Old 01-24-2005, 09:25 PM   #1
cgavula
cgavula is on a distinguished road
Default Rear Washer Dribbling
I got my new Vue last week. With all the salt and crud on the road, I've had to use the rear wiper/washer a lot. I notices that the fluid sort of runs straight down rather than spraying as it does in the front. Is this normal or should it spray?
I have to take the car in Friday because the cruise control doesn't work at all. Kind of unfortunate for a new car. If the rear washer should spray I want to point it out to the tech while it's in.
Other than these things, I pretty much love the Vue - it handles well and has a lot of power.
Thanks for the info.
--Chris
________________________________
2005 Vue FWD 3.5L - Dragonfly Green
1995 SC2 - Aquamarine (prev)
cgavula is offline
Old 01-24-2005, 09:34 PM   #2
blkprl
blkprl is on a distinguished road
blkprl's Avatar
2004 VUE 3.5L
Default Re: Rear Washer Dribbling
Unfortunately mine dribbles as well since new. The wiper also is not very effecient, it seems it needs to have more pressure against the glass.
blkprl is offline
Old 01-24-2005, 09:39 PM   #3
The Math God
The Math God is on a distinguished road
The Math God's Avatar
that's all you are going to get
2007 Vue -- AWD 3.5 Honda
2005 Vue -- AWD 3.5 Honda
2007 Ion 2 -- 2.2
2005 L300 -- 6 cyl
Gone but not forgotten
2003 Vue -- 105K-traded in
2000 LS 2 --140 K-totaled
1994 SL-- 100K-sold
The Math God is offline
Old 01-24-2005, 09:50 PM   #4
NOLA-Vue
NOLA-Vue is on a distinguished road
2008 AURA XE
2006 VUE 2.2L
Just this once, when Saturn tells you it's normal, it IS normal.
"The principle difference between a man and a dog is that if you take a dog in and make him prosperous, he won't bite you!" - Mark Twain
2008 Aura XE-4
2006 VUE 2.2L
NOLA-Vue is offline
Old 01-24-2005, 09:51 PM   #5
cgavula
Well Saturn hasn't told me anything yet, I just wanted to check with other folk before I brought it up. It seemed kind of anemic, especially since most of it ends up running down the back of the Vue rather than getting onto the rear window!
Could be worse - I traded an Pontiac Aztek - it had NO washer/wiper at all. Weird with all that glass back there - but then that didn't pick up the dirt the way this one does!
--Chris
cgavula is offline
Old 01-24-2005, 10:31 PM   #6
mr weather
mr weather is on a distinguished road
Mine dribbles too. Has since day one. It's normal.
There is a way to time the wipers to take full advantage of the dribble. I've got it down to a science now!
I also agree the arm needs MORE pressure.
mr weather is offline
Old 01-24-2005, 11:04 PM   #7
runerx
runerx is on a distinguished road
runerx's Avatar
2003 VUE 2.2L
Has anyone tried "adjusting" the pressure by slightly bending the arm down?
Mine seems to work well enough so I havn't needed to do this myself.
And yes a straight stream down the glass is as good as it gets. It's all about the timing.
DJ
runerx is offline
Old 01-24-2005, 11:24 PM   #8
cgavula
I noticed that it was a trick of timing as well - but I have to agree - a little more pressure would be a good thing.
--Chris
cgavula is offline
Old 01-25-2005, 12:00 AM   #9
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
2002 - mid 2004 have a sprayer that shoots a straight stream down. Late 2004 and 2005 have a slightly dispersed pattern, but it still just dribbles out.
~D.J.~
OhioVueBoy is offline
Old 01-25-2005, 12:41 AM   #10
aahdd
aahdd is on a distinguished road
aahdd's Avatar
2004 VUE 3.5L
Same here.
aahdd is offline
Old 01-25-2005, 01:22 PM   #11
rickpa75
rickpa75 is on a distinguished road
rickpa75's Avatar
I was always wondering about that!!
Seems kind of dumb to have it dribble like that...
I wonder if any aftermarket spray ends would fix it - I'll have to investigate!
-Rick
rickpa75 is offline
Old 01-25-2005, 01:33 PM   #12
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
You have to time it right to get it to work at all. I would suggest a rear deflector. Will make things much better but not 100% solve your problem. An easy DIY job and you can get a good price at Saturnaccessories.com. Since i've installed one I use my rear wiper much less. Wait till you see what the wiper replacement costs
ricksLS1 is offline
Old 01-25-2005, 01:53 PM   #13
mr weather
Got mine aftermarket for about $7. There aren't many out there that small (11"?) but I found one.
What does Saturn ding you for one?
Old 01-25-2005, 02:02 PM   #14
ricksLS1
ricksLS1's Avatar
What after market did you find? From what I remember Anco made an 11 blade but the holder was either to big or small for the hook. One dealer near me wanted $14.07 the 10 and change. I got a couple at Saturn accessories for $7 and change.
ricksLS1 is offline
Old 01-25-2005, 02:06 PM   #15
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Roof rails will severly hamper the performance of the rear air deflector.
But my rear wiper still works WAY batter than the wiper on my Mountaineer did. That thing would leave about half the wiped area unclean. I bent that thing all around and improved it some but it was never great.
Slightly off topic, but have you noticed the different placements of rear wipers on other vans and SUV's? Some are in the middle, some are offset (to the right IIRC) and some are even top mounted. Personally, I like the center mounted wiper on my VUE.
Still slightly off topic, is there a separate reservoir for the rear wiper fluid? My Mountaineer had one but I haven't seen anything for the VUE.
--Tom
Not a Saturn.
Tom92SCm is offline
Old 01-25-2005, 02:16 PM   #16
revue
revue is on a distinguished road
revue's Avatar
--Tom
There's only one reservoir, it's under the hood. A really long hose snakes its way to the back.
revue is offline
Old 01-25-2005, 02:22 PM   #17
silvervoo
silvervoo is on a distinguished road
silvervoo's Avatar
2003 VUE 2.2L
-Rick
I have to believe there is a reason for this design. At 70MPH with a fine spray nozzle back there I wonder if you would get any liquid at all onto the window? it might all blow away unless you have a wind deflector or spoiler.
●● If it doesn't have a clutch, I'm not interested ●● Vive la bote manuelle ●●
silvervoo is offline
Old 01-25-2005, 03:10 PM   #18
ricksLS1
ricksLS1's Avatar
Could you imagine how bad it would be if the used the same nozzles that are used for the front? Those are poor. I had 2 blow off that had to be replaced. When the 1st one went asked if they could change the other. They said no but was back in a month. Guess the dealer wants you to come back to get more warranty $$ and a chance for maintenance services.
ricksLS1 is offline
Old 01-25-2005, 04:51 PM   #19
VUEnumber1
VUEnumber1 will become famous soon enough
VUEnumber1's Avatar
When I got my used VUE the rear nozzle was upsidedown, spraying towards the sky.
I wonder if the previous owner liked to squirt tailgaters.
I flipped it over.
VUEnumber1 is offline
Old 01-25-2005, 05:25 PM   #20
mr weather
US dollars, right?
I got mine at our national car parts emporium called Canadian Tire. They sell OE-like metal blades. Not sure who the manufacturer is.
Hmm... I just looked up their website and they no longer list the 11" blade. I hope they haven't stopped selling them!
Rear Washer Nozzles Kazooracer 2008 Vue 4 12-31-2007 11:04 AM
Rear washer on 99 SW1 VWman S-Series Tech 2 02-04-2006 06:51 PM
Rear washer, early SW cityhawk S-Series Tech 12 10-29-2005 06:54 AM
Rear washer - no spray Isophorone S-Series General 7 02-04-2004 06:38 PM
rear washer on new vue judesps Vue General 5 12-13-2002 02:42 PM
