Old 08-25-2004, 07:56 PM   #1
Meridian
Meridian is on a distinguished road
Default Replacing bulbs for a/c console
I apologize if this has been asked before.
Some of the bulbs seemed to be burned out for the a/c console in my SL1 2001. Can you replace these bulbs, and if so, how do you go about doing that? Also, what type of bulbs are needed?
Thanks
Add to Meridian's Reputation
Rate the quality of this post and help Meridian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Meridian is offline
Old 08-25-2004, 09:04 PM   #2
Default
Check with your local Saturn parts deparment. I suspect that the 2001 cars need to have the entire HVAC control head replaced.
If the car is still under warrenty it is covered by it.
Add to ssicarman's Reputation
ssicarman is offline
Old 08-25-2004, 10:02 PM   #3
Meridian
Default
Does anyone else know if the unit must be replaced, or if the bulbs can be replaced?
Meridian is offline
Old 08-30-2004, 06:17 AM   #4
Meridian
Default
I was able to remove the led lights, there were about 3 that were out. It looks as though they are just held in by the thin wire from the bulb, does that sound right to anyone else? I had to order the bulbs from Saturn.
Meridian is offline
Old 08-30-2004, 03:17 PM   #5
Qlara
Qlara's Avatar
Default
My AC switch bulb was out before, and Saturn doesn't have just the bulb for it. Like Wolfman said, you need a new assembly (Either New from Saturn, or Used from Junkyard).
There's an Option, however. I got a similar bulb (not a direct replacement, but close) from RadioShack. Look for 12V low-wattage bulb with similar connection and size, then make it to fit in the unit. That's how I did it.
Add to Qlara's Reputation
Qlara is offline
Old 08-30-2004, 11:13 PM   #6
wolfman
wolfman's Avatar
Default
Actually credit Ssicarman for that one. I have yet to personally disassemble the HVAC console on an 00' and up "S" series myself so was not sure one way or the other.
Add to wolfman's Reputation
wolfman is offline
Old 09-09-2004, 12:56 AM   #7
Meridian
Default
The bulbs are definitely saudered onto the board, which is the easy part. I went to Radio Shack but the only white led lights they had were 3.6 volt. They don't carry white in 12v. Can you use another voltage, or will it blow the led? Thanks
Meridian is offline
Old 09-11-2004, 03:06 PM   #8
Meridian
Default
Does anyone know if you can use a 3.6v led bulb if the led is normally 12, or what if anything would happen? The new board for the ac is about $130, ouch!!
Meridian is offline
Old 09-12-2004, 02:35 AM   #9
bbene
bbene is on a distinguished road
Default
You could use it if you want the LED to blow right away. Would you plug a 110V appliance into a 220V outlet?
Add to bbene's Reputation
Rate the quality of this post and help bbene reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbene is offline
Replacing Window Console LJ57 S-Series Tech 2 08-13-2009 11:18 AM
Replacing headlight bulbs need help! Hondahater1982 Ion Red Line 6 07-02-2005 12:16 PM
Replacing Bulbs for A/C Console Meridian How-To Library 1 08-26-2004 08:46 PM
Replacing Center Console... Lazydog Vue General 15 05-21-2004 11:15 PM
console light bulbs kev99sl Miscellaneous Tech 1 08-23-2002 04:28 PM
