Go Back   SaturnFans.com Forums > Site Information > Community Center > Suggestion Box
Old 08-23-2001, 06:53 AM   #1
beasjd
Guest
Posts: n/a
Default Sportmatic Transmission
If Saturn doesn't use the perf/norm switch, maybe they could use one of the new "sportmatic" transmissions like Mitsubishi and Dodge use.
Add to beasjd's Reputation
Rate the quality of this post and help beasjd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-26-2001, 10:46 PM   #2
Russ Bellinis
Russ Bellinis is on a distinguished road
Default
You could probably do it yourself. All it would take is to put the shift lever on a ball joint to allow side to side movement, and then fabricate a shift gate like Mercedes, Jaguar, etc. If the lever is left in 4, it works like the stock autoshift. With a shift gate you can shift up through the gears, or down through the gears one gear at a time without having to stare at the shifter. You would need to fabricate a set of spring loaded sliders to keep the lever from flopping around, and to keep it from skipping a shift.
Add to Russ Bellinis's Reputation
Rate the quality of this post and help Russ Bellinis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Russ Bellinis is offline
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 06:47 PM
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 08:28 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
'95 Transmission Operation Debrief: Transmission stuck in 2nd gear rc1488 S-Series General 0 01-12-2008 12:28 AM
Transmission Fluid flow from Transmission into the radiator ? Luke S-Series Tech 5 11-10-2005 10:52 AM
