Old 08-24-2004, 11:43 AM   #1
RustyJCNC
RustyJCNC is on a distinguished road
RustyJCNC's Avatar
Default Security Light non-stop blinking
My security light is on crack. It won't stop blinking. Blinks when I am driving, never goes off...any suggestions or an easy at home fix before I bring her in on the next oil change.
Add to RustyJCNC's Reputation
Rate the quality of this post and help RustyJCNC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RustyJCNC is offline
Old 08-24-2004, 11:47 AM   #2
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default
Could be the computer (BCM or PCM not sure). Any other electrical things going haywire?
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 08-24-2004, 04:31 PM   #3
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default
After having my air bag light go off like that, and the odometer going wacko, my guess would be the same.
Try checking all fuses related to "security" or "BCM" first. There are about 3 fuse panels to check. A trip to AutoZone to check codes won't help, as that would be a BCM issue, not a PCM.
Good luck. It sounds like a trip to the delaer.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline
Old 08-25-2004, 12:36 PM   #4
sstar
sstar is just really nicesstar is just really nicesstar is just really nicesstar is just really nicesstar is just really nice
sstar's Avatar
2002 L-Series 2.2L Wagon
Default
I just had my car in yesterday for the same problem. 2nd time. The first time they reset the codes and said everything is fine. The second time they adjusted a sensor and said everything is fine. One hour later, the security light was on again. I drove back to the dealer, and now they want to replace the BCM. I couldn't wait for the car so I'm having it done next Tuesday. They said I can drive it like it is until then. However, last night the car stalled immediately after starting it, two times. Then it was OK. I'm going to be driving my old Buick until next week. I don't trust the Saturn at this point. I do not want to get stranded.
Add to sstar's Reputation
Rate the quality of this post and help sstar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sstar is offline
Old 08-25-2004, 12:48 PM   #5
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default
That's weird sstar that they would tell you it's the BCM and then it would stall. The BCM doesn't control any engine functions, just things like security,lights,A/c, and stuff like that. I would get a second opinion.
If you do have your BCM replaced, remember to bring BOTH key fobs. They will need to reprogram these to the new BCM. The whole process of changing the thing out and reprogamming was done in a little over an hour for me.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 08-25-2004, 01:53 PM   #6
sstar
sstar's Avatar
Default
Actually, this whole thing started a couple weeks ago. The car stalled once and the security light issue started at that point. It never stalled again until last night. So consequently, I never told the dealer about the stalling. Doesn't the security system cut the fuel supply in case of theft? Maybe it still could be the BCM. BCM, PCM, I don't know. I'm starting to get a sick feeling.
sstar is offline
blinking security lite after new ECM montemontana L-Series Tech 1 12-07-2009 01:05 PM
Security light blinking constantly when locked? 02Saturnlady S-Series Tech 9 06-28-2009 02:04 PM
Vue wont start Security light blinking Powellak Vue Tech 2 01-16-2007 12:02 AM
Stop the Blinking Coolant level light! fatherof5 S-Series Tech 7 08-01-2005 11:09 AM
Security light DTR Light confusion L-300 Holland1 L-Series General 3 08-01-2005 10:12 AM
