Old 11-19-2004, 09:18 AM   #1
el bon bon
el bon bon is on a distinguished road
Wrench DOHC Valve Cover Gasket Replacement on 1995 SW2
95 Saturn SW2-DOHC valve cover gasket replacement
This model has an aluminum cover with ten, T-40 bolts. It requires a gasket.
1. Disconnect the pcv valve, air filter housing hose to the valve cover and the spark plug boots, push them to one side out of the way, now remove all T-40 bolts and remove the valve cover. You may have to tap the edges of the cover with a rubber mallet to free it. The bolts, rubber inserts & washer over the bolts can be used again, just check to see if the rubber doesnít have cracks, if so replace them.
2. Clean all the bolt components and put them aside. I shake them in a small glass jar with a cleaning fluid, use anything that wonít destroy the rubber.
3. The cover has grooves where the gaskets go so make sure you do a very good job in cleaning off all of the old gasket material and oil residue from both surfaces. Remember the cover is aluminum and can be damaged using a rough steel brush. I use a paint scraper, a fine brass brush and a small screwdriver that fits into the valve cover groove. Try not to gouge the aluminum. At times the inside of the valve cover is so bad, I have it steamed cleaned at a shop for 5 bucks. Washing with soap & water also works. When everything is cleaned & dried, put some break cleaner on a lint free rag and wipe all the surfaces where the new gasket goes.
4. I have had problems using RTV for the gasket on this model & if it starts to leak, it is a mess removing the RTV gasket once it has cured so I bite the bullet and purchase Saturnís pre made gasket. The gasket they sell is heat cured & cost $42.00 Itís better then doing it over again.
5. The new gasket tends to fall out when replacing the valve cover so I use a thin coat of solventless silicon liquid gasket in the grooves of the valve cover before inserting the new gasket. Saturn sells a 3oz tube for a few bucks, you can find some in most auto stores. Just make sure you use plastic gloves because liquid gasket can be very harmful to your eyes if you rub them after the stuff is on your fingers. Read the caution label.
6. Replace the valve cover carefully, make sure it is level and over the bolt holes.
Donít push the valve cover down with a lot of pressure, it may not be aligned yet.
7. Make sure the bolts have the rubber and washer attached and install all the bolts a few
turns by hand, this will help with the alignment. Use a ratchet and slowly turn each bolt until you feel a slight pressure and stop. Use the sequence below.
8. Set your torque wrench to 10 foot lbs and follow the sequence below. Yes, 10 foot lbs
for this model. The max is 15 foot lbs. When in doubt, talk to a Saturn mechanic,they are usually very helpful. I have found some after market manuals have misprints on the torque specs & they sometimes confuse the models.
Intake Manifold
5 7
10 3 1 2
9
4 6 8
Exhaust Manifold
9. Now set your torque wrench to 15 foot pounds & follow the same sequence.
10. Reconnect the pcv valve, air filter housing hose to the valve cover and the spark plug boots. Start the engine and run at idle for 45 min. The heat will cure the gasket. You shouldnít have any leaks. After a few days, change the oil & filter to remove any containments.
As an added note, the two spark plug cylinders close to the timing chain take a lot of oil hits from the oil jets which could be the reason why these gaskets are the first to be penetrated with oil. Just an opinion, the jury is still out. Also some people will add a small amount of RTV around the washers and rubber on the three center bolts before they install them to block oil from penetrating.
Happy driving.
Add to el bon bon's Reputation
Rate the quality of this post and help el bon bon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
el bon bon is offline
Old 02-20-2005, 01:36 AM   #2
amazinghl
amazinghl is on a distinguished road
Default Re: DOHC Valve Cover Gasket Replacement on 1995 SW2
WARNING
Let the RTV dry at least 24 hrs before you turn on the engine, or else it IS going to leak.
Please follow this instruction from thread instead.
http://www.saturnfans.com/forums/sho...ht=valve+cover
Add to amazinghl's Reputation
amazinghl is offline
Old 02-20-2005, 02:31 PM   #3
Luke
Luke's Avatar
>> el bon bon <<
> As an added note, the two spark plug cylinders close to the timing chain take a lot of oil hits from the oil jets which could be the reason why these gaskets are the first to be penetrated with oil. <
We continue to learn -- thank you
Add to Luke's Reputation
Luke is offline
Old 02-21-2005, 11:06 PM   #4
RadioRon
RadioRon is on a distinguished road
How frequently do these gaskets go bad?
I have just over 60k on my '96 SW2 and I believe the gasket is leaking because I am getting oil dripping (apparently and mostly) down the back side of the engine.
Add to RadioRon's Reputation
Rate the quality of this post and help RadioRon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RadioRon is offline
Old 02-21-2005, 11:22 PM   #5
Razorbak
Razorbak's Avatar
Every 32,143.762 miles, like clockwork.
j/k - there's no predictable timeline.
Add to Razorbak's Reputation
Razorbak is offline
Old 02-22-2005, 07:07 AM   #6
RadioRon
OK. Thanks. At 60k+, then, I guess I did allright in making it this far without needing the repair.
RadioRon is offline
'97 DOHC valve cover gasket danerdman1234 S-Series Tech 5 12-21-2009 03:47 PM
HELP! 1995 SL2 Valve Cover Gasket! ach95 S-Series Tech 13 08-22-2008 04:06 PM
92 DOHC valve cover gasket ?S Park Style S-Series Tech 9 05-07-2008 01:49 AM
FS: Cam/Valve Cover from 1995 DOHC - $30/shipped delturcious Classifieds 1 07-29-2006 03:55 PM
DOHC Valve Cover Gasket, does anybody make one? Fricken eh! Miscellaneous Tech 5 08-16-2004 07:23 PM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
