Old 09-30-2004, 05:06 AM   #1
SL1Joe
SL1Joe has a spectacular aura aboutSL1Joe has a spectacular aura about
SL1Joe's Avatar
Question Charging System Issue
Yesterday while running an errand the Alternator Light came on, at first I wasn't paying attention but I noticed the clock light wasn't quite as bright as before then I noticed the light on, about now i'm thinkin greeeat I aint had the car a week and already theres a problem. Anyhow I got it home fortunatley I wasn't far from my house when this happened. Natually I assumed the Alternator at first but I wanted to be sure and checked all the connections (Battery, ALT wires, etc) to see if maybe something rattled loose, everything looks good belt had sufficent tension.
Btw the light never went off stays on consistantly so I know it's not intermittant.
Any ideas on what the problem might be, ALT possibly?? Only thing I can think to do is take the Alternator into Kragen or AutoZone and have it tested. I would of course prefer to do that while it's still in the car but with it running at a discharge I don't wanna weaken the battery any furthur by driving it over there, fortunatley I have two other vehicles here but unlike the Saturn their batteries use Top Terminals so can't interchange them.
Car Info - 1995 SL1 (about 114,500 miles)
Add to SL1Joe's Reputation
Rate the quality of this post and help SL1Joe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL1Joe is offline
Old 09-30-2004, 06:50 AM   #2
okpatioman
okpatioman is on a distinguished road
Default
You can take your car to Autozone or O'reilly's where they will test it free. My alternator went bad on my 94 SL2 but never got a light, just the battery wasn't charging and Autozone said it was bad. I bought a new one and once I put it on, my alt light came on and stayed on. I took it back to Autozone so they could test the new old. They said it was over charging so they gave me another one.
I haven't had any problems since.
Add to okpatioman's Reputation
Rate the quality of this post and help okpatioman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
okpatioman is offline
Old 10-01-2004, 11:01 PM   #3
wolfman
wolfman's Avatar
Default
Simple alternator HOME test.
Lossen but do not remove the POS battery cable at the battery
BE CAREFULL NOT to touch ANY part of the car with the tool you use to loosen the POS battery cable post while it is also in contact with the post itself!
Start the car
With the car RUNNING, CAREFULLY remove the Positive battery cable completely from the battery post.
Did the car quit? If YES, the alternator is SHOT.
IMPORTANT NOTE: DO NOT reconnect the POS cable during this test with the engine RUNNING! DO NOT drive the car or leave it running for more than 1~2 minutes MAX with the cable disconnected!
Add to wolfman's Reputation
wolfman is offline
Old 10-02-2004, 10:03 AM   #4
Razorbak
Razorbak's Avatar
Default
Good post, wolfman. That should probably be posted in the "How To" forum, too.
Add to Razorbak's Reputation
Razorbak is offline
Old 10-03-2004, 04:41 AM   #5
SL1Joe
SL1Joe's Avatar
Default
Thanx wolfman, it was the Alternator. Went to AutoZone and bought a new Gold Duralast for $120 w/Lifetime Warranty, didn't wanna go reman I know those can be good too but I just felt better going with the 100% new one.
Now if I could just get that passenger power window working (doesn't move and it's not completley closed) i'd have it made here . Haven't been able to wash the car for fear of getting my interior wet.
SL1Joe is offline
Charging System Issue Got Me Stumped KevinVarnes S-Series Tech 21 11-15-2008 11:53 PM
Charging System Question Photomatt S-Series Tech 9 03-23-2006 08:00 AM
charging system woes jjsk8r85 S-Series General 3 06-10-2005 06:55 AM
Charging System Problems schultp S-Series Tech 14 04-20-2005 07:24 PM
charging system problems freedominco S-Series Tech 6 08-15-2004 07:42 PM
