Old 03-29-2001, 02:01 PM   #1
Jeremy
Jeremy is on a distinguished road
Default Stock Airbox
Is there anything i can do to my stock airbox on my 1997 SL besides a K&N drop in filter?
Add to Jeremy's Reputation
Rate the quality of this post and help Jeremy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeremy is offline
Old 03-29-2001, 02:11 PM   #2
evilSL1
evilSL1 is on a distinguished road
Default
I have the same year only i have the SL1 (basically the same car). What you need to do is take the plastic box that is sitting on top of the radiotor off, it has one plastic button clip you need to pull out, the you have to wiggle the pipe in the air box till it comes out. Unless you live in the artic circle or anywhere the air temp. gets below -30 deg. far. But all it does is warm the air.
You can also drill the h*ll out of the bottom of the box. That way it draws in cold air from the bottom also.
Add to evilSL1's Reputation
Rate the quality of this post and help evilSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
evilSL1 is offline
Old 03-29-2001, 02:31 PM   #3
patrick 96sl2
patrick 96sl2 is on a distinguished road
Default
I cut about a 5-6 inch hole in the bottom of my stock airbox using a hacksaw blade.. The car does seem a little more peppier in the midrange area and no increase in noise.
Patrick
Add to patrick 96sl2's Reputation
Rate the quality of this post and help patrick 96sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
patrick 96sl2 is offline
Old 03-29-2001, 02:37 PM   #4
Jeremy
Default
Thanks, i was wondering what that thing sitting on top of my radiator was, i had to take it off once already because my radiator fan died on me. One of my concerns deals with water getting into the filter and such, but i guess its high enough.
Jeremy is offline
Old 03-29-2001, 02:45 PM   #5
evilSL1
Default
Once you do that you should be able to feel an increase in torque and hp, it doesn't get to loud, but it does get a little louder
evilSL1 is offline
Old 03-29-2001, 03:12 PM   #6
Jeremy
Default
I know in a previous discussion someones mentioned a tab coming off of the airbox and that it might damage the upper raidiator hose, is that something i have to worry about?
Jeremy is offline
Old 03-29-2001, 03:16 PM   #7
evilSL1
Default
I never had any problem with any tab, but then again i have know idea what tab he is talking about.
On my car the tube pulled out and i did not notice a tab. I never saw any problems with my hose
evilSL1 is offline
Old 03-29-2001, 03:20 PM   #8
chulo
chulo is on a distinguished road
Default
Check out the ten commandments for saturn owners. Thou shalt rid yourself of thy cursed resctrictive factory airbox lest is draggeth thee down to hell.(With all of the civics) Get a monkey racing intake.
Add to chulo's Reputation
Rate the quality of this post and help chulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chulo is offline
Old 03-29-2001, 03:21 PM   #9
Jeremy
Default
OK, maybe its just on the older models.
Thanks
Jeremy is offline
Old 03-29-2001, 03:24 PM   #10
Jeremy
Default
Hahaha,
Good one Chulo, actually FirePower Performance might be releasing a turbo for my car, i might get it, but if not an intake is the way to go.
Jeremy is offline
Old 03-29-2001, 04:40 PM   #11
Sam96SL2
Sam96SL2 is on a distinguished road
Sam96SL2's Avatar
Default
ok the tab is on the airbox itself as far as the box you removed i dont think it warms the air it is a resonator, put on their to muffle the intake, IMO i would just drop the 150 and get a hotshot. B/C i removed the resonator didnt noticed an increase at all until i put on the hotshot.
Add to Sam96SL2's Reputation
Rate the quality of this post and help Sam96SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sam96SL2 is offline
Old 03-29-2001, 04:43 PM   #12
evilSL1
Default
i actually does both. i was talking with saturn and they put it there as a intake warmer/muffler.
Just a little food for thought
evilSL1 is offline
Old 03-29-2001, 05:26 PM   #13
Sam96SL2
Sam96SL2's Avatar
Default
ok. ? why would you want to warm the air
Sam96SL2 is offline
Old 03-29-2001, 05:26 PM   #14
Jeremy
Default
But, will the tab harm any of the hoses, yes or no?
Jeremy is offline
Old 03-29-2001, 05:59 PM   #15
evilSL1
Default
for some climates you need to have warmer air or you can actually put out the spark
that would basicaly suck really really bad.
but for anyone in a normal climate that box is usless and robs hp and somewhat of a growl.
evilSL1 is offline
Old 03-29-2001, 06:12 PM   #16
Steve96SL2m
Steve96SL2m is on a distinguished road
Steve96SL2m's Avatar
Default
The tab WILL wear a hole in your upper radiator hose after removing the resonator. The hose rests on the resonator, and when you remove it, the tab sticks out near the hose. Don't be fooled thinking that the hose is far enough away and won't touch. After the hose warms up, it sags enough to contact the tab and it will wear a hole quickly. Trust me, I removed mine. About a week later I read about the tab on this message board, so I checked mine. Sure enough, it had started to wear. I would definitely take one minute to cut the tab off. It will not keep you from reinstalling the resonator if you want to in the future, but it may save you from getting stuck somewhere with a busted hose!
Add to Steve96SL2m's Reputation
Rate the quality of this post and help Steve96SL2m reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve96SL2m is offline
Old 03-29-2001, 06:30 PM   #17
Jeremy
Default
Thanks,
I live in sunny Florida so i dont think the climate issue will be a problem, thanks for the heads up on that TAB.
Jeremy is offline
Old 04-01-2001, 12:47 AM   #18
KerryrreK
KerryrreK is on a distinguished road
Default
I used hose clamps to protect the radiator hose as opposed to cutting off the tab (easier and reversable). But I have one question, doesn't this hole in the side of the airbox allow air to come in bypassing the air flow sensor? Wouldn't this make for more air in the air/fuel ratio, which would then be detected by the oxygen sensor at the exhaust manifold which would attempt to correct the problem by using less air? Maybe I'm confused, but isn't giving more air without letting the pcm know it going to cause problems and possibly hurt performance?
Add to KerryrreK's Reputation
Rate the quality of this post and help KerryrreK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KerryrreK is offline
Old 04-01-2001, 04:54 AM   #19
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
The only sensor near the the airbox is the air temp sensor, which people have relocated when removing the air box resonator. I believe the duties of an air flow sensor are handled by the manifold air pressure (MAP) sensor at the intake, downstream from the airbox and throttle body.
Add to Heartbeat - '95 SL2's Reputation
Rate the quality of this post and help Heartbeat - '95 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Heartbeat - '95 SL2 is offline
Old 04-01-2001, 12:58 PM   #20
Jeremy
Default
where do you relocate the air temp sensor to?
Jeremy is offline
De-restricting stock airbox Grymhawk Astra Tech 64 10-28-2011 08:47 AM
Modifying stock airbox yottabit S-Series Mods 8 08-12-2008 06:58 AM
air sensor on stock airbox i think Sony S-Series General 4 09-22-2005 07:21 PM
stock airbox? ATLMike S-Series General 21 10-06-2004 10:23 PM
stock airbox mods? patrick 96sl2 Mods and Performance 6 01-11-2001 04:38 PM
