Old 06-16-2004, 07:58 PM   #1
jviper777
jviper777 is on a distinguished road
Question Ball joint?
I'm on the left front tire. I have the tire rod off but I cannot seem to get the ball joint seperated. I followed the Chilton manual but without the part to seperate I am stuck. It says to use the tool to seperate it and then using a pry bar across a rod, keeping it down, and pull up on the axle you can get it the rest of the way.
Any help. I can't get it to budge.
Thanks.,
Add to jviper777's Reputation
Rate the quality of this post and help jviper777 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jviper777 is offline
Old 06-16-2004, 08:59 PM   #2
wolfman
wolfman's Avatar
Default
Remove the cotter pin and nut from the ball joint stud
Place a LONG (3 FEET or so) pry bar UNDER the engine cradle and OVER the lower control arm so you can pry DOWN on the CONTROL ARM.
While pushing/prying DOWN, HARD! on the control arm, rap the part BELOW where the ball joint NUT was (where the ball joint stud goes through) with a METAL hammer. IF you pry down hard enough, and hit it hard enough, it will suddenly pop right out of the knuckle above it (The control arm will suddenly move DOWN and away from the knuckle above it, taking the ball joint with it)
DO NOT hammer on the threaded ball joint stud!
Add to wolfman's Reputation
wolfman is offline
Old 06-16-2004, 09:05 PM   #3
Lucas1
Lucas1 is on a distinguished road
Default
i usually just pound on the ear of the steering knucke with a hammer until the tie rod end is loose. but heed wolfmans warning, do not hit the threaded part of the tie rod end.
Add to Lucas1's Reputation
Rate the quality of this post and help Lucas1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lucas1 is offline
Old 06-16-2004, 09:37 PM   #4
Default
Ditto^
Add to ssicarman's Reputation
ssicarman is offline
Old 06-17-2004, 04:10 PM   #5
eljefino
eljefino's Avatar
1995 SW1
Default
I don't know how you can even pound on the ball joint stud. There's no clearance. Now the tie rod end has plenty of hammer swingin' room.
Old ball joints that you don't care about can be popped out with a "pickle fork" and hammer. This tears the rubber seal sometimes.
Add to eljefino's Reputation
eljefino is offline
Old 06-17-2004, 08:11 PM   #6
LATEMODELRACING
LATEMODELRACING is on a distinguished road
Default
or just use a picklefork and seperate the the ball joint from the spindle and do not risk hitting something that you are not supposed to!
Add to LATEMODELRACING's Reputation
Rate the quality of this post and help LATEMODELRACING reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LATEMODELRACING is offline
Old 06-17-2004, 08:30 PM   #7
Lucas1
Default
if you use a pickle fork, you will destroy the rubber boot on the tie rod end, the tie rod end will have to be replaced. not recommended, unless you like throwing money away.
Lucas1 is offline
Old 06-17-2004, 10:33 PM   #8
LATEMODELRACING
Default
he said he already had the tie rod off i was talking about the ball joint!
Old 06-17-2004, 11:02 PM   #9
wolfman
wolfman's Avatar
Default
The ball koint likewise has a rubber boot. DO NOT use a pickle fork if the balljoint is to be reused. Follow the directions I gave, it will work...
wolfman is offline
Old 06-17-2004, 11:17 PM   #10
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
I usually leave the nut on, but loose. This does 2 things, protects the threads from errant hammer blows and when it does come loose, it keeps the lower arm under control.
A mechanic friend of mine uses 2 hammers. He places the head of a small sledge against 1 side of the casting and smacks the other side with another small sledge.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline
Old 06-18-2004, 08:52 AM   #11
Luke
Luke's Avatar
Default
Fm ElJefino
This is the very reason I'm having to change mine, for the drivers side unit was torn, then the tech used the pickle fork in removing it, when working on my transmission a couple of months ago.
Add to Luke's Reputation
Luke is offline
Old 06-20-2004, 09:38 PM   #12
LATEMODELRACING
Default
the reason for the job was to replacement of the BALL JOINT.
Old 06-20-2004, 09:44 PM   #13
wolfman
wolfman's Avatar
Default
Not to get into a pi**ing contest here, but the original poster never said he was replacing the balljoint, he just needed help/instructions on how to sperate it from the knuckle...re-read the original post.
wolfman is offline
Old 06-20-2004, 10:06 PM   #14
TedL
TedL is on a distinguished road
Default
Please get a better grasp of the English language, including vocabulary, grammar, punctuation and sentence structure before posting critiques of others' responses. The only thing being shown off is ignorance when one reads in things that aren't written, and writes in a basically unintelligible stream of words and attempts at words.
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 06-20-2004, 11:41 PM   #15
Lucas1
Default
i dont even think that you can replace the ball joint anyway, you would have to replace th lower control arm, right?
regardless, pickle forks are hacker tools.
Lucas1 is offline
Old 06-21-2004, 05:21 AM   #16
TedL
Default
Correct, the ball joint is not separately serviceable; the whole LCA must be replaced.
I take exception to your sweeping comment. I used a PF when my objective was to replace the LCA. Why not use the easiest, fastest method in those circumstances?
TedL is offline
Old 06-21-2004, 07:56 AM   #17
bbarbulo
bbarbulo is on a distinguished road
Default
I most often use a 3 jaw puller, grab the jaws to the knuckle, and press the screw part against the threaded part of the balljoint. no hammering, no prying, no sweat, and no chance at damage. It's so easy! I use the same method for tie rods too. Works like a charm, but it takes some getting used to to get all three jaws to hold on.
Add to bbarbulo's Reputation
Rate the quality of this post and help bbarbulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbarbulo is offline
Old 06-21-2004, 02:41 PM   #18
jasonpopnc
jasonpopnc is on a distinguished road
Default
Here's how I remove it. Do not hit the threads! Do not damage any boots!!
Back the nut off (not completely off). Use a small breaker bar (straight edge end) and position it between the top of the nut and the axle metal housing above the nut. A little downward force will break it loose. I then follow wolfman's instructions. Use a long bar above the LCA and under the engine cradle. Stand on the bar and move the knuckle out of the way. Voila!!
Whats a pickle fork????
Add to jasonpopnc's Reputation
Rate the quality of this post and help jasonpopnc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jasonpopnc is offline
Old 06-21-2004, 06:35 PM   #19
wolfman
wolfman's Avatar
Default
Just gotts to ask...how are you managing to get that tool in there with the installed axle shaft in the way?
wolfman is offline
Old 06-21-2004, 09:00 PM   #20
Default
Just what I was wondering.^^^
Ball Joint Boot? blackeagle1 Classifieds 11 08-27-2012 06:18 PM
Possible Ball Joint Problem! Bkny_72 L-Series Tech 2 12-06-2007 12:58 PM
ball joint replacement adhsc2 S-Series Tech 11 10-01-2007 07:10 AM
Ball joint? Or not? Rozzwell S-Series General 3 11-12-2003 11:13 PM
How do I know is the ball joint or the CV joint? amazinghl S-Series Tech 1 08-16-2002 08:43 AM
