Old 12-29-2004, 09:58 AM   #1
blkmrideon22s
blkmrideon22s is on a distinguished road
blkmrideon22s's Avatar
1992 SL
Default 1993 saturn sl1 temp gauge
i have a 1993 saturn sl1 and for the past couple of weeks my car temp gauge has been reading cold even on a two hour drives my car never get's warm. so i replace the thermostatand the temperature switch but when my friend replace the temperature switch he didn't tighten all they way down becuase the bolt was starting to round off. so when i crank the car up and let it idie or try to drive the car it runs hot quick. i check the water pump and it's fine. so could it be that my head gasket is blown or what?
Add to blkmrideon22s's Reputation
Rate the quality of this post and help blkmrideon22s reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blkmrideon22s is offline
Old 12-29-2004, 11:49 AM   #2
emailer33
emailer33 is on a distinguished road
1993 SL2
Default Re: 1993 saturn sl1 temp gauge
may wanna check your coolant level. and describe what you mean by running hot. does it get to the line before teh H before it starts to settle down? or does it actually get to the red H line?
Add to emailer33's Reputation
Rate the quality of this post and help emailer33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emailer33 is offline
Old 12-29-2004, 12:08 PM   #3
blkmrideon22s
1992 SL
my coolant level fine. my temperature gauge gets just a little over the red line but i turn it off before it get to the h mark. could it be the temp gauge is not reading right because of the temperature switch is not all they way in?
Old 12-29-2004, 01:50 PM   #4
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
Feel the radiator, is it hot? If the radiator is not hot, then either the water pump doesn't work, the thermostat is bad, or there is lots of air trapped in the system.
Check the thermostat by placing it in boiling water. It should fully open. Make sure it's not put in backwards, also.
The temp sensor should still read the engine temperature, even if it is out a thread or 2.
Add to alleninpa's Reputation
alleninpa is offline
Old 12-29-2004, 02:01 PM   #5
Razorbak
Razorbak's Avatar
I don't think you can mount a Saturn thermostat upside down in it's housing and have it remain in place. JMHO. Never actually tried it, but I think the length of the spring and the location and the mounting tabs would prevent it from being mounted upside down.
Add to Razorbak's Reputation
Razorbak is offline
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 8 06-12-2012 08:34 PM
94 Saturn SC2 - Coolant boils over at 3/4 on temp gauge wscreate S-Series Tech 16 01-22-2010 01:37 PM
Another temp gauge question-'02 SL1 SL2Many S-Series Tech 3 10-08-2008 10:49 AM
SL1 temp gauge... spitbits1500 S-Series Tech 2 10-16-2005 07:35 PM
Temp gauge problems - 95 SL1 sps SOHC S-Series Tech 10 10-14-2005 09:32 PM
