Old 11-03-2004, 01:39 PM   #1
roswell998
Guest
Posts: n/a
Question ECT sensor.....does it drive temp gauge as well as PCM input?
Would a properly working temp gauge on a 96SL2 imply that ECT sensor is probably OK?
Add to roswell998's Reputation
Rate the quality of this post and help roswell998 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-03-2004, 01:41 PM   #2
freakerz
freakerz is on a distinguished road
freakerz's Avatar
Default
mm.. SL2 of that year have 1 ECTS.. and its used for PCM and Gauge..
Add to freakerz's Reputation
Rate the quality of this post and help freakerz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freakerz is offline
Old 11-03-2004, 01:56 PM   #3
sierrap615
sierrap615's Avatar
Default
yes, 96+ use just one sensor (or was it 95? i can never remember)
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 11-03-2004, 03:10 PM   #4
freakerz
freakerz's Avatar
Default
hehe me2 I think its 95+
freakerz is offline
Old 11-03-2004, 05:28 PM   #5
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default
I think they went to 1 sensor when they switched to OBD2, so that would be 96+...
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
Add to bennett9000's Reputation
Rate the quality of this post and help bennett9000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bennett9000 is offline
Old 11-03-2004, 08:25 PM   #6
Bsmith
Bsmith is on a distinguished road
Default
Yup my 95 SC2 has two of them. One for PCM one for gauge.
Sold it when I moved. sniff... sniff....
'95 SC2 funky rootbeer color. Yes I know black gold.
Add to Bsmith's Reputation
Rate the quality of this post and help Bsmith reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bsmith is offline
Old 11-03-2004, 10:53 PM   #7
bennett9000
Default
BOO-YAH!
-Andy
Old 11-03-2004, 11:06 PM   #8
wolfman
wolfman's Avatar
Default Re: ECT sensor.....does it drive temp gauge as well as PCM input?
Not necessarily. Just because the gauges "seems" to be reading right or simply works, does not mean that the ECT sensor is actually good. If your 96' still has the OEM sensor in it in fact, I can almost guarnatee it isn't. IF it has been replaced with the updated all brass unit (to your firsthand knowledge) and you have acceptable starting and fuel economy behaviors as well as a gauge that rises and falls normally and, more importantly, a RADIATOR FAN that SELF ACTIVATES on cue, odds are the ECT sensor is fine.
Add to wolfman's Reputation
wolfman is offline
Old 11-04-2004, 01:01 AM   #9
Default
96 and up with the single temp sensor the gauge is feed information from the PCM which gets it from the temp sensor. If the temp sensor is out the the gauge will be out as well.
Add to ssicarman's Reputation
ssicarman is offline
No Dtc's,good Ect Sensor Temp Gauge High BEAMECH S-Series Tech 13 02-13-2008 05:34 AM
ECTS and Temp Gauge Sensor Wiring WingsOfSaturn S-Series Tech 7 10-22-2005 09:45 PM
Coolant Temp Sensor - Fan or Gauge? petemcs Miscellaneous Tech 3 01-05-2004 10:37 AM
New Engine and radiator.. Temp gauge input needed!!!! sideout303 S-Series Tech 5 11-25-2003 11:41 PM
93sl1 PCM coolant temp sensor question 93sl1 S-Series Tech 8 09-17-2001 09:13 AM
