Old 07-14-2004, 08:21 PM   #1
ma1hman
ma1hman is on a distinguished road
Default bubbles on trans fluid dipstick?
I posted an earlier thred regarding my 2000 saturn SL1 (38k miles). The last few times I have checked the trans fluid, I noticed little bubbles on the dipstick and the color is not as red as it should be.
I was wondering if this is a sign that the trans fluid needs to be changed. I thought that trans fluid goes for 100k miles.
My last thred was regarding the the hesitation and slightly rough riding I experience when driving at about 50mph and higher. The problem seems slightly intermittent. I also stalled out several times at very high speeds (65-70mph). Could these bubbles indicate a problem with the transmission? Is air getting into the system?
Let me know what you think
Add to ma1hman's Reputation
Rate the quality of this post and help ma1hman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ma1hman is offline
Old 07-14-2004, 10:21 PM   #2
Nowhere Man
Nowhere Man is on a distinguished road
Nowhere Man's Avatar
1995 SW2
Default
Actually auto trans fluid is a tune up item. So every 30,000 miles with the spark plugs and stuff. If its not a light red anymore, then its time to change it. As in if it looks like blood.
Sorry I dont have any experience with rough running at high speeds...check the usual stuff. Air filter, clean egr, and change out pcv valve.
95' SW2
131,000 Miles
32-MPG avg.
Add to Nowhere Man's Reputation
Rate the quality of this post and help Nowhere Man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nowhere Man is offline
Old 07-14-2004, 11:05 PM   #3
sierrap615
sierrap615's Avatar
Default
assuming it is a auto, or is it a manual? it may be air or bad fluid. ever use lucas oil?
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 07-15-2004, 02:36 AM   #4
wolfman
wolfman's Avatar
Default Re: bubbles on trans fluid dipstick?
A little foam on the dipstick is quite normal and no sign of anything "bad"
Add to wolfman's Reputation
wolfman is offline
Old 07-15-2004, 05:34 AM   #5
walt
walt has a spectacular aura aboutwalt has a spectacular aura aboutwalt has a spectacular aura about
Default
Make sure you fluid is not overfilled. I had this problem with my Cavlier and the bubbles were being caused by there being over a Qt. to much fluid . The fluid level was past the full mark on the stick. It had just came from a transmission shop after being serviced.
Add to walt's Reputation
Rate the quality of this post and help walt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
walt is offline
Old 07-15-2004, 06:49 AM   #6
BobL
BobL is on a distinguished road
Default
Auto trans fluid has a change interval of every 30,000 miles.
Doing so will improve transmission life.
One very easy job on Saturn "S" since pan need not come off.
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Old 07-15-2004, 10:22 AM   #7
WHITE98SL2
WHITE98SL2 is on a distinguished road
Default
Use Mobil one synthetic ATF in the tranny, you won't regret it.
Add to WHITE98SL2's Reputation
Rate the quality of this post and help WHITE98SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WHITE98SL2 is offline
Rate My Dipstick (Transmission Fluid ) CND_SC1 S-Series Tech 14 02-20-2010 10:53 PM
Finding Transmission Fluid Dipstick, PLEASE HELP! Zalagar S-Series General 5 10-09-2009 11:56 AM
2001 SL1 has some bubbles in fluid and 'hunts' around 1800-2500 rpm ringo5000 S-Series Tech 0 08-20-2009 11:09 AM
trans dipstick length 97sl2DOHCaut1.9 S-Series General 1 07-11-2008 03:33 AM
manual transaxle fluid dipstick? kevo420 S-Series General 14 10-23-2006 10:32 PM
