Old 03-11-2005, 04:21 PM   #1
92sl2
92sl2 is on a distinguished road
Default Oil Filler Cap
Somehow I managed to lose my oil filler cap (I suppose I didn't put it on tight enough). At any rate every store I've tried (Autozone, Napa, Advance Auto, etc.) has said that the cap for the 1992 SL and the 1992 SL2 are the same but when I tried it, the cap did not fit. I called the dealer today and he said the same thing, but asked if I was sure that mine wasn't a 1991 since that year apparently does have different caps. I know that my cap is different from a 1995 SL, which itself is different from a 1994 SC2 (which would just further prove a difference between base and 2). Does anyone have any insights on these differences? Does anyone have any suggestion on where I can find the right cap? I am sure the tinfoil and duct tape won't last for very long.
Add to 92sl2's Reputation
Rate the quality of this post and help 92sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92sl2 is offline
Old 03-11-2005, 04:54 PM   #2
partsmgr
partsmgr is on a distinguished road
Default Re: Oil Filler Cap
1992 uses two types of oil filler caps for either SOHC/DOHC engines:
1st des: 21007528
USE ON 91-92 USE ON COVER WITH STANDARD (LIGHT-BULB STYLE) THREADS. FOR 92 FORWARD USE P/N 12573342 (SQUARE
CUT THREADS). SEE TECH BULLETIN 95-T-01A.
2nd des: 12573342
SERVICE INFORMATION ON NEW DESIGN OIL FILL CAP #95-T-01A - (Jul 1, 1995)
SUBJECT: Service Information on New Design Oil Fill Cape with Internal Relief Valve
Due to revisions under Models Affected and Purpose, this bulletin supersedes bulletin 95-T-01, which should be discardes.
MODELS AFFECTED: 1991-1994 and 1995 Saturns built before and including VIN SZ302900 with SOHC (L24) engines and VIN SZ289249 with DOHC engines.
PURPOSE: A new 2nd design oil fill cap (P/N 21007528)with light bulb threads, has been released for all 1991-1992 Saturns built before and inclucing VIN NZ223175 with SOHC (LK0) engines and VIN NZ207713 with DOHC (LL0) engines.
A new 2nd design oil fill cap (P/N 21007373) with square cut threads, was released for service in Janauary, 1995, for 1992-1995 vehicles built after and including VIN NZ223176 with SOHC (LK0/L24) engines and VIN NZ207714 with DOHC (LL0) engines.
Both of the new 2nd design oil fill caps have an internal relief valve and are the only oil fill caps available from Saturn Service Parts for servicing 1991-1995 Saturns.
IMPORTANT: 1995 Saturns built after and including VIN SZ302901 with SOHC (L24) engines and VIN SZ289250 with DOHC (LL0) engines have the new 2nd design oil fill cap (P/N 21007373) installed during production.
Figure 1
Figure 2
General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information.
Add to partsmgr's Reputation
Rate the quality of this post and help partsmgr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
partsmgr is offline
Old 03-15-2005, 12:59 PM   #3
92sl2
Thank you for your reply. However, I am still a little muddled. The end of my VIN (I assume that is what is referenced in the bulletin) is NZ135206. Does that mean I need an oil cap with what is referenced as "light bulb threads", which seems to be one originally intended, mostly, for the 1991 model year? So this would support the theory that the cap I have tried to obtain from the auto parts store is the one with "square cut threads", which would be why it does not fit, leading one to conclude that if you need an oil filler cap for this particular 1992 Saturn you should ask for a cap for a 1991 Saturn? I only ask this because if I can obtain a cap for a 1991 Saturn from a local parts store it would be easier (not to mention cheaper) than trying to obtain it from the dealer who is over an hour away. Unless, of course, you might know of an online source where it can be located.
Thanks for your help!
92sl2 is offline
Old 03-15-2005, 01:24 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
On you old oil cap, did it screw on and ratchet around or did it go on, turn a 1/4 turn and get tight?
Low Saturn is offline
Old 03-15-2005, 02:19 PM   #5
partsmgr
according to your VIN, you should have the first design cap. Click the link in the previous post (21007528). That will take you to where you can order online. Just search that number in the OEM part number search.
partsmgr is offline
Old 03-15-2005, 07:38 PM   #6
92sl2
On the old cap it turned and clicked tight. Not sure if it was 1/4 turn and not sure if it would continue to turn past the click for I always stopped at the click.
Thanks for the link partsmgr - but it comes up with nothing.
92sl2 is offline
Old 03-15-2005, 07:52 PM   #7
partsmgr
21007528
partsmgr is offline
Old 03-15-2005, 11:03 PM   #8
92sl2
All that does is give me the home page of Saturnparts.
92sl2 is offline
Old 03-16-2005, 12:06 AM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Just send Simon an e-mail, he'll get you the part you need
Old 03-16-2005, 11:46 AM   #10
partsmgr
92sl2, go back to that link (21007528), type the same number in the "Search by Factory Part Number" field. The cap will be listed there.
partsmgr is offline
Old 03-16-2005, 12:12 PM   #11
Thor4SL2
Thor4SL2 is on a distinguished road
Thor4SL2's Avatar
Just put 3 or 4 layers of aluminum foil over the opening, hold it in place with some twist ties or something, and say the hell with it. Seriously, with the foil in place drive to your nearest Saturn dealer and show it to the parts guy.
It's not what you know that counts,
it's what you think of in time!
Add to Thor4SL2's Reputation
Rate the quality of this post and help Thor4SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thor4SL2 is offline
Old 03-16-2005, 01:00 PM   #12
92sl2
Default About that Aluminum Foil
That and duct tape are what are currently covering the hole at the moment.
92sl2 is offline
Stuck Oil Filler Cap kmdevo S-Series General 14 11-03-2014 03:13 PM
Oil filler cap stuck wishihadacamaro S-Series Tech 7 01-29-2008 12:11 AM
Whats under my oil filler cap? mrwag S-Series Tech 3 02-21-2007 04:30 PM
Creamy substance on oil filler cap - cause? miker S-Series Tech 6 02-20-2006 08:46 AM
tanish-grayish gunk under oil filler cap blackeagle1 S-Series Tech 10 10-29-2005 08:57 PM
