Old 09-08-2004, 04:55 PM   #1
elvinrodr
elvinrodr is on a distinguished road
2008 VUE 3.6L
Dizzy Need math help!
I want to measure my gas mileage so I drove my 91 SL2 till the needle got to the E (actually below E because with these gas prices it means enough). Went to the station and topped off the tank which came out to 9.508 gal @205945mi on the odometer. Today, the needle was back at enough and the odo. read 206448. Now, if I'm doing this correctly, 206448-205945=503/9.508=52.9mpg? Cant be.
91 SL2M
93 SL2A
Add to elvinrodr's Reputation
Rate the quality of this post and help elvinrodr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
elvinrodr is offline
Old 09-08-2004, 05:05 PM   #2
wrg813
wrg813 is on a distinguished road
Default
Fill up again knowing the mileage at the last fill up, then do the math. However, if you mileage is correct, 500+ miles on one tank is excellant. Anyone put a couple of bucks in without you knowing it?
Add to wrg813's Reputation
Rate the quality of this post and help wrg813 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wrg813 is offline
Old 09-08-2004, 05:08 PM   #3
oneharbour78
oneharbour78 is on a distinguished road
oneharbour78's Avatar
Default
I've heard of good mileage before, but that is crazy. I only see one thing, and that is that you should fill up, make note of mileage, then next time you fill up, divide your miles driven by the amount that you refilled-not the amount that you filled the first time...
But even to get 500 miles in a tank is crazy.
Add to oneharbour78's Reputation
Rate the quality of this post and help oneharbour78 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oneharbour78 is offline
Old 09-08-2004, 05:35 PM   #4
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default
use the trip reset...it's the button stocking outta the gauge. It'll reset it to 000.0 and calculate that way.
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline
Old 09-08-2004, 07:32 PM   #5
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
Default
You have to fill up to the same point both times. Fill until it clicks off two times in a row. Record the gallons you put in the second time and divide that into the miles you drove.
2008 BMW 328i
2013 Subaru Outback 2.5i Limited
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline
Old 09-08-2004, 08:42 PM   #6
RexSpeed
RexSpeed is on a distinguished road
RexSpeed's Avatar
Default
Is your odometer accurate? If the tires you're running are not the OEM size, there's a chance it's throwing off the calibration of the speedo/odo. You might want to make sure that you actually did drive 503 miles.
Add to RexSpeed's Reputation
Rate the quality of this post and help RexSpeed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RexSpeed is offline
Old 09-08-2004, 08:52 PM   #7
elvinrodr
2008 VUE 3.6L
Default
The tires are 1956015 on factory alloys. I also reset my odometer during first fillup and wrote down the mileage. I wanted it to be accurate thats why i drove it to almost empty. When I filled up this afternoon, I wrote down the mileage and the odometer was at 503. I do a lot of highway driving, about 40 miles every day averaging about 75 mph. The last time I took down the readings I came up with 55mpg which I cant see happening. Ill try again next week and take an average of the three.
91 SL2M
93 SL2A
Old 09-08-2004, 09:07 PM   #8
RexSpeed
RexSpeed's Avatar
Default
Have you recently installed any special intake vortex turbolators in conjuntion with twin-electrode spark plugs? Maybe a quart of Prolong in the sump combined with Lucas mystery oil in the fuel? All of the above? According to independent tests, the combined fuel economy increase of the above modifications would match your observed increase over stock pretty closely
RexSpeed is offline
Old 09-08-2004, 10:08 PM   #9
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default Re: Need math help!
You wouldn't use the 9.508 that you originally put in. You want to start once the tank is full then use that mileage based on the amount of gas you put in after having driven it. The easiest way:
Fill tank and reset trip meter.
Drive until the gauge is on E.
Fill tank again and divide the miles on the trip meter by the number of gallons you put in.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Old 09-08-2004, 11:27 PM   #10
oneharbour78
Default
Wait, and you drove most of those miles at 75??? YOur mileage efficiency would have been decreased because of that fact as well...I wanna hear the end of this story.
Old 09-09-2004, 09:00 AM   #11
poorboy
poorboy is on a distinguished road
Default
As a side note. It is not good to run your car down to E all the time. The fuel pump is actually cooled by the gas in the tank (sounds kind of strange doesn't it). By running the tank down, the pump gets hotter and shortens the life of the pump.
94 SL2 Automatic
Add to poorboy's Reputation
Rate the quality of this post and help poorboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
poorboy is offline
Old 09-09-2004, 09:11 AM   #12
Razorbak
Razorbak's Avatar
Default
There is a difference between running down to "E" on the dash gauge before refilling (when there's still reserve fuel in the tank) and running the system until you run out of fuel and stall (bone dry).
Is the Saturn fuel pump a submerged pump design?
Add to Razorbak's Reputation
Razorbak is offline
Old 09-09-2004, 04:33 PM   #13
elvinrodr
2008 VUE 3.6L
Default
Thanks Applefool. Thats what I was doing wrong. Well, I try again.
91 SL2M
93 SL2A
Car Math. Calculate anything! HeroHog Miscellaneous Tech 10 11-26-2017 07:43 AM
Saturn Math Asterixx S-Series General 37 06-23-2009 07:46 AM
GMs fuzzy math mpg walt General Saturn Discussion 22 05-20-2005 03:17 PM
e-bay SC 2 - check the math out. piney S-Series General 15 06-15-2004 03:36 PM
Saturns in Grade 11 Math text! bigbird General Saturn Discussion 2 06-05-2002 03:15 PM
