Old 01-12-2005, 01:02 PM   #21
KPatrick
KPatrick is on a distinguished road
1994 SC2
Default Re: Changing the ECTS Coolant Temp Sensor (with pictures)
Just curious why the replacement in the first place, what were the symptoms? I suspect mine being bad, 94 SC2. It misfires until the engine warms up. No codes and replaced the O2 sensor and EGR valve last year.
Add to KPatrick's Reputation
Rate the quality of this post and help KPatrick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KPatrick is offline
Old 01-12-2005, 01:34 PM   #22
Luke
Luke's Avatar
Fm >> KPatrick <<
>Just curious why the replacement in the first place, what were the symptoms? <
Just do a search on ECTS and you'll come up with considerable & detailed information on it; for Saturn upgraded the unit, as the old ones were cracking, resulting in a mis-read being sent to the computer, with the engine running colder and using more fuel, due to the mis-read.
Add to Luke's Reputation
Luke is offline
Old 01-24-2005, 08:16 PM   #23
JerryHughes
JerryHughes's Avatar
1997 SL
Hi all,
I read somewhere that after the sensor was changed that the PCM B fuse should be reset by pulling that out for about 15 seconds. Is that true? If so, that may be my problem! Thanks,
Jerry
JerryHughes is offline
Old 01-24-2005, 08:22 PM   #24
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Never heard this myself,but it could be true....
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 01-24-2005, 11:07 PM   #25
Razorbak
Razorbak's Avatar
It's in wolfman's ECTS thread...
Originally Posted by wolfman
You "should" reset the PCM after changing this (or ANY sensor) this does NOT require any special tools, just disconnect the NEG battery cable for about 15 secs.
Changing the ECTS (Engine Coolant Temp Sensor)
Add to Razorbak's Reputation
Razorbak is offline
Old 01-26-2005, 02:33 AM   #26
sierrap615
sierrap615's Avatar
you can disconnect the NEG cable, but i perfer pulling the PCM B fuse, its easyier and you don't lose your radio presets.
sierrap615 is offline
Old 01-26-2005, 02:13 PM   #27
reemoe
reemoe is on a distinguished road
1995 SC1
Please forgive, as it sounds like it's super simple, but where and how do I go about pulling the PCM B fuse?
Thank you!
Ryan
Add to reemoe's Reputation
Rate the quality of this post and help reemoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
reemoe is offline
Old 01-26-2005, 03:06 PM   #28
Luke
Luke's Avatar
Fm >> Ryan <<
>where and how do I go about pulling the PCM B fuse? <
After opening up your front hood, there should be a black rectangular fuse box, located in front of the battery, on the driver's side. The top of the box should be secured by a small circular screw. Simply loosen it, and lift up the top of the fuse box. On the underside/inside of the top, you'll see where each of the fuses sit.
Luke is offline
Old 01-26-2005, 03:26 PM   #29
reemoe
1995 SC1
Thanks, Luke! So I just find it, take it out with my fingers, I'm guessing, and put it right back in?
reemoe is offline
Old 01-26-2005, 03:58 PM   #30
Luke
Luke's Avatar
Yep; I leave it out for atleast a "minute". Just to insure that the memory is cleared
Luke is offline
Old 01-29-2005, 10:31 PM   #31
green
green is on a distinguished road
Auxmike:
In the photo with the ratchet it shows one end of the connector (black cap cover) going to the sensor, where's the other end going? My 95 SW1 temp gauge isn't working. The photo with the part in the bag is exactly (with 2 butt connectors) what I bought from Saturn but they give me instructions.
Could you give me instructions (photos?) on how to install the connector.
Thank You very much.
Add to green's Reputation
Rate the quality of this post and help green reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
green is offline
Old 01-29-2005, 11:21 PM   #32
auxmike
auxmike's Avatar
Green,
You crimp the wires to the original wires from the cars harness.You heat up the butt connector's ends to shrink/seal them.
Hope this helps some.....
auxmike is offline
Old 02-02-2005, 09:44 PM   #33
green
I installed the single wire temp gauge sensor connector. Now the temp gauge is working again. But the engine light remains on and the horn doesn't work. This happened after taking my 95 vehicle from tranny shop. The auto parts store only checks vehicles 96 or newer. Do I have to buy a scan tool that will only work on a 95 or older Saturn or GM car?
green is offline
Old 02-03-2005, 12:13 AM   #34
Lucky for you, NO. It's way easy with an OBD-1 ('95 and back) car. This how-to entry describes how to acquire the code with a paper clip, and even deciphers the codes.
That's why the store only does '96 and later; they're OBD-2, which require a scan tool.
BTW, since this is no longer really part of the "how to" for changing the ECTS, you might want to start a new thread in the regular "S-Series Tech" section.
Add to madpogue's Reputation
madpogue is offline
Old 02-06-2005, 11:44 AM   #35
rixter
rixter is on a distinguished road
rixter's Avatar
1995 SW2
Thumbs Up Re: Changing the ECTS Coolant Temp Sensor (with pictures)
Wow is all that needs to be said about this post. Awesome. Thank you.
Does a bear p__p in the woods
Add to rixter's Reputation
Rate the quality of this post and help rixter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rixter is offline
Old 04-25-2005, 10:21 AM   #36
kickarse
kickarse is on a distinguished road
Where;d you guys buy yours? How much did you spend?
02 Saturn L200 - 156k miles - Black on Black
- HIT! 96 Saturn SL2 - 172k miles - Fire Red
- SOLD 97 Saturn SL1 - 126k miles - Green/Brown Speckle
Add to kickarse's Reputation
Rate the quality of this post and help kickarse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kickarse is offline
Old 04-25-2005, 06:33 PM   #37
Tiger
Tiger's Avatar
I got mine at Saturnparts.com. Less then $10 for the ECTS, but $8.50 for shipping. So I bought a Transmission Filter to split the shipping charge and reduce overall cost.
Add to Tiger's Reputation
Tiger is offline
Old 08-24-2005, 08:08 AM   #38
mainedvd
mainedvd is on a distinguished road
There is (was) a little cap that went over the electrical connector to my ECTS on my 97 SL2. I lost it, can't find it anywhere. Is this really necesary? It does cover the wires, but I have heard no mention of this cap anywhere. Would the dealership provide me with a new one, and for how much?
Add to mainedvd's Reputation
Rate the quality of this post and help mainedvd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mainedvd is offline
Old 08-26-2005, 07:01 AM   #39
jdhimie
jdhimie is on a distinguished road
The pictures and explinations are outstanding! Thanks a million times.
Add to jdhimie's Reputation
Rate the quality of this post and help jdhimie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jdhimie is offline
Old 08-26-2005, 08:24 AM   #40
auxmike
auxmike's Avatar
Thanks all.
I never thought this would be so popular.
It was fun documenting the job.
auxmike is offline
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 12:58 PM
ECTS and Temp Gauge Sensor Wiring WingsOfSaturn S-Series Tech 7 10-22-2005 10:45 PM
Ref Mike's "How-To" : Change the ECTS Coolant Temp Sensor w/pics! Luke S-Series Tech 2 06-20-2005 02:19 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
Here's my famous cracked Coolant Temp Sensor Scan {ECTS} auxmike S-Series Tech 36 01-30-2005 02:17 PM
