Old 02-03-2005, 09:24 PM   #1
lpradiohead
lpradiohead is on a distinguished road
1999 SC1
Default Hole in Flex Pipe
Hello Everybody,
I was investigating muffler vibration the other day and noticed that I have a hole in my flex pipe. Here come the questions. First, how does a hole in the flex affect performance (i.e. affect transmission or acceleration)? Secondly, how can I fix this (I can't afford to replace the entire unit surrounding flex pipe, as it comes via Saturn)? I am pretty sure this is causing my muffler to shake, thus, bad vibration at idle. Thanks.
Add to lpradiohead's Reputation
Rate the quality of this post and help lpradiohead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lpradiohead is offline
Old 02-03-2005, 09:43 PM   #2
Default Re: Hole in Flex Pipe
A hole in the exhaust should not cause a vibration. More likely to cause that might be the upper engine mount. Check aftermarket exhaust shops to see if they are able to patch in a replacement flex pipe.
Add to ssicarman's Reputation
ssicarman is offline
Old 02-03-2005, 09:59 PM   #3
lpradiohead
1999 SC1
All engine mounts are superb. I know the exhaust is shaking and causing some vibration, though.
Old 02-03-2005, 10:16 PM   #4
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Is your muffler hanger in the back broken causing your muffler to rest on the axle making a ridiculous vibration?
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline
Old 02-04-2005, 12:56 PM   #5
Qlara
Qlara's Avatar
Hole in the exhaust pipe....How can you bear in driving such loud condition? And yes, hole in the pipe will make the whole thing shake.
SaturnTech is right, have you checked the muffler strap hanger too? Tell easily because you'll see the Muffler Tip is hanging very low, once the strap hanger is broken.
Add to Qlara's Reputation
Qlara is offline
Old 02-04-2005, 01:18 PM   #6
lpradiohead
1999 SC1
I don't think the hanger is broken. But I am going to put it up on ramps and figure more out. I still want to know how a hole in the flex pipe affects performance. I hear this quite a bit, but do not understand. Thanks for the replies.
Old 02-04-2005, 03:30 PM   #7
SaturnTech
SaturnTech's Avatar
Don't need ramps to check the hanger...walk behind the car, grab the tailpipe and try to ove it up and down....if it moves...its broken.
Old 02-04-2005, 04:57 PM   #8
kmix99
kmix99 is on a distinguished road
kmix99's Avatar
Cool Re: Hole in Flex Pipe
I had a hole just in front of my flex pipe (where the tranny clamp holds it) and MIG welded it with stainless steel. The braiding on my flex pipe is flaking off--still thinking of a way to fix it.
Where exactly is the hole?
Add to kmix99's Reputation
Rate the quality of this post and help kmix99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kmix99 is offline
Old 02-04-2005, 05:08 PM   #9
lpradiohead
1999 SC1
If the hanger is broken, how do you fix? I know for sure that the pipe is shaking from the flex to the muffler. Maybe tis the hanger. Thanks. The hole in my flex pipe is smack in the middle. It is big enough to see exhaust coming out.
Old 02-04-2005, 05:23 PM   #10
kmix99
kmix99's Avatar
You may be able to have it welded with the pipe on the car if you are lucky.
You can make your own hanger with two stainless steel exhaust clamps, hammer and a vise. Just weld them together as in my picture.
kmix99 is offline
Old 02-05-2005, 10:55 AM   #11
Luke
Luke's Avatar
>> kmix99 <<
Really appreciate your pictures
Add to Luke's Reputation
Luke is offline
Old 02-05-2005, 03:41 PM   #12
IMkenNY
IMkenNY is on a distinguished road
Checking to see what UPS charges are from Buffalo To Central PA .......Kmix99 looks like a welding pro!!!, lol
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline
flex pipe osaturn Ion Tech 8 06-04-2009 12:04 PM
97 Flex Pipe off-track S-Series Tech 2 06-20-2008 10:12 PM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 03:46 PM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 07:44 PM
Flex pipe... Rob1998SL2 Mods and Performance 10 10-08-2003 04:33 PM
