Old 11-13-2004, 02:43 AM   #1
wolfman
wolfman's Avatar
Information S-Series Torque Specifications
Torque Ft/Lbs Unless otherwise indicated!
91/92 Models
A/C Compressor Bracket to Engine Bolts 19
A/C Compressor to Front Bracket Bolt 40
A/C Compressor to Rear Bracket Bolt 19
Accessory Belt Idler Bolts 33
Accessory Belt Tensioner Bolts 22
Axle Shaft Support Bracket to Engine Bolts 41
Camshaft Sprocket Bolt 75
Connecting Rod Cap Nut 33
Cradle to Body Bolts 151
Crankshaft Sprocket Bolt 158
Cylinder Head Bolt (In criss-cross sequence from center OUT)
DOHC-
Tighten all bolts in sequence to 22ft/lbs.
Then tighten all bolts to 37ft/lbs.
Repeat sequence, tightening all bolts an additional 1/4 turn.
SOHC-
Then tighten all bolts to 33ft/lbs.
Engine Block Drain Plug 26
Engine to Transaxle Stiffening Brackets 40
Exhaust Manifold Retaining Nuts
DOHC 23
SOHC 16
Exhaust Pipe to Manifold Nuts 23
Flex Plate to Crankshaft 44
Flex plate to Torque Converter Bolts 41
Flywheel to Crankshaft 59
Front Engine Mount 52
Front Pulley to Crankshaft Bolt 159
Front Strut to Knuckle Bolt 148
Fuel Lines 19
Intake Manifold Retaining Nuts 22
Intake Manifold Support Bracket to Engine Bolt
DOHC
LH Side 22
RH Side 41
SOHC 22
Main Bearing Cap Bolts 37
Oil Pan Dran Plug 26
Power Steering Pump Retaining Bolts 27
Rocker Arm Shaft Bolts 19
Starter Motor Retaining Bolts 27
Throttle Body Bolts 23
Timing Chain Guide Bolts
Fixed 21
Pivoting 19
Torque Axis Mount to Engine Nuts 52
Torque Strut to Cradle Brackets 52
Transaxle to Block Bolts
Lower 96
Upper 66
Water Pump to Block Bolts 22
Water Pump Pulley Bolts 19
Wheel Lug Nuts 103
Cam Cover Bolts 89IN lbs
Camshaft Bearing Cap Bolt 124
Coolant Sensor 71 IN lbs
Crankshaft Seal Housing to Block Bolts 97 IN lbs
Front Cover Bolts
Lower Center Bolt 89 IN pds
Perimeter and Upper Center 22
Fuel Line to Fuel Rail 133 IN lbs
Fuel Line to Fuel Pressure Regulator 133 IN lbs
Oil Pan Bolts 80 IN lbs
Oil Pump Cover Screws 97 IN lbs
Starter Motor Bracket 80 IN lbs
Timing Chain Tensioner Bolts 168 IN lbs
93-97 Models
Crankshaft Pulley/Balancer Bolt 159
Cylinder Head Bolt (In criss cross sequence from center OUT)
DOHC
SOHC
Engine Mounts
Front Mount to Block 52
Rear Mounts 35
DOHC 23
SOHC 16
Front Cover
Except Lower Center Bolt 22
DOHC 22
SOHC 15
Oil Pan Darn Plug 26
Strut to Steering Knuckle Bolt 148
Throttle Body Bolts 24
Timing Chain Guide Bolts 19
Timing Chain Tensioner Bolt 14
Torque Axis Mount to Engine Nuts 37
Lower 96
Upper 66
Wheel Lug Nuts 103
Cam Cover Bolt 89 IN lbs
Camshaft Bearing Cap Bolt 124 IN lbs
Front Cover Lower Bolt 89 IN lbs
Fuel Line to Fuel Pressure Regulator Nut 133 IN lbs
98-01 Models
Accessory Belt Idler Bolts 22
Clutch Pressure Plate 19
Cylinder Head Bolt (In criss cross sequence from the center OUT)
DOHC
SOHC
Engine Mounts
Front Mount to Front Cover 37
Rear Mounts 35
DOHC 150 IN lbs
SOHC 16
Flex plate to Torque Converter Bolts 52
Front Cover
Lower Center Bolt 89 IN lbs
Oil Pan Drain Plug 27
Power Steering Pump Retaining Bolts 22
Spark Plugs 20
Lower 96
Upper 66
Wheel Lug Nuts 103
Cylinder Head Cover Bolt 89 IN lbs
Add to wolfman's Reputation
wolfman is offline
Old 11-13-2004, 02:51 AM   #2
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: "S" Series torque specifications
Thought it was 126...I don't have any literature to back me up, but iirc it's 126 ft/lbs. If not, then i've been wrong for quite some time...Hahaha...
Anyways, Great reference tool, wolfman!
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline
Old 11-14-2004, 10:36 AM   #3
freakerz
freakerz is on a distinguished road
freakerz's Avatar
From Hayne's:
Strut-to-suspension knuckle bolts/nuts
1995 and earlier .... 148lbs
1996 ................... 126lbs
Enjoy! I'll check others later since I'll make this a guide on csq.com
Add to freakerz's Reputation
Rate the quality of this post and help freakerz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freakerz is offline
Old 12-01-2004, 12:55 AM   #4
hckysakpro
hckysakpro is on a distinguished road
sorry i'm confused, I am not sure what exactly the list is saying. If someone could explain that would be really helpful.
thank you.
Add to hckysakpro's Reputation
Rate the quality of this post and help hckysakpro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hckysakpro is offline
Old 12-01-2004, 08:44 AM   #5
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Wrench Re: "S" Series torque specifications
thank you.
Torque is the force used to rotate things. Our cars have lots of bolts and nuts. If we don't tighten them enough then they might loosen. If we tighten them too much then we can damage things. Wolfman provided lists of how tight bolts and nuts and stuff need to be tightened. The units for torque are foot-pounds (as in distance and weight) for SAE and newton meters for metric. There are other units for torque too such as inch-pounds (12 inch-pounds = 1 foot-pound), newton-centimeters, millinewton-meters, etc. and these are less common. We use a "torque wrench" when applying force to rotate bolts and such. Torque wrenches come in a few varieties and they range in price from between $10 and to amounts exceeding $200. I'd guess that a decent torque wrench costs between $30 and $80. Anybody that does the most basic car maintenance to include swapping their wheels/tires around should have a torque wrench in their tool collection.
As of May 2018
∙ 2004 VUE 123K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 12-01-2004, 02:12 PM   #6
hckysakpro
right on, thanks.
i was thinking like the power in your engine, but thanks for clearing it up. makes sense
Old 12-01-2004, 03:31 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
(Torque x Engine speed) / 5,252 = Horsepower
Torque is a force that tends to rotate or turn things. We generally express force from an engine or motor in pound-feet and torque needed to tighten a fastener in
foot-pounds.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 01-05-2005, 10:06 PM   #8
cardocr
cardocr is on a distinguished road
Default Re: S-Series Torque Specifications
What is the torque specification for the intake manifold retaining bolts on a 2000 Saturn SL2 with the new plastic intake? The post above indicates 22 ft lbs but that is the same spec as the cast iron intake. I would think it might be lower for the plastic intake. Thanks.
Add to cardocr's Reputation
Rate the quality of this post and help cardocr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cardocr is offline
Old 01-05-2005, 10:35 PM   #9
The intake manifold-to-head are 13 Nm (9.5 lb ft).
The EGR pipe-to-cylinder head is 25 Nm (19 lb ft).
Add to ssicarman's Reputation
ssicarman is offline
Old 02-05-2005, 09:44 PM   #10
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Wrench
The torque spec for the thermostat housing bolts is 22 ft. lbs.
As always, be sure to use a 6-point socket as the 12-point sockets are likely to "round" the hexagonal heads of the bolts.
As of May 2018
∙ 2004 VUE 123K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-11-2005, 06:50 PM   #11
1nf3st
1nf3st is on a distinguished road
so does a torque wrench have an adjustable torque setting like an electric screwdriver to prevent a bolt to be over tightened?
Add to 1nf3st's Reputation
Rate the quality of this post and help 1nf3st reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1nf3st is offline
Old 04-11-2005, 07:02 PM   #12
Razorbak
Razorbak's Avatar
Depends on the type of torque wrench. Clicker types do. Beam types don't.
Add to Razorbak's Reputation
Razorbak is offline
Old 04-11-2005, 07:23 PM   #13
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Torque Wrenches
http://home.jtan.com/~joe/KIAT/kiat_3.htm
There are two common types of torque wrenches for home shop use; the "beam" type and the "clicker" type. The beam type torque wrench is shown in Figure 1c and is the least expensive torque wrench. The beam wrench works by the beam bending in response to the torque applied as shown in Figure 2c. This type is very simple, reliable, and accurate, and there is little that can go wrong with it when used properly. When tightening a bolt, make sure to only apply force in the center of the handle. This allows the beam to bend in the manner it was designed to indicate the correct torque. Do not over torque the wrench or the beam may bend permanently. Do not drop the wrench because rough handling can bend the pointer arm or pointer. If the pointer is bent, it can be bent back to the center without affecting accuracy. If the beam is bent it cannot be bent back.
Figure 3c shows the clicker torque wrench, which is sometimes called a digital wrench. A clicker torque wrench works by preloading a "snap" mechanism with a spring to release at a specified torque. When the mechanism releases the ratchet head it makes a "click" noise as shown in Figure 4c. The torque is set by rotating the handle until the desired torque is shown in the window. Older clicker wrenches have a micrometer style scale along the handle instead of a window. The clicker wrench is much easier to use because it is easy to set the desired torque and just pull until you feel the click. The ratchet head also makes it easy to use in confined spaces. It is good practice to set a clicker wrench to its lowest setting before putting it away to prevent the spring from taking a set. Avoid rough handling and dropping because it can damage the mechanism. Do not use the torque wrench to loosen tight fasteners since this may damage the calibration.
As of May 2018
∙ 2004 VUE 123K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-19-2005, 08:33 PM   #14
kickarse
kickarse is on a distinguished road
hey you rock thanks!
02 Saturn L200 - 156k miles - Black on Black
- HIT! 96 Saturn SL2 - 172k miles - Fire Red
- SOLD 97 Saturn SL1 - 126k miles - Green/Brown Speckle
Add to kickarse's Reputation
Rate the quality of this post and help kickarse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kickarse is offline
Old 09-04-2005, 02:26 AM   #15
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Information Re: S-Series Torque Specifications
Lower control arm to frame as per Autozone for 1991 thru 1998.
"Tighten the cradle bolt to 92 ft. lbs. (125 Nm), then tighten the cradle nut to 74 ft. lbs. (100 Nm)."
Add to peppermrj's Reputation
Rate the quality of this post and help peppermrj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peppermrj is offline
Torque specifications... p8ntballsniper8 S-Series Tech 4 09-14-2013 01:35 PM
1997 Saturn S-Series Specifications ... cfg83 S-Series General 5 09-29-2007 05:28 AM
Nut Torque Specs for 1999 SL2 Torque Axis Mount todd8 S-Series General 3 05-01-2005 12:34 AM
S-Series Specifications Manual SaturnTech S-Series General 0 02-17-2005 01:28 PM
torque specifications craftyone Miscellaneous Tech 2 10-28-2003 10:46 PM
