Old 11-18-2004, 11:34 AM   #1
johnnyvue
johnnyvue is on a distinguished road
Default Horn/security problem
Ok, here is a weird one.... I lock my VUE using the fob and about 10 seconds later the panic starts going. I sat inside the VUE and did it and it looks like the car locks at first but the security dummy light blinks and then the chime goes off really fast then the dome light comes on and it starts going crazy. I have checked all the door plungers and they work just fine apparently (I did have a broken passenger side one a while ago). I brought it to the dealer and the said they couldn't pinpoint it so they just reprogrammed the computer. I am almost out of warranty and I need to know what to tell them, help!!
Add to johnnyvue's Reputation
Rate the quality of this post and help johnnyvue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnnyvue is offline
Old 11-18-2004, 11:37 AM   #2
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default Re: Horn/security problem
Sounds like a BCM . Computer
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 11-18-2004, 12:29 PM   #3
revue
revue is on a distinguished road
revue's Avatar
Does the dome light operate correctly when opening any of the four doors and rear hatch?
Add to revue's Reputation
Rate the quality of this post and help revue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
revue is offline
Old 11-18-2004, 01:04 PM   #4
johnnyvue
I have it set to "door" and when you shut the doors it stays on.
Old 11-18-2004, 01:37 PM   #5
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
That's the problem. One of the door sensors has failed most likely.
~D.J.~
OhioVueBoy is offline
Old 11-18-2004, 01:55 PM   #6
johnnyvue
Seems like it... When the thing tripped, I opened and shut the driver's door and then the keyless lock worked, but the security light still came on and started panic again.
Old 11-18-2004, 02:08 PM   #7
revue
revue's Avatar
The BCM sets off the alarm when it detects one of door switches activated.
So, you have either:
1. A bad door switch.
2. Open or shorted wire between a door switch and the BCM.
Also, one of the connectors on the back of the BCM might be loose.
3. A bad BCM.
Probably #1 or #2.
You're the guy that used the vacuum cleaner cord for something, right?
revue is offline
Old 11-18-2004, 06:57 PM   #8
johnnyvue
Haha yeah I rewired all of that a long time ago so it is good to go. The door thing just started last week. Thanks for your help!
security light problem 2RINGS L-Series Tech 6 04-17-2008 08:04 AM
2007 Vue Horn & Security System Problem SPARKYTAM Vue Tech 2 12-05-2007 04:33 PM
security problem bastet L-Series General 1 06-27-2005 09:29 AM
Security problem - HELP Please! Shanin S-Series General 1 01-12-2004 01:12 AM
Saturn stock security problem monkeysl2 Miscellaneous Tech 8 08-07-2003 01:24 PM
