Old 01-16-2005, 03:21 AM   #1
SimPlyxTriPPiN
SimPlyxTriPPiN is on a distinguished road
SimPlyxTriPPiN's Avatar
1995 SC1
Default possible throttle problem
im not really sure if this is an actual problem. i have a '97 sl2 that i've had for about 7 months. i've noticed that when im driving and i release the gas, the car seems to keep goin. it takes awhile for the car to slow down, about 1/2 a block for it to decrease the speed by 5 (going 35mph). the rpm slowly descends. could it be the throttle body?
Add to SimPlyxTriPPiN's Reputation
Rate the quality of this post and help SimPlyxTriPPiN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SimPlyxTriPPiN is offline
Old 01-16-2005, 03:27 AM   #2
avanwest
avanwest is on a distinguished road
Default Re: possible throttle problem
I have a '98 Sl2 that is the same. There is almost no engine braking and you really have to use the brakes to start slowing down. It's not at all like my Acura, I barely use the brakes on it. It does seem strange when I switch cars but then again there are lot's of strange differences with Saturn.
Cheers
Add to avanwest's Reputation
Rate the quality of this post and help avanwest reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
avanwest is offline
Old 01-16-2005, 04:19 AM   #3
SimPlyxTriPPiN
1995 SC1
yeah that's true. but imagine how much gas it takes if the car uses gas to slow down. what a waste that'll be.
Old 01-16-2005, 04:30 AM   #4
wolfman
wolfman's Avatar
Throttle plate or cable is sticking. Simple fix. Clean the throttle body and lightly lube the cable with some silicon spray lubricant or cable and chain spray lubricant. CLEAN IT FIRST though, well oiled dirt is no better than unoiled dirt.
Add to wolfman's Reputation
wolfman is offline
Old 01-16-2005, 04:34 AM   #5
avanwest
True I guess. My Sl2 gets about 17-23 mpg city and 27-30 hwy. As you know Honda's get way better mileage. I guess what is happening is that even though the engine is absorbing friction to slow the car it's RPM's are down at idle so really its burning less than the Saturn that holds the RPM's and slowly cruises down? Do you ever notice that when you are braking the RPM's fall then the car gears down and the RPM's jump way up causing you to surge forward then you have to push the brakes even harder? I had to buy EBC greenstuff front pads just to feel safe. Wonder what it's going to cost me in the long run for brake parts?
avanwest is offline
Old 01-16-2005, 06:58 AM   #6
freakerz
freakerz is on a distinguished road
freakerz's Avatar
Wasn't that related to PCV valve too?
Add to freakerz's Reputation
Rate the quality of this post and help freakerz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freakerz is offline
Old 01-17-2005, 07:33 AM   #7
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
You may want to check into replacing your ECTS. My SC2 gets about 37 highway mpg and 30 city - about 3 mpg less than that if it's winter. By that, Hondas don't get much better gas mileage.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline
Old 01-17-2005, 04:51 PM   #8
avanwest
Thanks for the advice, I have changed it to the newer brass one already. I'm thinking of checking th o2 sensor now.
avanwest is offline
Old 01-17-2005, 05:24 PM   #9
Razorbak
Razorbak's Avatar
Have you considered following wolfman's advice?
Add to Razorbak's Reputation
Razorbak is offline
Old 01-17-2005, 05:45 PM   #10
avanwest
Yes, already tried. Besides, absolutely no lag in throttle response in driveway. This condition only happens in drive. I think it's the normal way the transmission is geared that makes the car feel this way. I've also changed tranny fluid and filter nothing there for contamination. Otherwise the engine runs well, no codes etc. Only a nagging oil consumption issue - what's new right.
avanwest is offline
Old 01-17-2005, 06:03 PM   #11
wolfman
wolfman's Avatar
Saturn transaxles (automatics) do downshift much more noticablely during deceleration (foot off throttle or slowing down with partial throttle) than other cars in their class you may have driven. What you may be feeling could actually be normal. Reading your first post I thought you were saying that the car was actually fighting the brakes when you were trying to stop.
wolfman is offline
Old 01-17-2005, 07:07 PM   #12
avanwest
Glad to hear that. What I meant about the brakes is that I'm using them harder to stop this car than I do in other cars. The car is not actually fighting the brakes, just the opposite. I need to use the brakes to fight the surge when the car down shifts.
avanwest is offline
Old 01-18-2005, 06:00 AM   #13
K-1
K-1's Avatar
2008 Astra XR
Could it be the torque converter disengaging?
K-1 is offline
throttle body cleaning problem gordoloff S-Series Tech 12 03-21-2008 07:26 AM
Poor throttle response/ Tranny problem whayes2007 L-Series Tech 6 03-16-2008 11:28 AM
Odd Throttle Problem Greycat S-Series Tech 4 02-27-2005 12:26 PM
throttle problem...TPS? EGR? sps SOHC Miscellaneous Tech 11 11-04-2004 07:11 PM
SPS Throttle Body Problem... Saturn_x2001 Mods and Performance 2 07-19-2001 04:12 PM
