Old 02-09-2005, 08:05 AM   #1
cris_thomas
cris_thomas is on a distinguished road
cris_thomas's Avatar
Wrench 1998-2002 S-Series Fuel Filter Replacement (w/ Pictures)
The original updated version of this document lives here.
98-02 Saturn S-series Fuel Filter Replacement
Disclaimer:
I am not a mechanic. These instructions are a conglomeration of several other how-to documents, Saturn FSMs, shop manuals, online postings and other sources of information. These instructions should not be considered a stand alone document and should be used in conjunction with an FSM, Haynes, or Chiltons manual. These instructions are in no way authorized, approved, or otherwise condoned by Saturn Corp. If you render your car undrivable, unsafe, or just plain broken I am in no way responsible. If you are an idiot, moron or just plain stupid do not attempt this repair.
Introduction:
The 1998-2002 Saturn S-Series Fuel Filter is rated for 100,000 miles and should not need to be replaced before then (unless you use really crappy gas). The fuel filter includes an integrated fuel pressure regulator making the part fairly expensive ($65-$95). The fuel pump is located inside the gas tank and is not a subject of this document.
This is a fairly simple repair. On a scale of one to ten with an oil change being a one, pads and rotors being a three I would rate this maybe a two. The biggest obstacle to overcome with this repair is locating the actual items on the car. It should only take aproximately 30 to 45 minutes if you have never done this before and if you go really slow. The most time consuming part is getting the car up on jack stands. Note this How-To is for the newer S-Series (98-02), older S-Series fuel filters are completely different and located in a different location. Most of the photos are from a 2001 SC2, your vehicle may be slightly different.
Tools and parts needed:
- Usual hand tools
- Jack
- Jack Stands
- New Fuel Filter With Bracket (SAT21009427)
- Catch Basin/Drip Pan
1. Remove the fuse for the Fuel Pump. It is located in the passenger fuse box.
2. Start the car and let it idle until it stalls.
3. Locate the Schrader valve under the hood. Remove the screw on black cap and depress the valve. Have a rag handy to catch the small amount of fuel that will escape. Your Fuel System is now depressurized.. (Remember to resecure the black cap.)
- Cris Thomas
SPOC New England
http://www.spocne.org
Add to cris_thomas's Reputation
Rate the quality of this post and help cris_thomas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cris_thomas is offline
Old 02-09-2005, 08:09 AM   #2
cris_thomas
Default Re: How To: 98-02 S-series Fuel Filter Replacement (w/ Pics)
4. Jack up the rear of the car and support it with jack stands. Make sure the car is high enough for you to comfortably work underneath it and that it is secure. Don't be the idiot that kills themselves by dropping a car on your head. (They usually don't think it will happen to them either.)
5. Lay down under the car and locate the original fuel filter. It will be on the drivers side just forward of the gas tank. Note the location of the two bracket retaining bolts and the three fuel lines entering and exiting the filter.
6. I found it easiest to remove the two bolts holding the bracket first. Note, these bolts have been under your car exposed to rain, snow, salt and other nasty stuff for probably 100,000 miles if not longer. It is very likely that they will be rusted in place. These are very skinny bolts and will break off easily. Also note that the brake line may be in the way making it difficult to use a socket in this location.
7. After you have removed the bolts disconnect the fuel lines. These connectors are a two part system requiring you to squeeze the inner plastic clip and pull the line. Be careful, while the system is no longer pressurized the filter is still full of fuel, quite a bit of it. Don't lay down directly under the filter when disconnecting the lines or you will get a face full of fuel. Have your drip pan ready to catch whatever pours out.
8. Insert the new filter into the new bracket and attach the new clips. (If you bought an OEM filter it should come with the bracket and clips. If you didn't buy an OEM filter good luck getting the old filter out of the bracket.)
9. Slide the bracket and filter into place and attach the fuel lines.
10. Reinstall the bolts that hold the bracket in place.
- Cris Thomas
SPOC New England
Old 02-09-2005, 08:10 AM   #3
cris_thomas
11. Lower the car.
12. Reinstall the fuel filter fuse.
13. Turn your ignition key to the RUN position and hold it a few seconds, you should be able to hear the fuel pump repressurize the fuel system and fill the new filter full of fuel.
14. Start the car. If the car doesn't immediately turn over you may need to slightly depress the gas pedal.
15. Check for leaks. Go for a short test drive and check for leaks again.
Congratulations! You have changed your fuel filter!
Many thanks to Jeff Putnam, Bill Kuhns, Lane, Kevin Keller, John Comskey, Wolfman, Ssicarman, SaturnSpeed, SPS, SaturnFans.com, SPOCNE, and everyone else.
If you find a problem with these instructions or a better way of doing things, or something Iíve missed please let me know.
Updated versions of this document can be found at http://www.cristhomas.com/cars/GasFi...lterHowTo.html
Permision is hereby granted to republish and distribute this document provide that no changes are made. This includes but is not limited to the introduction, disclaimer and URLs.
Written By: Cris Thomas (cthomas AT spocne DOT org)
Last Updated: January 30, 2005
The original updated document lives here.
- Cris Thomas
SPOC New England
Old 02-17-2005, 11:20 PM   #4
SimPlyxTriPPiN
SimPlyxTriPPiN is on a distinguished road
SimPlyxTriPPiN's Avatar
1995 SC1
Default Re: 1998-2002 S-Series Fuel Filter Replacement (w/ Pictures)
would this work on my '97
Add to SimPlyxTriPPiN's Reputation
Rate the quality of this post and help SimPlyxTriPPiN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SimPlyxTriPPiN is offline
Old 02-18-2005, 08:39 AM   #5
cris_thomas
Ummm, no. There is another How-To around here somewhere that shows the fuel filter for the 97 I think. Try doing a search.
- Cris Thomas
SPOC New England
Old 10-13-2005, 07:51 PM   #6
DarrylLeeOHS30
DarrylLeeOHS30 is on a distinguished road
2001 SL2
which fuse is for the fuel pump
Add to DarrylLeeOHS30's Reputation
Rate the quality of this post and help DarrylLeeOHS30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DarrylLeeOHS30 is offline
Old 10-19-2005, 12:56 AM   #7
edlee
edlee will become famous soon enough
1999 SL1
The Haynes manual shows a picture of a 10 amp fuse #12. I do not know which model of Saturn that they photographed.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline
Old 10-21-2005, 07:06 PM   #8
sunshn1972
sunshn1972 is on a distinguished road
sunshn1972's Avatar
When I did this I had to pull the fuel pump relay, not the fuse. The inside of the cover should have a diagram telling you what fuse and relay goes to what.
This space intentionally left blank.
Add to sunshn1972's Reputation
Rate the quality of this post and help sunshn1972 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sunshn1972 is offline
Cheap $25 1998-2002 Fuel Filter & aftermarket guide ruley73 S-Series General 74 06-04-2013 10:08 AM
1998 Fuel Filter - (Fuel line retainers) Jeffsimpson S-Series Tech 3 01-30-2008 08:42 PM
98-2002 S-series Fuel Filter Replacement horny-toad S-Series Mods 6 12-12-2007 04:51 PM
2002 SL2 fuel filter replacement Gonefishin76 S-Series Tech 4 11-23-2006 10:54 AM
1998-2002 S-Series Fuel Filter With Pics cris_thomas How-To Library 0 01-30-2005 05:27 PM
