Old 01-27-2005, 11:01 PM   #1
Adam1027
Adam1027 is on a distinguished road
Adam1027's Avatar
1994 SC2
Default draining antifreeze/coolant
can anyone tell me where to find the drain valve for a radiator on a 1994 saturn sc2?
also, how exactly do i "flush" the radiator after its drained?
Add to Adam1027's Reputation
Rate the quality of this post and help Adam1027 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Adam1027 is offline
Old 01-27-2005, 11:39 PM   #2
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default Re: draining antifreeze/coolant
Ok heres the low down on how to flush:
1)Jack the vehicle up on jackstands (one per side a few inches away from the front wheels along the metal lip that runs along side of car).
2)The 'petcock' (drain valve) is located on the RIGHT bottom side of radiator. A big plastic piece/protector covers the bottom of the radiator. However, there is a hole in this piece that allows you to access the drain valve, although its a little tight fit. Turn it COUNTERCLOCKWISE and pull down slightly. Be careful! The fluid with shoot out with force.. it is suggested to do this with an ICE COLD car cuz the fluid is really hot. Have a BIG bucket positioned under this valve. Let drain. LEAVE THE VALVE OPEN FOR NOW.
3)To "flush" it run a hose through the coolant tank until the water coming out the petcock is clear. If your coolant is SEVERELY neglected, skip this step for now, fill up with a product such as RADIATOR FLUSH/CLEANER(available at wal-mart among other places) and then top it off with distilled water. Run this for a few days to "clean" the system. THen flush it again the normal way.
4)After running a hose through, open up the engine block drain plug. It is near the petcock, but obviously on the engine block itself. You need a socket wrench for this (dont remember exact size, its pretty small ~10mm?).
Let the coolant drain from this then screw back in.
5)Close the petcock. LOWER the car then fill up with a 50%/50% mix of water and antifreeze (the coolant cap should have a colored dot for which kind). *my personal preference is to buy "pre-mixed" 50/50 antifreeze, also available at wal-mart. Straight antifreeze is SUPER CONCENTRATED and should never be added umixed!
*you may want to let it sit a while or let the car idle after doing this. Usually after it circulates you will need to top it off with more coolant*
*as for disposing of antifreeze, you 'can' severely dilute it with water and run it down your sink without worry.*
Add to RalliArt16's Reputation
Rate the quality of this post and help RalliArt16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RalliArt16 is offline
Old 01-28-2005, 12:15 AM   #3
Silver02ex
Silver02ex is on a distinguished road
Silver02ex's Avatar
1991 SL2
http://www.saturnfans.com/forums/sho...light=radiator
2002 Honda Civic EX
1991 Saturn SL2
Add to Silver02ex's Reputation
Rate the quality of this post and help Silver02ex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Silver02ex is offline
Old 01-28-2005, 10:44 AM   #4
Razorbak
Razorbak's Avatar
Does this flush solution also protect against freezing? (I've never used it before.)
Add to Razorbak's Reputation
Razorbak is offline
Old 01-28-2005, 03:23 PM   #5
RalliArt16
RalliArt16's Avatar
1996 SC1
I dont think so. On the back of the label it just says it helps get rid of all the rust in the system and clean it out. There is another product by Prestone(which makes all these antifreeze additives i've mentioned) called "radiator treatment". It says you add it and it lubricates and protects the system.. so that *may* help against freezing, not too sure.
Old 01-28-2005, 06:05 PM   #6
Adam1027
Adam1027's Avatar
1994 SC2
thanks a ton RalliArt, exactly the info i needed. *thumbs up*
Adam1027 is offline
Old 01-28-2005, 06:57 PM   #7
Razorbak
Razorbak's Avatar
That's what I thought. OK, just to be clear, you should modify your previous recommendation...
"If your coolant is SEVERELY neglected, skip this step for now, fill up with a product such as RADIATOR FLUSH/CLEANER(available at wal-mart among other places) and then top it off with distilled water. Run this for a few days to "clean" the system. THen flush it again the normal way.
... to prevent someone from using this stuff in the middle of winter, and then leaving the car overnight where this slurry freezes inside the radiator and the block.
Razorbak is offline
Old 01-28-2005, 07:52 PM   #8
emptypockets
emptypockets is on a distinguished road
emptypockets's Avatar
1999 SC1
So you run it with no antifreeze at all? Is that going to make the temp rise/fall faster than normal? I would think that the cooling properties of this stuff mixed with just distilled water would make a long highway drive for someone like myself(1 hour round trip) a little different than normal. Anyone know from experience? By the way, awesome "How To" RalliArt
Add to emptypockets's Reputation
Rate the quality of this post and help emptypockets reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emptypockets is offline
Draining the engine coolant Loopie S-Series Tech 12 02-28-2008 11:33 AM
Draining coolant to replace the I.Manifold? Batman87 S-Series Tech 6 01-31-2007 10:13 PM
Draining/Flushing Coolant on an SL2. Splops S-Series Tech 8 09-17-2006 06:05 PM
Coolant draining arunsam3000 S-Series General 12 01-13-2006 02:04 AM
What kind of containers do you use when draining fluids (oil, tran., coolant)? sjt78 S-Series Tech 5 09-09-2002 11:16 PM
