Old 09-30-2004, 05:37 PM   #1
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default Is it OK to powerwash the my SW2 Engine?
The entire car is CLEAN, except the engine is COVERED in a layer of dust. Can I safely take this down to the coin-op carwash and powerwash the engine/trans? Anything I should be careful NOT to spray (Other than the DIS Coils, obviously)
TIMSPEED is offline
Old 09-30-2004, 06:24 PM   #2
BlackBirdRacing
BlackBirdRacing is on a distinguished road
BlackBirdRacing's Avatar
Default
yes
be careful
BlackBirdRacing is offline
Old 09-30-2004, 06:26 PM   #3
Razorbak
Razorbak's Avatar
Default
I would recommend using a garden hose with a light spray feature rather than any type of power sprayer. Spray everything with a little Simple Green degreaser first, and let it soak for about 15 minutes before spraying everything off. I usually cover the DIS coilpacks with a piece of Saran wrap or a sandwich baggie, held in place by a piece of string or a large rubber band, to keep the coils dry.
Razorbak is offline
Old 09-30-2004, 06:50 PM   #4
TIMSPEED
TIMSPEED's Avatar
1998 SW2
Default
Well, if it comes down to it, I'll just pull the coil packs OFF, since it's easy enough. Then I can spray the block/bellhousing to my hearts content.
TIMSPEED is offline
Old 09-30-2004, 07:56 PM   #5
wolfman
wolfman's Avatar
Default
I would likewise recommend AGAINST using a pressure washer. There are ALOT of connectors under the hood that while they are "weatherproof" to an extent, they CAN be compromised by a high pressure spray. Why invite trouble. A spray of Simple Green or Castrol Superclean followed a few minutes later (COLD ENGINE!) by a GENTLE clean water rinse should do nicely.
wolfman is offline
Old 09-30-2004, 11:38 PM   #6
sierrap615
sierrap615's Avatar
Default
don't use a pressure washer, that would be very bad. on older cars from the 60s or 70s, this may have worked. but on today's cars the damage would two fold. first there are countless sensors and modules and solinoids and blahblahblah, much more then any older car. second, and more importently, all the wiring connection have weather seals, which work great normally. but with a lot of pressure, not only will the weather seals fail, when the pressure returns to normal, water becomes trapped inside the seals and connectiors, and its not that it may corrode, its that it WILL corrode.
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 10-01-2004, 09:26 AM   #7
BlackBirdRacing
Default
yeah I use simple green all the time.. I forgot to mention that.
It rules!!
Old 10-01-2004, 12:48 PM   #8
eljefino
eljefino's Avatar
1995 SW1
Default
Maybe a gentle steam clean would be better. Most road grime is held on with at least some oil. The less water, the better-- and a hot engine block mixed with hot steam and a stiff brush could be the ticket.
eljefino is offline
Old 10-01-2004, 02:01 PM   #9
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Default
I recommend simple green, letting it sit for a few minutes and then a gentle rinse with the garden hose.
Kevin
Kevin94SL is offline
sw2 engine cradle augey S-Series Tech 3 03-20-2008 06:27 AM
What's the difference between a 98 Sl2 engine and a '95 SW2 engine? redkees@msn.com S-Series Tech 5 01-29-2006 12:43 AM
'97 SW2 engine swap jk3006 S-Series General 1 12-29-2005 04:20 PM
93 SW2 blown engine,..will 94 SW2 work? riprocop S-Series General 7 12-11-2005 06:32 PM
98 SW2 Engine Code Urbanrover S-Series Tech 1 04-05-2005 11:55 PM
