway, the DOE says that every 5 mph you drive over 65 mph represents a 7-percent decrease in fuel economy.
5. Use the Highest Gear Possible
Cars are designed to start in the lowest gear possible because that's where they have the most power, but that power translates to an increase in fuel consumption. To improve your fuel economy, drive in the highest gear possible when you are cruising at a steady speed, such as on the highway. If your vehicle has an automatic transmission with a "sport" mode, it's most likely that this is a computer program designed to shift later (and therefore keep you in a lower gear longer). While this gives you greater performance, driving in "sport" mode will also decrease your fuel economy.
6. Use Cruise Control Selectively
Using cruise control can improve your gas mileage by helping you maintain a steady speed, but only if you are driving on mostly flat roads. If you are driving in hilly terrain, using cruise control typically causes your vehicle to speed up faster (to maintain the preset speed) than it would if you were operating the accelerator yourself. Before you push that cruise control button, think about the terrain ahead.
7. Think Clean
Keeping your car washed and waxed improves aerodynamics and therefore affects fuel economy. Engineer Tom Wagner, Jr. reported to Stretcher.com (as in stretching your dollars) a 7-percent improvement in fuel economy, from 15 to 16 mpg, during a 1,600-mile road trip.
8. Avoid Excessive Idling
When a car is idling, it is using fuel, yet not going anywhere. This translates to 0 mpg. When you leave your car running while you are waiting in line at the drive-thru, or as you wait outside your kids' school, you are wasting fuel. It is more efficient to turn the engine off while you wait and then restart the car. If that's not practical (like in the line at McDonald's), then park the car and go inside instead.
9. Think Before You Vent(ilate)
Running your air conditioner does cause your vehicle to consume more fuel, but driving with your windows rolled down can be even worse due to the increase of drag on the vehicle. If you are driving slowly, such as around town or in city traffic, then you are better off leaving your windows open, if at all possible. For highway driving, roll up the windows and turn the air conditioning on.
10. Combine Your Errands
A little planning can make a big difference in fuel economy. When your engine is cold, it uses more fuel than when it is warm. Combining errands can improve your gas mileage because your engine will be warm for more of the trip. It might also mean you travel less total miles. According to the DOE, several short trips all begun with a cold start can use twice as much fuel as a single, longer trip that covers the same distance.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 03-23-2005, 09:37 AM   #2
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default Re: "Top 10 Tips for Improving Your Fuel Economy"
7% increase from just a wax job?
I'd like to see that proven.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline
Old 03-23-2005, 10:16 AM   #3
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
You'll notice the 7% increase was from 15mpg to 16mpg. I'm sure one could swing that by unloading some.. uh.. bodily waste... if you catch my drift...
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline
Old 03-23-2005, 10:49 AM   #4
lexington01
lexington01 is on a distinguished road
lexington01's Avatar
Har Har!
Add to lexington01's Reputation
Rate the quality of this post and help lexington01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lexington01 is offline
Old 03-23-2005, 11:53 AM   #5
bobwill
bobwill is on a distinguished road
bobwill's Avatar
2003 ION-1 Sedan
Seeing as it got 15-16 mpg, it's either a sportscar (which is probably aerodynamic enough for the waxing to make a difference) or it's an SUV, in which case it's got aerodynamic problems that no wax can fix.
Bob
Add to bobwill's Reputation
Rate the quality of this post and help bobwill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobwill is offline
Old 03-23-2005, 12:30 PM   #6
lexington01
Or maybe they drove from Colorado to New York (downhill) with the wind at their back.
Old 03-23-2005, 12:34 PM   #7
K-1
K-1's Avatar
2008 Astra XR
Or they drove at a different speed
Or somebody else drove
Or there wasn't as much traffic
Or they had spicy mexican food the day before and... okay, I'll stop now.
K-1 is offline
Old 03-23-2005, 12:52 PM   #8
VegasSaturn
VegasSaturn is on a distinguished road
I can't believe that they left out number 11....... Leave the wife at home. Or does that fall into the "extra weight" catagory?
Add to VegasSaturn's Reputation
Rate the quality of this post and help VegasSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VegasSaturn is offline
Old 03-23-2005, 02:12 PM   #9
SweetSL2
SweetSL2 is on a distinguished road
2003 ION-2 Sedan
HI-OO!!!
"Cheap, Fast, and Reliable. Pick two, the other wont be possible" - TheSaturnKid
Add to SweetSL2's Reputation
Rate the quality of this post and help SweetSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SweetSL2 is offline
Old 03-23-2005, 02:43 PM   #10
lexington01
X-play?
Old 03-23-2005, 10:33 PM   #11
Pete93SL1M
Pete93SL1M is on a distinguished road
Pete93SL1M's Avatar
yea, and as long as we're doing that, take out the extra seats, pump the tires to maximum psi and only drive down-hill!
..aka GMinTheDriveway
Former Saturn Sales Consultant
Give me choices in powertrain, great handling and decent MPG and I will buy a Saturn again.
Add to Pete93SL1M's Reputation
Rate the quality of this post and help Pete93SL1M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pete93SL1M is offline
Old 03-23-2005, 10:39 PM   #12
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Devil Re: "Top 10 Tips for Improving Your Fuel Economy"
If you thought that article from Edmunds was funny then this information from AAA should be hysterical.
http://www.fuelgaugereport.com/
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-03-2005, 12:00 AM   #13
occupant
occupant is on a distinguished road
occupant's Avatar
The real #11 should be, coast as much as possible. If you are on a road that is 30mph with red lights every mile, get up to 35mph and coast to the next light. If cars way in front of you are slowing, don't get right up on them before you slow down, get off the gas.
OT: For those of you who are broke like me, here's a cute little trick, I read it in Bob Sikorsky's book, "Drive It Forever". It's called the Emergency Economy Method. If you're about to run out of gas, let's say you're on your way home from visitng your in-laws, and your kids are asleep in the back and your wife is nagging you to stop for gas, and you pull into a station and IT'S CLOSED! You have maybe a gallon of gas and your car gets 20mpg but the next station is 50 miles. Here's what you do:
Accelerate slowly to a reasonable speed, say 35mph. Then shut the engine off and coast down to 5-10 mph. Restart your engine and slowly accelerate back up to 35mph or so. Then repeat. This is easier with a stick. I'll use the clutch to start it when I get crawling. 4th gear at 10mph, you can pop the clutch out and in, then drop it in 2nd and start accelerating.
I did this last Wednesday up in the Middle Of Farm He//, TX. I felt my engine bucking at one point, started doing this, and managed to go 26 miles before it wouldn't restart anymore. The walk to the gas station was now within sight distance and under 10 minutes, instead of 3 hours or hitching a ride in a manure truck.
Alan Moore
Malone, TX
1999 Taurus SE sedan, navy blue, 131K, Jellybean
1988 Suburban 2500, gray/red, 228K, The Moose II
Add to occupant's Reputation
Rate the quality of this post and help occupant reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
occupant is offline
Old 04-04-2005, 09:48 AM   #14
100KSW2
100KSW2 is on a distinguished road
100KSW2's Avatar
David
Many Thanks for posting that information!
Jim
P.S. This is NOT (by far) the first time anyone has mentioned keeping a car clean and waxed to help mileage. Automakers have gone to great pains over the last few decades to reduce drag in their designs (at least outside the whole SUV/truck thing). Changing to different tires (rolling resistance vs. traction) will also have an effect on gas mileage.
Add to 100KSW2's Reputation
Rate the quality of this post and help 100KSW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
100KSW2 is offline
Old 04-04-2005, 03:13 PM   #15
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Re: "Top 10 Tips for Improving Your Fuel Economy"
Making a vehicle more aerodynamic will decrease wind resistance. Keeping a vehicle clean and possibly waxed will help a little bit. Over one tank full of gasoline the differences will be marginal. But over the course of tens of thousands of miles those saved nickels and dimes will slowly add up. In the world of bicycling it is not uncommon to see guys with shaved legs; they do it for a few reasons with aerodynamics being one of them. I swear I am not making this up.
In the automotive world the Saturn S-Series cars are aerodynamic. Or at least they were when they first came out. The Saturn S-Series car brochures used to have a bunch of technical stuff in them and wind resistance was actually in there.
I think the target audience for the seventh comment in the article regarding keeping the vehicle clean was directed toward the people who never ever wash their cars. Believe it or not I can count with one hand the number of people in my neighborhood that wash their cars.
The point of the article is there are a number of easy little things we can do that will improve our fuel economy. Doing a few or as many as we can will indeed make a difference over time. If I wrote the article I probably would not have included the bit about keeping the vehicle clean to lower wind resistance; instead I would have suggested people go on diet/exercise programs to lose weight and hence improve their vehicle's fuel economy while getting themselves healthier at the same time.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-04-2005, 03:40 PM   #16
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Cool Re: "Top 10 Tips for Improving Your Fuel Economy"
From the 1994 Saturn brochure, page 33:
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-05-2005, 03:48 PM   #17
VegasSaturn
Cyclist shave their legs for a number of reasons besides aerodynamics. It is actually proven that clean shaved legs will have less damage to them than hairy legs when a leg meets pavement at 20+ mph. It is also proven the women cyclists dig guys with sexy, smooth, muscular legs. It also provides guys the opportunity to create common ground with prospective females.
Hell, I just about have myself talked into going home and shaving my legs tonight!! Wonder if I'll have the same benefits sitting on the couch with a beer, hhmmm......................
Old 04-05-2005, 05:26 PM   #18
Citation84
Citation84 has a spectacular aura aboutCitation84 has a spectacular aura about
Citation84's Avatar
2005 ION-1 Sedan
Very clever.I LOVE that book "Drive It Forever". I suppose you have "Why Trade It In ?" as well ....... Excellent tips in both. My own favorite automotive philosophy books.... those two and "Car Repair For Dummies". All classics. Those should fit on the shelf nicely with "In The Rings Of Saturn" in a Saturn Fans library of automotive basics.....
What about a K&N Air Filter and low restriction muffler? Has anyone made cost effective mods for economy rather than performance on their Saturns ?
Add to Citation84's Reputation
Rate the quality of this post and help Citation84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Citation84 is offline
Old 04-05-2005, 06:54 PM   #19
piney
piney will become famous soon enoughpiney will become famous soon enough
piney's Avatar
I guess that dating skinny chicks is part of the "take a load off" section but I'v found that dating size 4 and below chicks under 5'02" gives me better MPG and saves on the dinner tab too!! Talk about a double whammy!!!
Add to piney's Reputation
Rate the quality of this post and help piney reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
piney is offline
Video: New Saturn "Pundits" Commercial Discusses Class-Leading Fuel Economy and Side- Charlie General Saturn Discussion 3 03-20-2009 03:52 PM
Fuel Economy Tips Charlie General Saturn Discussion 0 08-22-2008 10:55 PM
Bob Lutz comments on improving fuel economy djreed Vue Green Line 19 04-21-2007 09:52 PM
Beginning to Construct my "Performance/Economy" Switch SDJASON S-Series Mods 36 11-30-2006 01:18 PM
2007 Saturn "Green Line" vehicles to emphasize fuel economy XtremeGrandAm General Saturn Discussion 3 08-05-2005 05:47 AM
