Old 08-06-2004, 10:24 AM   #1
DeMAN
DeMAN is on a distinguished road
Default Anyone replace there front and rear Strut mounts
I'm installing new struts all around and wanting to see if anyone also install new mounting kits also.
DeMAN
95 SC2
97 Grand Prix GTP
06 Acura TL
DeMAN is offline
Old 08-06-2004, 11:33 AM   #2
thewretched
thewretched is on a distinguished road
thewretched's Avatar
Default
on a 95, you'll probably need new mounts in the front, but seeing as you're in TX take a look at how rusted the bolts are and decide for yourself. You wont need new rears since the bolts are in the inside of the car.
Just be ready to fight with the strut, cause its somewhat annoying to get it bolted up if you dont have a helper to hold the strut.
goodluck!
thewretched is offline
Old 08-06-2004, 11:57 AM   #3
bbarbulo
bbarbulo is on a distinguished road
Default
I just swapped out my Eibach pro kit back to stock springs... and I have KYB GR2 struts all around. It took me about 4 hours to do very slowly... I screwed around quite a bit, had some smokes, had some ice-cream. I have pix if you need. I'm still using the original upper mounts. AFAIC, I'll replace them when they NEED replacing, since I took them apart, greased them... they look to be in great shape.
bbarbulo is offline
Old 08-09-2004, 09:11 AM   #4
cris_thomas
cris_thomas is on a distinguished road
cris_thomas's Avatar
Default
It is not just rusted bolts on the mounts you need to worry about. The rubber bushings also wear out. When I did my rears the bushing was cracked almost all the way around. If your taking the strut out anyway it would be a good thing to check.
I would have hated to have it fail because I would have had to replace the rear window when the strut shot through it.
- Cris Thomas
SPOC New England
http://www.spocne.org
cris_thomas is offline
Old 08-09-2004, 09:58 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default
i've replaced all four struts, all four springs and all four strut mounts on top. the front struts have bearing on top that eventually gets busted and the ball bearing fall out when you remove the nut on top of the front struts. they'll make noise when you turn the steering wheel. the rear struts mount on top gets torn up and allow the rear struts to pogo stick up when you go over bumps. once you remove the shelf covering and the cap, you can look and see if they are torn up or not. if you've never had them replaced and you have say 100,000 miles or more i suggest doing it when you replace the struts themselves.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Gabriel Front Upper Strut Mounts - Crap cris_thomas S-Series Tech 1 11-23-2008 02:33 PM
Need Help - New Rear Strut Mounts - Clank Noise STRNFAN93SL2 S-Series Tech 12 06-23-2007 05:25 PM
Front Strut Mounts Tom92SCm S-Series Tech 2 12-15-2006 12:06 PM
Replace front strut mounts - Alignment needed? Red97sc2 Miscellaneous Tech 1 09-19-2004 02:31 AM
blown rear strut mounts...why?? red95isback S-Series Tech 3 09-16-2002 01:10 PM
