Closed Thread
Old 12-02-2004, 02:43 PM   #1
Admiral Beez
Admiral Beez is on a distinguished road
Admiral Beez's Avatar
2000 SL2
Default Do compasses work better in Saturns?
I'm directionally challenged and need a compass in my car. I had one of one plastic globe on a sucker compasses on my Accord, but the car's metal kept messing with it. Since the Saturn is a lot less metal, would a compass work better?
Also, are Saturns' plastic panels less likely to be picked up on radar? Stealth car!
Add to Admiral Beez's Reputation
Rate the quality of this post and help Admiral Beez reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Admiral Beez is offline
Old 12-02-2004, 02:53 PM   #2
Jaseball
Jaseball will become famous soon enough
Default Re: Do compasses work better in Saturns?
The Saturn will still mess with a compass that is not designed to compensate for the metal.
I have the travel package on my Ion and when I first got the car and calibrated the compass it appeared to be off a significant amount. I was comparing it to the reading on a normal compass while in the car. After getting out of the car the compass matched the car.
I'd suggest getting the travel package or getting a compass that is designed to go on the inside of the car.
Add to Jaseball's Reputation
Rate the quality of this post and help Jaseball reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jaseball is offline
Old 12-02-2004, 03:02 PM   #3
VTHokie00SL2
VTHokie00SL2 will become famous soon enoughVTHokie00SL2 will become famous soon enough
VTHokie00SL2's Avatar
I would think the difference in metal content due to plastic exterior panels is negligible when you consider that the frame is still steel.
Celebrity Eurosport.
When the road gets a little nervous, take one of these.
Add to VTHokie00SL2's Reputation
Rate the quality of this post and help VTHokie00SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VTHokie00SL2 is offline
Old 12-02-2004, 04:06 PM   #4
kg6mvb
kg6mvb has a spectacular aura aboutkg6mvb has a spectacular aura about
kg6mvb's Avatar
2003 ION-1 Sedan
My hobby (obsession) is ham radio.
When my Saturn was new, I tried using a handheld radio, until I installed a real mobile rig. I was surprised that I had MORE problems with my signal getting out than in other (steel) cars I have driven (with same handheld radio on same route). Although the side panels are plastic, you still have a steel hood, roof and trunk lid, not to mention the spaceframe. Based on what I experienced, there is a LOT of steel in the car.
One more thing to keep in mind. Any wire with current flowing through it will have a magnetic field around the wire. This too can affect a magnetic compass.
Tom
Proud to be a member of both the Ham Radio and Saturn Cults.
Avitar is a Saturn V rocket engine.
Add to kg6mvb's Reputation
Rate the quality of this post and help kg6mvb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kg6mvb is offline
Old 12-02-2004, 04:26 PM   #5
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
No. Radar uses sound waves to reflect back and calculate distance. It doesn't matter if it's steel, fibreglass, or polymer.
Lidar (laser) uses light waves for the same purpose. However, certain surfaces and colors react differently.
Hard to beleive there is an "Admiral" who is directional challenged.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline
Old 12-02-2004, 07:57 PM   #6
John10
John10 will become famous soon enoughJohn10 will become famous soon enough
2006 ION-3 Sedan
2009 VUE 2.4L
I agree with getting the travel package if you want an accurate compass. In addition to the compass you get a self dimming rear view mirror, an outside temperature read out on the mirror, and very useful map lights.
Add to John10's Reputation
Rate the quality of this post and help John10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
John10 is offline
Old 12-02-2004, 08:16 PM   #7
Admiral Beez
2000 SL2
Thanks all, but it's for my 2000 SL2 that I want the compass. Any suggestions?
Thanks for the note on radar. During the Second World War, aircraft made primarily of wood, such as the DeHavilland Mosquito gave far smaller returns on German radar than similiarly sized metal aircraft. If Saturns were made of wood, would they show up on police radar?
Old 12-03-2004, 09:24 AM   #8
Specialist
Specialist will become famous soon enough
Specialist's Avatar
I bought a compass for an old Jeep truck I used to own. It had an adjustment on the back of it so it could be calibrated. I parked the truck with all the electronics on (amplified radio, CB radio, etc.), and then found true North with a "good" hand held compass a few feet away from the truck. Once I calibrated the compass in the truck to match the hand held compass, I had no issues.
Check out Canadian Tire - search for "compass" -
http://www.canadiantire.ca
Add to Specialist's Reputation
Rate the quality of this post and help Specialist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Specialist is offline
Old 12-03-2004, 12:18 PM   #9
OhioVueBoy
OhioVueBoy has a spectacular aura aboutOhioVueBoy has a spectacular aura aboutOhioVueBoy has a spectacular aura about
OhioVueBoy's Avatar
Location: N. Bethesda, Maryland (DC) (Dayton Ohio Native)
2002 VUE 2.2L
Search for aftermarket autodimming mirror on here. It is a bit more of a pricey install, but with these, you get a compass, autodimming mirror, and an outside temperature readout.
~D.J.~
2012 Mercedes Benz C250 Sport Sedan
2008 smart fortwo Passion Coupe 8/28/2008 - 3/12/2012
2002 VUE FWD4m - Gone but not forgotten. 5/14/2002 - 10/31/2011
Add to OhioVueBoy's Reputation
Rate the quality of this post and help OhioVueBoy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OhioVueBoy is offline
Old 12-03-2004, 12:29 PM   #10
hugh
hugh will become famous soon enough
JohnS;
Are you sure about the outside temp readout feature ? My 2004 L300 has the auto dimming rearview mirror option and it doesn't have this feature.
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline
Old 12-03-2004, 01:48 PM   #11
TBone1082
TBone1082 will become famous soon enough
TBone1082's Avatar
2003 ION-3 Quad Coupe
Ion's and Vues both have the Travel Package option, which includes the Autodimming mirror, with compass and outsie temp gauge included on the right side.
STC-NY
Sales Consultant @ Saturn of Medford
Number 4 in line for a 2007 Sky Redline!
Black w/Black leather, Tan Inserts
LSD, Single CD Monsoon System, and Spoiler.
Add to TBone1082's Reputation
Rate the quality of this post and help TBone1082 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TBone1082 is offline
Old 12-03-2004, 07:03 PM   #12
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Originally Posted by hugh
JohnS;
The L has a different autodimming mirror than other Saturns. The L does not have this feature. The only outside temp readout available on the L series ever was in the automatic climate control head unit for 2002 and 2003.
~D.J.~
Old 12-03-2004, 07:15 PM   #13
John10
2006 ION-3 Sedan
2009 VUE 2.4L
JohnS;
Hugh- I saw your question but T-bone has already answered it for me.
John10 is offline
Old 12-03-2004, 07:23 PM   #14
John10
2006 ION-3 Sedan
2009 VUE 2.4L
Admiral Beez- Since you interjected the subject of old warfighting equipment into this thread, would you please identify the battleship on you avitar? Based on what I can see I'm guessing its something like USS Nevada (or a similar ship from that era) but I can't see enough to be sure.
John10 is offline
Old 12-04-2004, 09:20 AM   #15
Admiral Beez
2000 SL2
That's HMS Queen Elizabeth, first of Britain's fast battleships (everyone else was doing about 21 knots), pictured prior to her 1930s modernization.
QE's details as originally designed (per www.hazegray.org):
Displ: 33,500-34,000 tons full load
Dim: 645.5 x 90.5 x 28.5 feet
Prop: Steam turbines, 24 boilers, 4 shafts, 56,000 hp, 25 knots
Crew: 925-951
Arm: 4 dual 15/42, 14 single 6/45, 2 3 inch AA, 4 21 inch TT (sub)
Armor: 6-13 inch belt, 1-3 inch deck, 4-10 inch barbettes, 13 inch turrets, 11 inch CT
I found the Avatar picture at Vicker's photo archive, see.. http://www.dockmuseum.org.uk/archive/index.asp Vickers was one of the Empires most productive and important shipyards. The still make all of Britainís nuclear submarines, but not at this yard.
If you check out http://p216.ezboard.com/bwarships1discussionboards you'll see me, Admiral Beez all over the forums. Military history is one of my hobbies.
As for Nevada, see http://www.hazegray.org/navhist/batt...usa/bb36-2.jpg
You'll notice she has the cage masts, which were typical on USN battleships until after Pearl Harbour. British battleships used a tripod mast, the base of which you can see on my Avatar. Now after Pearl Harbour, Nevada was reconstructed as follows http://www.hazegray.org/navhist/batt...usa/bb36-7.jpg with a small tripod mast, so perhaps that's where the similarities are. Lastly, don't forget that Nevada's 14" "A" turret (closest to the bow) was a triple mount (three guns per turret) as opposed to Queen Elizabeth's dual 15" mounts (two guns per turret) all round.
Britain only tried triple mounts in one British design, the Nelson class battleships, with 9x16" guns, but they were a troublesome design (see http://www.chuckhawks.com/hmsnelso.jpg). They did make triples for the Italian navy, see http://www.dockmuseum.org.uk/archive...itle=Naval+Gun.
Britain's King George V class battleships had two four gun turrets, which looked impressive, IMO see http://www.dockmuseum.org.uk/archive...ect=&subtitle=
and http://www.chuckhawks.com/kgv1941.jpg
Britain also made battleships and/or major warships for many foreign navies, such as Chile, Brazil, Argentina and Japan including the Japanese battleship Kongo, see http://www.dockmuseum.org.uk/archive...ect=&subtitle=
and http://www.history.navy.mil/photos/i...000/h90506.jpg
which was sunk by the American submarine USS Sealion on 21 November 1944.
Old 12-04-2004, 09:26 AM   #16
Admiral Beez
2000 SL2
The hazegray links to the USS Nevada pictures don't seem to work. Go to www.hazegray.org directly and look for the Nevada pics.
Old 12-04-2004, 09:50 AM   #17
John10
2006 ION-3 Sedan
2009 VUE 2.4L
Thumbs Up Re: Do compasses work better in Saturns?
Thanks for the links Admiral. I actually was able to find photos of Nevada here after I read your post.
http://www.chinfo.navy.mil/navpalib/.../bb36-nev.html
You are correct about the front turret having three guns. I based my guess on an artists rendering of Nevada on a battleship shirt I own. The shirt shows a two gun turret and I regret now to say it is in error. Check the photo of Nevada after the Pearl Harbor attack however and it appears to me that the conversion from a cage to a tri-pod upper mast was indeed made before the Japanese attack. Unfortunately I never saw Nevada as the Bikini atomic tests took place before even I was born. LOL
Incidently here is a link to a newly posted dictionary of US warships. Enjoy the whole site but click on to the newly added dictionary link if you are not aware of it.
Couple of other links you might find interesting if you don't know of them already;
http://www.kbismarck.com
http://hmshood.com
Thanks again for the links.
John10 is offline
Closed Thread
Plastic Welding Tool, Work on Saturns ? Fallguy S-Series Tech 7 08-05-2009 02:56 PM
Choice between two used Saturns ? (New to Saturns) cboss S-Series General 25 10-16-2008 05:51 PM
To work...Or not to work...At a Saturn Dealership? koasterking General Saturn Discussion 11 08-09-2007 07:12 PM
Unshure how saturns work and need help... Southern Clown S-Series Tech 7 09-20-2005 12:44 AM
Now we have 3 Saturns Mike_SW2K Ion General 9 09-23-2003 10:59 PM
