Old 02-05-2005, 12:32 AM   #1
jmedlin6
jmedlin6 is on a distinguished road
Default 2000 LS1 misfire/poor fuel economy
Ok so here it goes. I bought my 2000 LS1 used. All recalls have been done to the car. *Even the one where they replaced the engine*
Here is my issue. I am having an intermintant misfire. I am also getting poor gas mileage. There is no ck engine light! I have replaced the following items:
* Fuel Filter
* Air filter
* Upstream O2 sensor
* Ignition Coil 2nd time *it was replaced before w/ the recall*
* New plugs
* New plug boots
* Down stream O2 was replaced a few months back *ck engine light w/ this one*
My mechanic hooked an OBDII up to it and we drove around. All of them would misfire sometimes. Usually when we were stationary #3 would misfire. It usually doesn't miss unless I am stopped at a light, the car is in drive and the A/C compressor is on. (I am thinking it us just making a greater load and causing the engine to miss easier)
When I had my PA emissions done a few months back my car passed but it stated:
"Based on the information gathered during an attempt to prefor an Onboard Diagnostic test, NO RPM signal was available from the Onboard Diagnostic computer system. This vechicle should produce an RPM signal from the Onboard Diagnostic computer system." Could this be my problem?
Also if I sit at the light and I give my car alittle gas and rev the engine up, it is smooth and won't mis. Anyone have any ideas?
This is driving me crazy!
Oh and Saturn checked it out and said everything was ok!
Add to jmedlin6's Reputation
Rate the quality of this post and help jmedlin6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jmedlin6 is offline
Old 02-06-2005, 10:13 PM   #2
L100
L100 is on a distinguished road
2001 L-Series 2.2L Sedan
Wrench Re: 2000 LS1 misfire/poor fuel economy
Wow. Your problem sounds similar to mine. I am getting worse gas mileage these days with no check engine light.. I also have a slightly rough idle, although it just happened. I may have put some bad gas in the tank. I don't know. If I find anything I'll let you know.
Add to L100's Reputation
Rate the quality of this post and help L100 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L100 is offline
Old 02-06-2005, 10:21 PM   #3
jmedlin6
Default Re: 2000 LS1 misfire/poor fuel economy
I just ordered the follow sensors from Saturnparts.com I am hoping that one of these is feeding the PCM bad information. I'll let you know if this helps.
  • AIR INTAKE TEMP SENSOR
  • COOLANT TEMP SENSOR
  • KNOCK SENSOR
  • MAP SENSOR
This car is making me go
jmedlin6 is offline
Old 02-06-2005, 10:29 PM   #4
eternalstdnt
eternalstdnt is on a distinguished road
What kind of plugs did you use?
I had horrible idle and misfires in my 2000 sl1, also without any ses light. It was being caused by the Bosch Platinum's I had installed just a few months earlier. I took them out and put in the NGK's that everyone else recommends and it has been idleing smooth ever since.
Add to eternalstdnt's Reputation
Rate the quality of this post and help eternalstdnt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eternalstdnt is offline
Old 02-06-2005, 10:36 PM   #5
jmedlin6
OEM ACDelco #41-981. I couldn't find any other company that made a good plug. Does NGK make a plug for the 2000 2.2 l61?
jmedlin6 is offline
Old 02-07-2005, 01:27 AM   #6
eternalstdnt
OH MY!! Im sorry, I read your post to quickly the first time through and thought you had an "SL1", and now I see you have an "LS1." The NGK is what comes OEM in the S -Series, and the use of platinum plugs in the "S" series seems to give those symptoms you listed. If the plugs you bought were OEM in the "L" series, then I would feel confident that the brand is not the problem, however is sure sounds like something is not quite with the plugs....
Old 02-07-2005, 04:42 PM   #7
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Did the car ever get the recall done regarding the coil?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline
Old 02-07-2005, 05:33 PM   #8
jmedlin6
Yup. All campaigns were preformed. I even went out and put another ignition coil module in. The strange thing is, it was kinda warm today. I think it hit close to 60 degrees. It seemed to run pretty well. As soon as the sun went down and it got colder, it seems to be running crappy again. I hope these sensors come in the mail soon..
jmedlin6 is offline
Old 02-09-2005, 04:49 PM   #9
JuicedL200
JuicedL200 is on a distinguished road
use u can get NGK for the 2.2L.....u prolly have to order em...i did from advance auto parts....
Add to JuicedL200's Reputation
Rate the quality of this post and help JuicedL200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JuicedL200 is offline
Old 02-09-2005, 05:23 PM   #10
jmedlin6
Did you see any improvement?
jmedlin6 is offline
Old 02-10-2005, 12:04 AM   #11
JuicedL200
a lil ya
Old 02-10-2005, 12:05 AM   #12
jmedlin6
how much were they?
jmedlin6 is offline
Old 02-10-2005, 12:24 AM   #13
JuicedL200
kinda pricey....i think like 4-5 dollars a pop
Old 02-13-2005, 05:51 PM   #14
jmedlin6
Does anyone have the proper gapping specs for a 2000 2.2? saturn told me it was close to 60 where as alldata online states it is 40. Can someone look in a manual and tell me? I bought my car used so it can w/ a S-Series book and not an L-Series! Stupid dealer..
jmedlin6 is offline
Old 04-20-2005, 02:04 PM   #15
etp26
etp26 is on a distinguished road
Sound like what mine has been doing. Did those parts fix the problem.
I had mine into Saturn for three days and they replace plugs, coil pack and ignition module and it still does it. They told me if the engine light doesn't come on then the engine misfire / vibration is okay. They are full of crap!
Add to etp26's Reputation
Rate the quality of this post and help etp26 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
etp26 is offline
Old 04-20-2005, 02:20 PM   #16
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Check the underhood sticker near the hood release.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Very Poor Fuel Economy diablo2070 S-Series Tech 54 01-23-2007 06:51 PM
Poor fuel economy David R S-Series Tech 56 06-16-2006 08:32 PM
2000 LS1 misfire/poor fuel economy jmedlin6 L-Series Tech 0 02-05-2005 12:21 AM
Poor Fuel Economy David R S-Series General 47 04-25-2004 05:58 PM
Poor Fuel Economy David R S-Series General 0 04-07-2004 11:21 AM
