Old 04-12-2001, 12:09 PM   #1
rudy
rudy is on a distinguished road
Default Hard starting 97' SL2
Please help guys. My GF's car is hard to start all the time-hot or cold. The engine will crank but will not fire. I turn the key off and try it again and it will immediately start. On Monday, I replaced the spark plugs, air filter, new wires, and new battery. I have thought about a bad injector. I have used Techron a couple of times in hope that the car has carbon deposits but Techron makes no difference.
Thanks in advance,
Rudy
Kansas City
Add to rudy's Reputation
Rate the quality of this post and help rudy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rudy is offline
Old 04-12-2001, 07:25 PM   #2
sattech
sattech is on a distinguished road
Default
Hard to say with limited info. Possible sticking idle air control comes to mind. Does the car start with partial throttle? Before you start throwing parts at it though, check for good spark when the condition is happenning, Check fuel pressure as well
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 04-12-2001, 07:25 PM   #3
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
Saw your post and the replies in autoforums -- let us know if it turns out to be the fuel pump.
Add to Heartbeat - '95 SL2's Reputation
Rate the quality of this post and help Heartbeat - '95 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Heartbeat - '95 SL2 is offline
Old 04-12-2001, 08:16 PM   #4
Three Rings
Three Rings is on a distinguished road
Default
There is an extended warranty coverage for the fuel pump on the 97. Had both of ours done last year for no cost - took about 2 hours. The dealer can put a pressure gauge on your car and check it to see if the pump is bad. See your dealer...
Add to Three Rings's Reputation
Rate the quality of this post and help Three Rings reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Three Rings is offline
Old 04-12-2001, 08:58 PM   #5
saturntech45
saturntech45 is on a distinguished road
saturntech45's Avatar
Default
whats happening is your fuel pump regulator is bleeding down during the non running time. when you go to crank it there is no fuel pressure. when you turn the key off and try again the fuel system has generated enough fuel pressure to fire right off. as t&k said there an extention of warranty for this problem. i believe 5 yr. or 70 k miles. and if your out i bet you can still talk your retailer into replacing it.
Add to saturntech45's Reputation
Rate the quality of this post and help saturntech45 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturntech45 is offline
Old 04-12-2001, 09:56 PM   #6
Default
I thinking one of two things happening. Either the special policy fuel pump problem or a bad crank sensor. Check for spark when the car is cranking and doesn't want to catch. If you have spark then the crank sensor is good. But I think that from what you said in your post it's likely the fuel pump bleeding down and causing the problem. If it's within the year and mileage requirements then Saturn will cover the fuel pump replacement. At a Saturn store of course.
Add to ssicarman's Reputation
ssicarman is offline
Old 04-13-2001, 09:15 AM   #7
newt
newt is on a distinguished road
Default
Is the fuel pump on a 97 different than the pump on a 95? Is it a OBD1 versus OBD2 thing? I seem to have a similar problem and have been going through FPR's like PEZ over the past 5 years--o.k. 4 FPR's. I have a new FPR in there right now which I installed in the fall--the pressure at the rail actually hold for more than a minute! I'd like to check the pressure at the pump but I think I need a "special" adapter for the line.
Any ideas for the adapter, or will I just have to take it into the dealer? Right now, the car is cranking about 8 to 10 times per start--even with the new FPR. When the FPR is bad, it'll do the same, but then kill immediately--especially if it's warm. Then it'll pop right off and stay running.
Thanks guys,
-Newt
Add to newt's Reputation
Rate the quality of this post and help newt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newt is offline
Old 03-13-2005, 07:44 PM   #8
PsychoSaturnMan
PsychoSaturnMan is on a distinguished road
Default Re: Hard starting 97' SL2
how long was that warrenty good??? i have a feeling that the fuel pump may be the root of my hard starting also.
Add to PsychoSaturnMan's Reputation
Rate the quality of this post and help PsychoSaturnMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PsychoSaturnMan is offline
Hard starting midwest S-Series General 2 06-27-2009 11:54 AM
Hard Starting SL jdsdls S-Series Tech 0 06-24-2009 10:53 AM
Hard starting mr.mangosteen L-Series Tech 4 09-28-2008 09:32 PM
Hard Starting richamer1 S-Series Tech 1 12-22-2007 12:57 PM
1993 sl2 hard starting when hot norsemen S-Series Tech 4 06-21-2007 07:15 PM
