Old 12-18-2004, 01:33 PM   #1
WEGoat
WEGoat is on a distinguished road
Dizzy Cam Position Sensor???
I am confused, to say the least. In some threads it says that SL's have cam position sensors and in others they say they don't. I have a '97 SL and want to know if it has one or not. Can someone please tell me???
Add to WEGoat's Reputation
Rate the quality of this post and help WEGoat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WEGoat is offline
Old 12-18-2004, 01:51 PM   #2
Default Re: Cam Position Sensor???
They don't. The PCM does a parlor trick, looking at when the coil pack fires and the different voltages of the wires for (IIRC) plugs 1 and 3, to send a make-believe cam pos signal.
Add to madpogue's Reputation
madpogue is offline
Old 12-18-2004, 02:28 PM   #3
sierrap615
sierrap615's Avatar
more detail here - http://www.saturnfans.com/forums/showthread.php?t=43380
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 12-18-2004, 03:47 PM   #4
Razorbak
Razorbak's Avatar
SLs have a crank position sensor, but no cam position sensor.
Add to Razorbak's Reputation
Razorbak is offline
Old 12-18-2004, 07:46 PM   #5
XenonGT
XenonGT is on a distinguished road
XenonGT's Avatar
No actual cam sensor.
Cam sensors are not that important anyway, they are mostly a back-up for the crankshaft sensor anyway, since a cam sensor would not be that accurate due to belt or chain slack.
Sandon Lettieri
1996 SL2 "The Green Beast" 139k :1997 Engine, Thermal Cat-Back
1993 Probe GT "My First Car" 135k : Hibernating in the Garage w/ 18 inch wheels
1999 SC2 "Ayane" 138k : Wife's car
Add to XenonGT's Reputation
Rate the quality of this post and help XenonGT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
XenonGT is offline
Old 12-18-2004, 09:13 PM   #6
wolfman
wolfman's Avatar
All "S" series SOHC/DOHC
CRANK shaft postion sensor = YES
CAM shaft position sensor = NO
(It is indeed just a function of the ignition system, there is NO physical part)
Add to wolfman's Reputation
wolfman is offline
P000A Cam Position Sensor skatethesea Astra Tech 17 02-16-2011 10:37 AM
Cam Position Sensor redux kellerje S-Series Tech 13 02-05-2009 07:20 PM
cam position sensor briansc1 S-Series Tech 5 09-09-2008 10:54 PM
Here we go again, PO340 Cam Position Sensor Tercero L-Series Tech 3 04-26-2007 07:59 AM
Cam Position Sensor??? WEGoat General Saturn Discussion 1 12-18-2004 01:35 PM
