Old 03-19-2005, 06:23 PM   #1
JerryHughes
JerryHughes's Avatar
1997 SL
Default Engine cleaning at car wash?
Hello,
I understand that you should not use the power washers at your neighborhood car wash to clean your engine, primarily because of the electronics, etc. Should you leave this to a professional only? (A clean engine looks so much better)
Thanks for any reply.
Jerry
JerryHughes is offline
Old 03-19-2005, 06:28 PM   #2
daddio
daddio is on a distinguished road
daddio's Avatar
Default Re: Engine cleaning at car wash?
i usually spary some mean green and use the gardenhose sprayer. works pretty well.
Add to daddio's Reputation
Rate the quality of this post and help daddio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daddio is offline
Old 03-19-2005, 06:53 PM   #3
Razorbak
Razorbak's Avatar
Originally Posted by JerryHughes
Hello,
Jerry
Don't use a power washer to clean your engine. The high pressure will force water and soap into the Weatherpak connectors. Just use a general purpose degreaser like Simple Green and a garden hose (light pressure) to rinse it off. You should probably cover the coil packs with a plastic baggie or Saran Wrap, because you want to keep that dry and corrosion free.
Add to Razorbak's Reputation
Razorbak is offline
Old 03-19-2005, 09:02 PM   #4
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
Just did it this morning and it worked great. Had to use a toothbrush on a couple caked on spots on the head but, aside from that, the Simple Green did just fine.
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline
Old 03-19-2005, 09:47 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
I've used Gumout foamy engine cleaner in the past with a garden hose to rinse it clean with good results. Cover the electrics and the air box. Simple Green is something else you could use.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 03-19-2005, 10:55 PM   #6
Sky King
Sky King's Avatar
I use the philosophy that says if you keep it clean you never have to go to stronger methods. I usually rinse the engine and compartment with plain water from the garden hose every time I wash my car. Then I use a blow nozzle on the old air compressor to blow off everything followed up immediately by starting the engine to allow heat to finish it off. I have not had to use any degreasers whether detergent or petrolium based. Only occasionally do I use just soap and water. Because of my regular cleaning, I regularly stay on top of keeping things such as hood hinges, latches, shift linkages etc lubricated.
One other important consideration, it not a good idea to spray cold water on a hot engine.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sky King is offline
Old 03-20-2005, 05:08 PM   #7
JerryHughes
1997 SL
It seems pretty universal not to use a high pressure spray at the car wash. I'll try the Simple Green, let it soak for a while then rinse with a garden hose on a cold engine. Can I use the Simple Green everywhere on the engine, down below, on the side of the engine, etc.? I will cover the coil packs but is there anything else, electronically, that I should protect? Thanks everyone for your replies.
Jerry
Old 03-20-2005, 06:48 PM   #8
JDub99SL2
JDub99SL2 is on a distinguished road
I've used a high pressure washer on my engine compartment several times and have never had a single problem. I've also used it when doing work on heavily oil soaked engines. Every used car that goes on the lot has had it's engine pressure washed as well. The only problem we had was when some water got into the plug holes on a Miata. Took a few shots of brake clean and a blast of compressed air to fix. I'd say there is little to no risk involved from personal experience...
Simple green works well. I forget what the detailers use. Some type of 'professional degreaser,' I'm sure. Breathe that stuff in and your lungs feel like they're on fire. Keeps wheels nice and shiney, though. :-) Simple green or some type of engine degreaser sold at any parts store should work fine.
Add to JDub99SL2's Reputation
Rate the quality of this post and help JDub99SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JDub99SL2 is offline
Old 03-20-2005, 08:30 PM   #9
dougVA
dougVA is on a distinguished road
1997 SW1
One other area to watch for when hosing off your engine is the throttle cable sheathing. It's not hard to get water into it, even with a garden hose, which will cause a stuck throttle cable if the temps fall below freezing.
We had a spring-like week this winter so I washed my car and decided to hose out the engine too. When it dropped down into the teens the next week, the throttle stuck when I pumped the accelerator after starting. I had to pop the hood, manually retract the cable, and not touch the pedal again until the engine warmed up enough to thaw it out. WD40 sorta helped, but not entirely. Made for several 10 minute idle sessions on the way to work & back home again.
Doug
97 SW1 (193,000 mi and counting!)
Add to dougVA's Reputation
Rate the quality of this post and help dougVA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dougVA is offline
Old 03-21-2005, 12:32 PM   #10
Qlara
Qlara's Avatar
Other than Electronics, try to avoid spraying water on the battery compartment/tray. There's no drain hole on the tray so water will stay to induce more corrosion.
Has anyone tried the Mr Clean car wash?
I actually like the Mist(Rinse) Setting from its water nozzle and it perfect for engine spraying. Not too strong, but still with great coverage.
Add to Qlara's Reputation
Qlara is offline
Old 03-21-2005, 01:56 PM   #11
JerryHughes
1997 SL
Hi JDub99SL2,
When you mentioned that you used a high pressure washer to clean your engine, was that at a pay-car-wash or a high pressure hose at home? Thanks,
Jerry
Old 03-21-2005, 08:30 PM   #12
micah_sl2
micah_sl2 is on a distinguished road
1993 SL2
i used the car wash sprayer, but i didnt pull the trigger- that works well
Add to micah_sl2's Reputation
Rate the quality of this post and help micah_sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
micah_sl2 is offline
Old 03-21-2005, 08:40 PM   #13
JerryHughes
1997 SL
Hi micah_sl2,
Good idea of using the car wash but not pulling the trigger! I hadn't thought of that but the yellow-colored car wash's engine degreaser that we have out here in southern California works great. In the past, on another car, I used the car washer's degreaser then used the high pressure spray to clean that off. However, that old Geo Metro would hardly start at the car wash and I had to get a push from a friend to get it started. So I have learned not to use the high pressure spray at those car washes for the engine. But from now on I will use their engine degreaser but I will do as you did and only use the mild spray from the nozzle instead of rinsing the engine off with the full force of the spray. (That'll keep my concrete at home cleaner too) Thanks and have a good one.
Jerry
Old 03-21-2005, 09:52 PM   #14
JDub99SL2
It's at work... I imagine very similar to the type available at a car wash. I also use the car wash at work, and have never used a DIY car wash before that (other than the driveway) so I am not exactly 100% sure what is available.
Old 03-22-2005, 03:06 PM   #15
JerryHughes
1997 SL
Thanks JDub.
Jerry
Old 03-22-2005, 08:47 PM   #16
Sky King
Sky King's Avatar
These posts causes me to ask me how often are you all cleaning your engine. In my opinion if you want to have a clean engine and engine compartment, the best thing you can do is not allow it to get dirty in the first place. As I said in my post early in this thread, I hose off my engine every time I wash my car at home with the garden hose and then blow it off with compressed air and have done so since I bought it new. It never got dirty. If you don't have an air compressor, you can use a leaf blower, (which is actually reccomended by motorcycle folks because high pressure air can push water into switch housings). Then start the engine and allow the engine heat finish the drying.
If you keep it clean, any time a leak appears, you know it right off. You don't have to wonder when it started or where it is comming from. It is never old so you can see exactly where it is comming from.
The only caution is to avoid degreasers in pulleys and bearings. You can eventually wash the grease and lubricant out of these devices and cause premature failure. That is another reason I use only water on a regular basis. If you do it every time you wash the car, you really don't have to depend on solvents and degreasers. I also regularly lubricate the shift links on the transmission, the hood latch and throttle cable and hood hinges.
Sky King is offline
Old 03-23-2005, 11:52 AM   #17
SATURNER
SATURNER is on a distinguished road
SATURNER's Avatar
My engine has NEVER been cleaned('94) . She has not needed it. It is my belief that if there are no oil leaks, then there is nothing for particulates to stick to.
Hang up and Drive
Add to SATURNER's Reputation
Rate the quality of this post and help SATURNER reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SATURNER is offline
Old 03-23-2005, 03:10 PM   #18
JerryHughes
1997 SL
Well, actually, I would keep the engine on a brand new car clean but I bought this car with around 93K miles. Even though when I got it a light cleaning was done on the engine, it wasn't thorough and I've been afraid to take it to the car wash because of that experience with my other car not starting after the cleaning. So hopefully, I can get this engine clean "gently" and keep it that way. I understand that taking a car to a professional cleaning service can cost some bucks but I'd rather do it myself and get a good job that I can keep up.
Jerry
Old 03-23-2005, 10:42 PM   #19
bryan_johnson
bryan_johnson is on a distinguished road
bryan_johnson's Avatar
1994 SC2
One note to add here. Don't ever clean a HOT engine. WARM is fine, but running cold water over a hot engine is just not a good idea, things contract and warp and crack sometimes :-( I start mine up, let it idle for 1-2min, and then soak and spray it. I also recommend Simple Green. The bit of engine heat also helps release some dirt. It actually dries too fast on a hot engine and doesn't have time to penetrate the grease.
Some cars also just get dirtier under the hood than others. Nissan, Honda, and Saturn seems to stay quite clean underhood. Mazda, Ford, Chevy, not so much.
Advantages of a clean engine is less mess when doing repairs, a cooler running engine, and problems are spotted more easily when they occur. I have heard some say that the thin film of road dirt on an engine and associated parts helps keep the hoses and such from deteriorating as quickly, but I'm not sure I beleive this or not. Anyone want to take that stance?
BJ
Add to bryan_johnson's Reputation
Rate the quality of this post and help bryan_johnson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bryan_johnson is offline
Old 03-23-2005, 10:54 PM   #20
Mr. Bill
Mr. Bill is on a distinguished road
Most of the newer car washes that are do-it-yourself now recycle their water through filter units and they don't want all that oil and engine GUNK residue in their machines.
Add to Mr. Bill's Reputation
Rate the quality of this post and help Mr. Bill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mr. Bill is offline
Car wash? redsaturn13 Ion General 11 04-26-2007 08:02 PM
problem after i wash the car???? 96 saturn S-Series Tech 4 03-01-2006 10:55 AM
Going through car wash w/OnStar noshooz Vue General 4 11-17-2003 04:54 PM
Car Wash vebix General Saturn Discussion 20 12-10-2002 12:58 PM
